Author Topic: [eBay]IBM Logo for model M  (Read 2252 times)
Offline cactux
  • Topre Knight
« Last Edit: Sat, 28 September 2013, 17:05:51 by cactux »
[FS]☠ The temple lol ->HERE<-
Offline E TwentyNine
    • Some of My Keyboards
Re: [eBay]IBM Logo for model M
« Reply #1 on: Sat, 28 September 2013, 17:28:13 »
Moose had gotten one from this guy, turns out it was a bit too large.  Thread here:
http://geekhack.org/index.php?topic=37430.msg892131#msg892131
Offline JimByr
  • ...old guy...
« Reply #2 on: Sat, 28 September 2013, 20:09:45 »
I got one also. It's much larger than the Model M logos.
My solution to getting a Model M logo. Find a junked keyboard and get the case piece with the logo so that it can be recovered. I just got a case piece from a vendor who has junked Model Ms. The piece that I received came from a 1391401.
Recovering the logo shouldn't be too hard. That's my next project. The big question is what adhesive to use to attach the logo to the Model M case that I'm repairing.
« Reply #3 on: Sun, 29 September 2013, 13:34:56 »
Won't that be awfully thick?
Rubber cement is probably the best for attaching it. Household caulk or sealant will work but be careful and only use a tiny amount.
I trust that anyone with a junk metal-badged model M/F knows to remove that badge if they discard the case. A few drops of naptha (old-fashioned cigarette lighter fluid) will soften the original adhesive.
"Technology can make us forget what we know about life."
- Sherry Turkle
Offline JimByr
  • ...old guy...
« Reply #4 on: Sun, 29 September 2013, 16:29:17 »
Don't understand. I'm removing the logo sticker from the case piece and then adding the logo to a case top that needs a good logo
Thanks for the suggestions. I was going to start with GooGone to loosen the label. Will experiment on the damaged logo that needs to be removed first.
« Reply #5 on: Mon, 30 September 2013, 07:49:59 »
I'm sorry, I have not examined a newer Model M closely in a while. I was thinking that the label was embossed into the plastic and/or painted.
If it is a thin clear plastic, then a light spray adhesive might work best. The trick will be preventing it from curling, since it is likely to be stretched as you remove it.
- Sherry Turkle
Offline JimByr
  • ...old guy...
« Reply #6 on: Mon, 30 September 2013, 10:01:42 »
The Model M logos are probably adhesive 3M labels... maybe layered. The surface is a very durable plastic. They can be removed intact. Thanks for the idea about using a spray adhesive. I didn't think about that and it would work perfectly. I have a can around here somewhere.
Offline MTManiac
« Reply #7 on: Mon, 30 September 2013, 15:44:10 »
The #1 trick for removing labels, stickers, heck even BUMPERSTICKERS!
a hairdryer
They get hot enough to warm the glue without warping the label 99.99% of the time.
Plus, since the glue is already warm so you can re-use it or remove it with alcohol very easily.
Offline JimByr
  • ...old guy...
« Reply #8 on: Mon, 30 September 2013, 19:49:59 »
I'll try a hair dryer. I'm curious as to whether that will work with 25 or so year-old adhesive.
« Reply #9 on: Mon, 30 September 2013, 19:54:47 »
This thread sent me to my junk pile. I took a black label off a 1993 Lexmark in 15 seconds with naptha (lighter fluid).
- Sherry Turkle
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #10 on: Tue, 01 October 2013, 02:54:51 »
Does somebody have a spare logo for me from a used board?
« Reply #11 on: Tue, 01 October 2013, 21:10:53 »
which one are you after: I have a dome-model M keyboard that I'm slowly parting out (I may bolt mod it someday)
