Author Topic: KMAC happy block accessories  (Read 2392 times)
Offline acantha
  • Aure Entuluva
« on: Sat, 12 October 2013, 13:32:04 »
I just bought a KMAC happy off the classifieds (woo!) and I want to install the blocks to make it look like a HHKB. From a bit of investigation it looks like I have to desolder the switch from the pcb then screw the block to the plate. Just wanted to check before I do that I'm understanding it. Don't wanna mangle the board
Thanks.
All the Happy Hacking Things
Re: KMAC happy block accessories
« Reply #1 on: Sat, 12 October 2013, 13:37:51 »
I haven't done this before, so someone please correct me if I'm wrong..
You'll have to desolder the switch for sure. I think you place the blocker into the switch hole on the plate and then screw it onto the PCB, not the plate.
Offline meiosis
  • Time
« Reply #2 on: Sat, 12 October 2013, 14:50:27 »
pretty much this, but you don't screw it in persay it just sits in there so you can't flip your keyboard or else it falls out o-o
Keyboards:
Aripeko TKL
Offline BliTzKiN
« Reply #3 on: Sun, 13 October 2013, 05:00:35 »
Really? I had always thought they were screwed in, you would think with all the work they put into to initial design that they would do something fixed for these key blockers.
If this is true then I'm properly disappointed :( I was planning on getting one as well and this could just be the deal breaker
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #4 on: Sun, 13 October 2013, 05:05:24 »
+1
Offline kaiserreich
  • HHKB Elite
« Reply #5 on: Sun, 13 October 2013, 05:22:05 »
They are screwed on
Offline longweight
  • philanthropist
« Reply #6 on: Sun, 13 October 2013, 05:34:33 »
Is the KMAC Happy available with a one piece HHKB style top cover?
Offline meiosis
  • Time
« Reply #7 on: Sun, 13 October 2013, 05:58:18 »
No idea, I believe the HHKB format also comes without blockers where its a solid piece of metal. KMAC 2 has drop in.
Keyboards:
Aripeko TKL
