Author Topic: Methamphantomine - Breaking Bad themed Phantom [UPDATED: 25-03-14]  (Read 14970 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
So I made a Breaking Bad inspired case in dedication of the great show it was. This is for my upcoming Phantom PCB from MK.
38093-0
The side view with and without flash:
38095-1
38097-2
I used the green and white from the opening sequence theme, the blue for the crystal meth and yellow and black for the feet, for the danger that was Walter White.
38099-3
38101-4
I'll be making a dust cover using this acrylic plate:
38103-5
I wanted to use the hat-glasses-beard image initially, however after the series finale, the skull and cross-bones version looked more apt. :D
EDIT: The bolts and nut are temporary, I'll be using flat head screws and brass stand-offs once the brass stand-offs come from China.
UPDATE
I finally got time to complete building the case, so here it is, still waiting on Toxic GB and a few other caps to reach me (Shot-key and toxic green gasmask) to complete it, till then just mixing things up with Tai Hao OEM DS green and Dolch Cherry mods.
I'm loving the layout and the pseudo-numpad.
PCB: White Phantom PCB from MechanicalKeyboards
Switches: Ghetto-greens, 80g springs from Originative in blue switches
Stabs: I was able to mod cherry plate stabs and glue them in, by cutting the top tabs on the stabs that lock the stab into the plate.
Layout: ANSI125 92-key
Firmware: Metalliqaz's keymapper generated custom
Material: All layers are cast acrylic, green-translucent blue-milky white-translucent yellow-smoke
Keycaps: Temporary Tai Hao green and Dolch Mods (Will put Toxic). Breaking Bad and crystal meth caps from TechKeys.
With the dustcover:
Dust cover off:
Back:
« Last Edit: Tue, 25 March 2014, 18:29:52 by MOZ »
Re: Methamphantomine
« Reply #1 on: Mon, 07 October 2013, 14:34:46 »
Ha, nice one moz! ;D
I love the series and I love this case too!
Offline MOZ
  • Busy making stuff
« Reply #2 on: Mon, 07 October 2013, 14:38:09 »
I swear this is the last acrylic update for tonight :P
I plan on using the breaking bad keycaps from SP for the 5 extra keys as compared to a traditional TKL. 3 meth caps and the two "Br" "Ba" on either side of the up arrow.
I think the Tai Hao Green set and the toxic set when it gets made would go best on this board.
« Reply #3 on: Mon, 07 October 2013, 14:40:52 »
Never seen breaking bad but that case is flipping sweet!
And I clearly should have asked for a dust cover, didn't know you were making those :eek:
« Reply #4 on: Mon, 07 October 2013, 14:43:02 »
Tai Hao
step it up
taohao has no place on this board
Offline MOZ
  • Busy making stuff
« Reply #5 on: Mon, 07 October 2013, 14:43:39 »
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: Go.Watch.Now.
Offline MOZ
  • Busy making stuff
« Reply #6 on: Mon, 07 October 2013, 14:44:58 »
Tai Hao
step it up
Toxic it is bro, order has been placed, waiting for it to be produced. And the name of the set itself is match-made for this case.
Offline MKULTRA
  • telling it how it is
« Reply #7 on: Mon, 07 October 2013, 14:52:10 »
How much did that cost you MOZ?
Offline MOZ
  • Busy making stuff
« Reply #8 on: Mon, 07 October 2013, 15:04:32 »
About $55
Offline MKULTRA
« Reply #9 on: Mon, 07 October 2013, 15:05:38 »
About $55
Wow thats a good deal...
« Reply #10 on: Mon, 07 October 2013, 21:48:11 »
About $55
You could make one on your own pretty cheap if you wanted to.  I have a place that does laser cutting nearby where you can get an hourly pass for $30 or monthly membership for $95-140. You could crank out several of these cases in an hour and the materials cost isn't obscene, so if you decided to sell some, you could probably offset the machine time cost pretty easily.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #11 on: Mon, 07 October 2013, 22:28:26 »
I love the work. Dual Colour layer.
Offline MKULTRA
« Reply #12 on: Mon, 07 October 2013, 22:39:50 »
About $55
Still gotta buy acrylic
Offline Photoelectric
« Reply #13 on: Mon, 07 October 2013, 23:43:28 »
Very unusual combination, and I like the story behind it + the name :thumb:
Offline bazemk1979
« Reply #14 on: Tue, 08 October 2013, 00:18:27 »
I always wondered how does the acrylic cases fair with steel plate instead of the acrylic one, possible thing to pull out?
« Reply #15 on: Tue, 08 October 2013, 00:23:58 »
I should ask, how thick is the acrylic for this?  I've been looking at making a case like this out of wood since I have a place I can do laser cutting/engraving at an hourly rate.  I'd need to make up the files, but it should be interesting.
Offline MOZ
  • Busy making stuff
« Reply #16 on: Tue, 08 October 2013, 02:31:17 »
3mm per layer.
The case took almost two hours to cut, since I was there while it was happening. About 8 feet of acrylic used due to wastage because of the multitude of colors. So I don't kniw how much cheaper I could have got it cut.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: Methamphantomine - Breaking Bad themed TKL case
« Reply #17 on: Wed, 09 October 2013, 14:32:50 »
MOZ you amaze me
Offline MKULTRA
« Reply #18 on: Wed, 09 October 2013, 14:34:30 »
The acrylic Poker case I have works with a steel plate.  You put it over the acrylic one provided.
  • Live long and prosper
« Reply #19 on: Wed, 09 October 2013, 14:38:37 »
Love this. Would have you make me one if I wasn't so damn poor lol
tp thread is tp thread
Offline MOZ
  • Busy making stuff
« Reply #20 on: Thu, 10 October 2013, 01:11:43 »
MOZ you amaze me
Thanks, it is this encouragement, that keeps me going.
