Author Topic: The Living PCB Design Thread  (Read 614907 times)
Offline jmdaly
Re: The Living PCB Design Thread
« Reply #750 on: Tue, 05 June 2018, 08:29:18 »
I do have the ground planes set up, as per the tutorial. However I did end up with more large red areas which I assume are 'missing ground planes' than he has in the tutorial, which I was not sure what to do with.
Those red areas you see show that you have ground plane on one side of the board, but not the other. The trick to getting the ground plane over to the other side is to do via stitching. I followed https://forum.kicad.info/t/protip-nicer-via-stitching/1103 to do my via stitching.
Offline evn
« Reply #751 on: Tue, 05 June 2018, 12:02:26 »
Thanks! That actually worked out great https://i.imgur.com/qB1Fjyp.png
Offline jmdaly
« Reply #752 on: Tue, 05 June 2018, 12:06:58 »
Great, I'm glad it helped!
Offline evn
« Reply #753 on: Tue, 05 June 2018, 16:40:22 »
Okay I think this design is about ready to be scrutinised. Would someone be willing to have a look over my kicad files and point out any mistakes/errors? They're available here.
Offline hanya
« Reply #754 on: Tue, 05 June 2018, 19:14:58 »
Hi,
- It is hard to solder through hole diodes under the switches. But it is OK if your switch having hole which allows you to put a diode on the case of the switch.
- In your design rules, you have 0.6 mm via dia and 0.4 mm via drill. This means 0.1 mm annular ring of via. I suppose you to make larger annular ring to match the design rule of the PCB manufacturer which you have choosen.
- If you want to make reference of some parts clear, place references away from pads and vias.
PFU HHKB JP, Sanwa MA-TB38 trackball
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #755 on: Wed, 06 June 2018, 02:55:50 »
I would recommend not running USB through vias where you can help it, and avoid 'T' junctions for your traces, you don't want hard 90deg angles.
Offline evn
« Reply #756 on: Wed, 06 June 2018, 07:23:55 »
I should be able to change the traces to avoid vias from the USB and remove 90deg angles without too much hassle. Thanks for your input! Do you know if wiring these 3 pads on the USB like this is okay? It isn't in the tut to do it, I just did it to get rid of an unconnected pads error.
Hi,
- In the tutorial I followed he mentions that this diode placement only works for SMD diodes, so I'm gonna get SMD ones for this. That should be okay as I think the SMD diodes go on the other side, right?
- I haven't even looked into PCB manufacters yet, I'm going to do that now. Thanks for your help!
« Reply #757 on: Wed, 06 June 2018, 15:43:38 »
Running the ground trace like that isn't a problem, but might be redundant since those pads will connect through the layers and ground.
SMD will be fine, no issues there, the diodes and switches are on different sides of the board so if you use SMD you won't run into problems.
The cheapest place I have found for getting a PCB printed was at https://jlcpcb.com/quote, but my pcb shape and size were normalish, I don't know how your PCB shape will affect costs.
Offline _ODIN_
« Reply #758 on: Wed, 13 June 2018, 15:02:20 »
Do you know a good online shop located in Europe to by the components, like diodes and the controller, from?
« Last Edit: Tue, 19 June 2018, 16:21:43 by _ODIN_ »
Offline Croktopus
« Reply #759 on: Fri, 22 June 2018, 06:41:05 »
Hey, does anyone have an SMK 2nd gen footprint on hand? I sent out a couple PMs to people selling SMK boards and haven't heard back yet, so I figured I'd ask here
Offline Tech22
« Reply #760 on: Fri, 22 June 2018, 13:43:59 »
Hello. I want to use this type c pro micro controller with a custom pcb found at https://tinyurl.com/yby9bd42
How would I go about making the PCB to work with that? I am also confused on how I bridge each switch with the traces etc. I am using KiCad and my layout can be found at https://tinyurl.com/y9b6oftl
Thank you.
« Last Edit: Fri, 22 June 2018, 13:45:39 by Tech22 »
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #761 on: Fri, 22 June 2018, 17:29:24 »
I don't know if all 2nd gen SMK switches have the same pin spacing, but Scott who runs www.lfkeyboards.com was cool enough to post all his keyboard footprints on GitHub.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline Croktopus
« Reply #762 on: Sat, 23 June 2018, 03:55:55 »
thank you so much mandrew!
« Reply #763 on: Mon, 25 June 2018, 09:49:25 »
First of all, thank you for everyone who checked my schematic and gave me advice on my last project, it ended up working out great.
