Author Topic: Where to buy mx switches?  (Read 2509 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sun, 15 September 2013, 14:30:20 »
Ok I think I have decided on a keyboard... I will buy a Neo Zelia 87 but I will do ergo clears where can I buy cherry switches?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Where to buy mx switches?
« Reply #1 on: Sun, 15 September 2013, 14:54:38 »
7bit on Deskthority and mouser.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 15 September 2013, 15:01:43 »
Or, if you don't mind used stem, you can get them off something like this Chyron or 8200LAAUS. Taking switches from used boards is what I normally do, as it is usually much cheaper.
« Last Edit: Sun, 15 September 2013, 15:04:27 by IvanIvanovich »
« Reply #3 on: Sun, 15 September 2013, 15:26:23 »
Do all the chyron boards have clears?
« Last Edit: Sun, 15 September 2013, 15:44:43 by SpAmRaY »
« Reply #4 on: Sun, 15 September 2013, 15:51:28 »
All that I have seen so far have clears.
Offline C5Allroad
« Reply #5 on: Sun, 15 September 2013, 16:33:03 »
Ooh cool I'll be ordering this month maybe.. If the shine 3s are back in stock by the time I order then I won't.
« Reply #6 on: Sat, 21 September 2013, 15:18:56 »
 I got one that does not. :(
« Last Edit: Sat, 21 September 2013, 15:31:01 by SpAmRaY »
Offline Tarzan
  • formerly known as Greystoke
« Reply #7 on: Sat, 21 September 2013, 21:09:21 »
Yeah, I got a vintage Allen-Bradley keyboard on Friday.  Massive board.  Huge.  Heavy.  Mostly metal.
And foam-and-foil switches, crappy caps that have stems break off upon removal about 50% of the time...
Ebay roulette - sometimes you win, sometimes you lose, lucky to just break even.
« Reply #8 on: Sat, 21 September 2013, 21:19:10 »
Worst part is whatever these switches are, they are actually nice feeling.
