Author Topic: Is KBC-3500B a PCB or Plate mount?  (Read 1971 times)
Offline quake4mhg
« on: Sun, 29 September 2013, 23:07:57 »
www.keyboardco.com/keyboard/black-left-handed-keyboard-ps2-and-usb.asp
Sorry, I'm newbie  ;D
I brought this last year, would like to know if I can swap the switches to other without soldering.
Thank you very much in advance.
« Last Edit: Sun, 29 September 2013, 23:13:27 by quake4mhg »
Offline jonathanyu
Re: Is KBC-3500B a PCB or Plate mount?
« Reply #1 on: Sun, 29 September 2013, 23:41:36 »
it is plate mount
Offline yasuo
  • spanengan puyeng newbie
« Reply #2 on: Mon, 30 September 2013, 00:00:06 »
looks case/plate mount maybe
plate made from plastic it seems
Logitech MK220 Colemak DH
« Reply #3 on: Mon, 30 September 2013, 00:01:36 »
I can tell it's plate mount by the plate.
Offline jabar
« Reply #4 on: Mon, 30 September 2013, 00:23:23 »
three responses but no answer.
Since it's a plate mount, you won't be able to replace switches without desoldering.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline quake4mhg
« Reply #5 on: Mon, 30 September 2013, 01:45:31 »
Thank you very much guys :D
Offline quake4mhg
« Reply #6 on: Mon, 30 September 2013, 23:11:36 »
Sorry, dumb question again, could I open the switch top just change the spring & stem, make it MX red? (originally is MX black).
Thank you again.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Mon, 30 September 2013, 23:19:27 »
Thank you again.
Nope, with plate mount you have to desolder and remove them from the plate. That is unless you have a custom plate that allow switch top removal. Your plate does not support this.
Also, red and black stems are the same except for the color. The only think you would need to change to Mx reds is the spring.
Offline terran5992
  • One With The Cup Rubber
« Reply #8 on: Tue, 01 October 2013, 03:41:14 »
Unless you get a phantom plate