Currently, I am trying to create an AEK compatible PCB for the KBDFans KBD66 based on Hasu's Alps64 project. Due to a deficiency of pins, I placed solder jumpers so there is choice between having the reset LED or split-backspace and a third key to the right of the spacebar (neither of which I will use). Can anyone tell me if this is alright since I am about to send this out for fabrication.
Also, anyone have Alps64 parts on hand and can do the SMD work? Otherwise, I'll just buy a cheapo 858D.
Offline Croktopus
« Reply #764 on: Fri, 29 June 2018, 02:34:19 »
id really like to add a volume wheel of some sort (like a knob from a car stereo, or a rolling design, or whatever really), but i have no idea how. has anyone here done something like that before?
Offline senso
« Reply #765 on: Mon, 02 July 2018, 04:25:21 »
Hardware wise, an encoder is what you want, lots of styles to choose from.
Offline Nixon
« Reply #766 on: Thu, 26 July 2018, 03:16:21 »
Designing a 39 key board using the new Kailh Chocs, similar to the Planck but 10 keys wide instead of 12. First complex design in Eagle so I thought I'd better upload it here to see if anyone can spot something I've done wrong. I know I've wasted space by mounting the Arduino Pro Micro behind and not underneath the keys, but wanted a pen tray so got space in the case and it made laying traces a whole lot easier. Will add mounting holes and a ground plane but just want to check that my progress so far is all good.
Edit: Here's the parts library for Eagle with the Kailh Choc in: https://github.com/skullydazed/clueboard_eagle
« Last Edit: Thu, 26 July 2018, 03:18:11 by Nixon »
Offline marhalloweenvt
« Reply #767 on: Thu, 26 July 2018, 05:16:32 »
So far, your work is still good. But i think you should put column pins in 1 side and row pins in other side of pro micro for easy to debug if there would be errors.
« Reply #768 on: Wed, 08 August 2018, 15:28:55 »
I am a bit confused by everyone grouping the capacitors off to the side. I have been looking at the Teensy 2.0 schematic and TalkingTree's GH80-3000 PCB for reference. When using the ATmega32u4, do I need a 1μF capacitor on both the UVCC and VBUS lines? Also, does it matter whether I be put the 22Ω resistors for the D+ and D- lines near the MCU or USB port?  I've read the capacitor on pin 42 (AREF) is optional.
Done with this PCB so this is what I have (minus the ground plane).
Offline bpiphany
« Reply #769 on: Fri, 10 August 2018, 09:10:27 »
Aref is optional altogether if you're not doing analog readings. I believe you should leave it unconnected if not used.
You need a 1uF cap on Ucap.
It's recommended to put the 22Ω resistors close to the pins.
It's recommended to have one 100nF cap close to each VCC pin, it's probably also advisable to have some bulkier capacitances close to the chip, as well as a big bulk capacitor over the VCC to GND pins. You should keep the total capacitance below 10uF to comply with the USB spec.
Decoupling is a complicated subject, and you are most probably better off overkilling it.
Offline AresTheGod
« Reply #770 on: Sat, 11 August 2018, 17:19:56 »
First time using KiCad, but I'd like to create an on-board per keys RGB TKL pcb with multiple layouts available with USB Type C connector. I've read loads of thing about how to design PCB but almost none of them mention how to add per keys RGB. So far, the closest thing I've seen to what I'd like to do would be this https://easyeda.com/IBNobody/Matias_RGB_TKL_copy-2d2fab1805ff4c39b05c490e5ca4c47c?authenticate=force# . However, it doesn't meet every one of my requirements. I'm also not sure which controller I should use as I've seen people talking about a lot of different controllers such as the ATmega32u4 and the Teensy++ 2.0 .
Here's what I've done so far since I don't really understand which/where should I put the RBG led in here 201864-0
« Last Edit: Sat, 11 August 2018, 17:21:27 by AresTheGod »
Offline ErgoMacros
« Reply #771 on: Sat, 11 August 2018, 18:30:55 »
Hi,
I can't help with the RGB LEDs (sorry), but in terms of what micro controller board to use
start with your input/output pin requirements.
These will be something like:
  x = number of columns
  y = number of rows
  l  = number of indicator LEDs (caps lock, numb lock...)
  u = number of pins to talk to your RGB array
So you might need something like:
   17
+  6
+  0 or 3? Not sure about this count
+  3 or whatever you want
  29 or so available pins on your controller, minimum
Teensy++ 2.0 has lots (37!)
Pro Micro has 18.