Woah, $60 is cheap as far as GH is concerned.
« Reply #21 on: Thu, 10 October 2013, 01:22:47 »
It's cheap as far as anyone is concerned when it comes to custom cases with custom color options.  The last acrylic case I remember seeing was a minimum of $82.
I just want to play around with your design and see if I can make one with wood.  I've been planning on making my own similar to this for a while with wood, but it would be easier to use someone else's design instead of mocking up my own for a prototype.
And with your prices, I'm sure people would flock to it if you ran a GB...after you finished the others of course.
Offline MOZ
  • Busy making stuff
« Reply #22 on: Thu, 10 October 2013, 01:34:53 »
Hahaha. Yes, I know. But with the recent happenings, I am more interested in finishing the designs than having hundreds of guinea pigs.
If you need any help with the design, let me know :D
Offline MOZ
  • Busy making stuff
Re: Methamphantomine - Breaking Bad themed TKL case [UPDATE: 25-03-14]
« Reply #23 on: Tue, 25 March 2014, 17:24:26 »
Updated OP with the completed build.
Now just waiting on Toxic GB to complete and some novelty keycaps.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #24 on: Tue, 25 March 2014, 17:30:15 »
Looks amazing I need one too, well different colors, but it looks awesome. I'd be looking for something to match toxic a little closer and be compatible with Phantom PCB.
Offline Dyslexic
  • All we love we leave behind
« Reply #25 on: Tue, 25 March 2014, 17:35:33 »
Good god, give this man some toxic bros to outfit that thing with. Frigging beautiful, and it's gonna look amazing with the toxic set.
| HHKB Type-S | FC660C Silenced | ReΛlforce 23UB
Offline MOZ
  • Busy making stuff
« Reply #26 on: Tue, 25 March 2014, 17:49:41 »
Using Phantom PCB on this. :)
Re: Methamphantomine - Breaking Bad themed Phantom [UPDATED: 25-03-14]
« Reply #27 on: Tue, 25 March 2014, 19:07:38 »
I AM THE ONE WHO THOCKS
Offline Pacifist
  • on hiatus
« Reply #28 on: Tue, 25 March 2014, 19:11:42 »
I need to start watching breaking bad and see what the hype is all about
Offline MOZ
  • Busy making stuff
« Reply #29 on: Tue, 25 March 2014, 19:18:50 »
It ain't hype bro, it is pure awesomeness.
Offline Pacifist
  • on hiatus
« Reply #30 on: Tue, 25 March 2014, 20:53:38 »
holy **** it is
1 down a bunch more to go
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #31 on: Wed, 26 March 2014, 06:49:42 »
Awesome work MOZ!
P.S. We need to get that Heisenberg skull and cross bones on a keycap!
Offline MOZ
  • Busy making stuff
« Reply #32 on: Wed, 26 March 2014, 07:36:51 »
Yes we do.
Offline chibishin
  • sittin around all day listening to classical music
« Reply #33 on: Wed, 26 March 2014, 11:40:50 »
okay yeah that's pretty hot
Offline MOZ
  • Busy making stuff
« Reply #34 on: Wed, 02 April 2014, 16:26:35 »
Which one looks best?
Or something else?
Offline FreeCopy
« Reply #35 on: Wed, 02 April 2014, 16:40:18 »
Or something else?
Damn this is a nice board! Fantastic work MOZ.
These examples here I like the 3rd one myself. I like the steps from blue to stripe to esc.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline MOZ
  • Busy making stuff
« Reply #36 on: Wed, 02 April 2014, 16:47:15 »
Yeah, I'm leaning towards that myself, but I just feel it is lacking a little bit of toxic. I was thinking of adding toxic arrows, but that would be too much going on in that area.
Offline FreeCopy
« Reply #37 on: Wed, 02 April 2014, 16:50:09 »
Maybe full toxic with nontoxic stripe?
Keyboards
Offline MOZ
  • Busy making stuff
« Reply #38 on: Wed, 02 April 2014, 16:51:38 »
Too much toxic kills it.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #39 on: Wed, 02 April 2014, 16:52:34 »
97% pure.
Offline FreeCopy
« Reply #40 on: Wed, 02 April 2014, 16:54:55 »
Haha, that statement makes sense. I guess it would be too bright. I like the subtlety of just the stripe myself.
Keyboards
Offline MOZ
  • Busy making stuff
« Reply #41 on: Wed, 02 April 2014, 17:01:17 »
I think this looks best
Offline Pacifist
  • on hiatus
« Reply #42 on: Wed, 02 April 2014, 17:03:49 »
put br above the up arrow
Offline FreeCopy
« Reply #43 on: Wed, 02 April 2014, 17:05:08 »
That's pretty good. Kind of follows the brokenness of the green and blue br/ba. I like seeing these mockups. Helping me to visualize what I might do with mine.
Keyboards
Offline whiskytango
  • Don't touch the trim
« Reply #44 on: Wed, 02 April 2014, 18:15:53 »
I thought I would like having the whole right side of my phantom full like that, but I have found over the last week that I don't like it much. I'm thinking of going with some of the SP e-sports caps in those 5 extra spots since they look low profile.
Offline MOZ
  • Busy making stuff
« Reply #45 on: Wed, 02 April 2014, 18:22:08 »
I've been using my Phantom for a few days now and I am liking it, I just need to make changes to the firmware so that the scroll lock LED lights up when on another layer besides the default.
Offline whiskytango
« Reply #46 on: Wed, 02 April 2014, 18:24:23 »
That would be a cool feature. Let me know if you figure that out.
By the way phantom looks good! It's unique