You can get away with fewer by either adding hardware (chips) for things like multiplexing (http://www.openmusiclabs.com/learning/digital/input-scanning-matrix/shift-brigade/index.html) or creating more complex matrixes.
Your 17 x  6 keyboard, minus 11 blank key slots = 91 keys. A 10 x 10 matrix will cover 100 keys so if you wanted to create a "complex" matrix 20 pins would do (instead of 17+6 = 23)
Today's quote: '...“but then the customer successfully broke that.”
Offline AresTheGod
« Reply #772 on: Sun, 12 August 2018, 03:59:30 »
So if I understood what you're saying, the pros of having a "complex" matrix would be to use fewer pins and the cons would be the "complex" part? Are the pros worth the cons? And the "complex" matrix would look like that? 201898-0
Offline ErgoMacros
« Reply #773 on: Sun, 12 August 2018, 13:34:16 »
Yes, exactly.
The pros of fewer pins are
* cheaper processor. . If you're producing millions of keyboards, and the larger (more pins) processor costs $1 more, it's probably worth it to design for the cheaper processor.
* for 1 keyboard the price difference is negligible.
* if the real estate on the PCB were very limited for some reason, having a physically smaller processor (fewer pins) could help.
The cons of fewer pins are
* not every key on keyboard row 0 would go to the same processor pin. So every time you wanted to know which 2 pins went to key you'd have to do a mental translation between the physical location and the microprocessor pins.
* The advantage of more pins is that the matrix is laid out just as you first posted. Each key maps to the same pins as it's neighbors.
This makes the keymap simpler, easier to "grok" as you change the key assignments.
Offline AresTheGod
« Reply #774 on: Sun, 12 August 2018, 14:08:21 »
Ok I see, thank you!
But by the way, since we’re using a Teensy controller, why not using the lastest? I saw a Teensy 3.6 somewhere and it had even more pins that the Teensy 2.0++. Would it also be overkill for a keyboard and be more expensive that it should be? Because it seems that nobody is using these newer version of Teensy.
« Reply #775 on: Sat, 18 August 2018, 22:00:36 »
Thank you once again for such a detailed response. I do have the 1uF capacitor on UCAP and will remove the on AREF, but other than than does everything look good? When you say VCC, does that only include just the pins 14 and 34 or the UVCC, VBUS and AVCC pins too?
Offline hanya
« Reply #776 on: Sun, 19 August 2018, 00:49:18 »
Not so many people designs full size keyboard which requires many pins. If you design such PCB, you can put MCU on your board directly. No need to put external board.
If you use RGB LED contains own controller such as SK6812, its V_HIGH is 3.4V on 5V circuit. Teensy 3.6 works on 3.3V and it might not work with the LED. Most of them might work well even with 3.3V but some might not work.
Not only the price of the board but components on your circuit is also important to choose target MCU. You can use level converter between 5V and 3V system if you really needed.
Offline _ODIN_
« Reply #777 on: Sun, 26 August 2018, 08:34:55 »
hello guys, do you know where to get the kicad footprint of this component? http://www.kailhswitch.com/uploads/201815927/PG151101S11.pdf
Offline bpiphany
« Reply #778 on: Tue, 28 August 2018, 06:03:36 »
Slow response, but the answer improved from it I believe =) When you are doing a simple design powered through USB with 5V IO everything VCC is the same. There are some different scenarios in the chapter " USB Module Powering Options" in the datasheet http://ww1.microchip.com/downloads/en/DeviceDoc/doc7799.pdf
Offline CameronBanna
« Reply #779 on: Tue, 04 September 2018, 00:27:09 »
If you google search "kailh socket kicad" you can find quite a few.
Heres one for example. https://github.com/daprice/keyswitches.pretty
« Reply #780 on: Wed, 05 September 2018, 21:56:28 »
Thank you once again for such a detailed response. I do have the 1μF capacitor on UCAP and will remove the on AREF, but other than than does everything look good? When you say VCC, does that only include just the pins 14 and 34 or the UVCC, VBUS and AVCC pins too?
Thanks, must have missed all that when looking through the 32u4 files, added a 1μF capacitor to VBUS. I'll have this off to fab once I get the USB port measurements coordinated with the case.
Offline Moosewing
« Reply #781 on: Wed, 12 September 2018, 15:34:52 »
Hoping to order a prototype within the next few days, but I'd like to run it by someone first.
Schematic and BOM:
I know it's bad practice but I didn't put the switch matrix in the schematic because it was constantly changing up until the end and I didn't want to bother editing the schematic after every little change. I'll be better about this in the future, I promise.
Full board pics:
This PCB is going to be used for a few different projects involving Omron B3G-S and KPT switches. The outermost pins in these switches are connected internally, so it's easy to go row2col and keep it (mostly) on one layer. I originally had it wired col2row until I opened up my FK-555 and noticed this pattern on its PCB.
MCU pics:
I only just realized as I was making this post that I forgot to connect the bottom left VCC pin to the rest of the VCC pins. That aside, I have a few questions.
Does it matter which VCC pin is connected to the USB port since they're all connected anyway? I have mine connected to uVCC but a lot of boards I've seen have it connected to VBUS.
I have a ground plane on each layer, connected together by the mounting holes. Are those enough, or should I add some via stitches elsewhere?
How should I go about connecting the isolated copper islands under the MCU and by C1 and C4/R3? I have a via on each section just to mark and identify which ones need to be connected, but beyond that I'm not sure. And of course, if anything else needs to be changed, I'm all ears.
« Last Edit: Thu, 13 September 2018, 17:59:50 by Moosewing »
Offline RealLaugh
« Reply #782 on: Fri, 14 September 2018, 00:38:47 »
it might be the software you're using but I don't see the 2 other pins (2 and 4) on the quartz going to GND?
Schematic and BOM:
Full board pics:
MCU pics:
Offline Moosewing
« Reply #783 on: Fri, 14 September 2018, 10:31:10 »
2 and 4 are connected together, and then 2 is connected to the ground plane. I'll go ahead and connect it manually to the ground pads on the capacitors though.
Offline online
« Reply #784 on: Wed, 19 September 2018, 10:18:59 »
Hi everyone,
I'm trying to design a pcb with atmega32u4 by following the pcb design guide on github. Got some pcbs made.
Soldered 4-5 of them but all have the same problem.
When it connected to PC (Windows 10), it recognised as 32u4 and detected by Atmel flip as well. However, after it plugged in for around 15mins, it disconnected by itself. It continue failed to be recognized after I reconnect it.
It happened with or without firmware flashed-in. I checked all pins are not shorted.
I set all trace to width to 6.30mil(0.16mm) and realised the VCC trace width is too thin after I sent the file to the manufacturer, could this be the problem?
Here is the schematic and PCB. Please help. :(
203917-0
203919-1
« Last Edit: Wed, 19 September 2018, 14:43:44 by online »
Offline tedfs3
    • No Mercy Given
« Reply #785 on: Sun, 23 September 2018, 19:50:24 »
Has anyone done up KiCad footprints and symbols for Kailh BOX switches or do the MX footprints suffice ? I'm not entirely clear if the nubs on the switch need to sit ON the PCB or if they sit down IN the PCB.
Offline senso
« Reply #786 on: Tue, 25 September 2018, 05:38:53 »
Hi everyone,
Your decoupling caps are in a nice row, miles away from the micro-controller.
Traces are too thin as you said.
No ground plane, ground is horrible as well, and it seems like your bypass caps ground is not connected to anything
Offline bpiphany
« Reply #787 on: Tue, 25 September 2018, 07:53:38 »
Good spotted, I didn't catch that. Which also would mean the oscillator caps are not connected to GND either. The oscillator circuit layout in whole is questionable as well I'd say.
It's hard not to sound harsh about it, but did you read up anything at all on circuit design?
Online Findecanor
« Reply #788 on: Tue, 25 September 2018, 14:13:41 »
BTW. I see quite a few junctions between rows and columns in that matrix. (I suppose you would have spotted and corrected those yourself by now, but anyway...)
Offline N9vem
« Reply #789 on: Fri, 05 October 2018, 17:16:41 »
Hi!
Are there someone who designed a pcb for RAFI RS 76 C switches? Can hall effect switches be compatible with QMK? I'm only briefly run trough the rafi schematics and I'm not good enough / I don't have time enough to design a pcb for 76 C switches yet, but its one of my further goals. Does somebody encountered Marquardt Two Fingers Typewriter switches, is it worth the time to design a pcb for them (for those great doubleshot keycaps)?
Offline LifeZ
  • LifeZone
« Reply #790 on: Thu, 18 October 2018, 20:02:49 »
Hello guys,  ;D
I am going to study artwork.
It is not easy because there is no knowledge about electronics.
I use Altium.
I just want to follow various things.
LZ Limited
Offline online
« Reply #791 on: Sun, 21 October 2018, 07:11:37 »
Hi everyone,
Thanks for your help. I've re-designed another test board based on your suggestion and it works! :)
I'm a total noob when it comes to circuit design, I read ruiqimao keyboard pcb design guide and also bits of info from everywhere.
atm, I'm just copying people's design and modify the layout to fit my need, didn't realise it's not as straightforward as I wish to be.
Didn't know the decoupling caps need to be placed near the IC.  :-\
PCB layer is filled with ground plane, is this a correct way to ground oscillator?
Here is another test board which is working, but any suggestion on improvement will be appreciated.
205871-0
205873-1
Offline bpiphany
« Reply #792 on: Tue, 23 October 2018, 09:51:53 »
That looks a lot better =)
I would rotate the controller 180° to route the USB lines shorter. Everything else should be equally easy to route that way. There is no reason not to move C4 closer to its VCC pin. You could move C3,7,8 closer to the chip as well.
I never used an external pull-up resistor on the reset pin, and I never had any problems without one. I would just drop R1 completely.
I would rotate C6 to have its axis pointing towards the controller (like the other caps and resistors), but that's just personal preference.
« Reply #793 on: Tue, 23 October 2018, 22:42:15 »
Hello,
I am designing my PCB with Kicad. Could you guys please give me some advices/tips in how to route track? For now, my tracks on pcb are a mesh. I just want to make them as beautiful as you guys did.
I am very appreciated with every single advice/tip you guys can give me.
Offline jayvee
Couple of questions about Teensy 2.0 connections on Ergodox
« Reply #794 on: Thu, 20 December 2018, 03:26:34 »
Hi,
I am trying to design my own split mechanical keyboard. For reference purpose, I am depending upon the design of Ergodox from github repository https://github.com/Ergodox-io/ErgoDox
Please find here the Teensy in the circuit diagram.
209148-0
Does anyone know why PB4 of Teensy is connected to Vcc and why PD6 is connected to ground?
If these are unused pins like PC7, PD4, PD5, PD7 and PE6, then they should not be connected anywhere else.
Thanks.
Offline jayvee
Re: Couple of questions about Teensy 2.0 connections on Ergodox
« Reply #795 on: Fri, 21 December 2018, 02:33:16 »
Hi,
+ Attachments and other options
Verification:
Thanks.
I looked at the Teensy 2.0 circuit (attached below) and found that D6 is connected to an LED and 1K Resistor and then connected to ground. This may be the reason about PD6 in Ergodox circuit shown as connected to ground.
Does this mean PD6 is effectively not available for either row or column purpose in a keyboard?
209185-0
Offline jayvee
« Reply #796 on: Fri, 21 December 2018, 04:46:40 »
Hi,
Verification:
Thanks.
I will just use PD6 for lighting up one of my status LEDs such as NumLock LED. Hope it can light up two LEDs together (one on the Teensy board and one on my prototype breadboard).
I am still clueless about PB4 of Teensy connected to Vcc. For now, I am ignoring it and plan to use it as in I/O for one of the rows on Left Hand Side keypad.
Offline bpiphany
« Reply #797 on: Sun, 23 December 2018, 13:39:52 »
Hi,
Thanks.
Bizarre reasons! Reason enough? ;) =D
Ok, so that was my doing. And the explanation is probably not super easy to think up on your own. It has to do with the flip-ability of the PCB. There's no reason to connect PB4 to VCC (or PD6 tp GND), and you probably should avoid to. The reason is that the pads doubles as VCC/GND pads for a decoupling capacitor for the IO expander.
So it was mostly a technicality to get it into KiCAD.
Offline jayvee
« Reply #798 on: Tue, 01 January 2019, 05:14:03 »
Thanks for the explanation! This means PB4 and PD6 are free and available for IO purposes. I will use PD6 to light up an LED as it has PWM support. And can use PB4 as one of the I/O lines.
In my case the two PCBs are distinct and so most likely I will not face the design issue you were facing.
Great!
Offline kuerb
« Reply #799 on: Thu, 03 January 2019, 05:37:04 »
Hi,
I'm currently trying to build my own full size keyboard with a custom layout. After reading through the whole thread (I actually just made an account so subscribe to this thread  ^-^) I still have some questions:
  • I've read that you should not place traces below the oscillator and surround it by a ground plane. Is that only specific to that layer or should I keep the traces on all layers away from the crystal?
  • I want to use a ceramic resonator. Do these even have the same issues with interference as crystals?
  • Originally I wanted to add LED backlighting but now I'm unsure: At >100 LEDs in parallel, drawing 20mA each, thats more than 2A (and therefore more than the 500/900mA USB provides and way more than the 20/100mA the Atmega32u4 can drain). What are the tricks to get low power LED backlighting?
Thanks a lot.
