Author Topic: Kishsaver Club  (Read 910011 times)
Offline Parak
Re: Kishsaver Club
« Reply #250 on: Fri, 13 June 2014, 11:01:42 »
I gave up on the spacers.  The case is still tight without them and I have not noticed any problems.  I think they mainly serve to line up the keyboard assembly with the case when you screw them together, but it seems the keyboard will be fine without them.  The assembled keyboard is still tight and sturdy during use without the spacers.
The spacers are actually there to make sure that there isn't too much pressure on the top plate. If you notice, the curve of the case actually presses into the top plate as it's screwed in, so there's a risk of damage to barrels or pcb if it's screwed down too much.
Offline vivalarevolución
Re: Kishsaver Club
« Reply #251 on: Fri, 13 June 2014, 11:11:47 »
Interesting.  I may fashion some sort of temporary replacement with some firm foam in the meantime just as a precautionary measure.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Kishsaver Club
« Reply #252 on: Tue, 17 June 2014, 12:32:21 »
Okay, now I need to convert this to HHKB layout. Things that need to change:
split left shift => full size
full size right shift => short right shfit + fn
split enter => full size
backspace => split
I believe all this is possible but I don't know how to get started. Can someone point me towards a good resource?
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Kishsaver Club
« Reply #253 on: Tue, 17 June 2014, 12:35:10 »
So I got around to stripping the paint off my Kishsaver, sanding it down, and spraying on a clearcoat.  I probably will keep this bare metal look, even with some of deep scratches from the paint chipper and wire brush that I did not bother to remove.  It will match all my kitchen appliances:
Looking good, I'm doing the same thing. But I'm going to try to sand it in one direction to get that brushed metal look.
ermahgerd you guys quit copying my idea.
If only I wasn't so lazy.  :blank:
Re: Kishsaver Club
« Reply #254 on: Tue, 17 June 2014, 12:38:07 »
Step 1) Unscrew the screws to separate the the case halves.
Step 2) Remove the back and unscrew the 4 screws holding the plate/hammers/caps to the top of the case
Step 3) Remove the screw holding on the PCBs at the top
Step 4) Carefully bend the tab near the screw that holds in the PCB
Step 5) Remove the plate/hammers/caps assembly
From here it's a bit tricky. I couldn't remove the plate from the assembly without a hammer so I couldn't do what phosphorglow shows in his video. He removes the plate then tapes the hammers on a piece of tape, one per row, so the hammers don't all fall out. I did it the hard way. Put the assembly on the side, got the plate off, then all the hammers fell out and it was a PITA to reseat them all. You can try putting the assembly face down, removing the plate, and then taping the hammers them pulling them out. Watch his video if you're not sure what I'm talking about.
Once the plate is removed, you can move the hammers around to accomidate the layout you would like. When you're done, do everything in reverse. It's not too hard. If you don't drop all the hammers out, it's a fairly quick mod.
If you have more questions, I can take pictures.
Re: Kishsaver Club
« Reply #255 on: Tue, 17 June 2014, 12:39:32 »
seriously, don't let the hammers drop
  • Cherry Peasant
  • keycult.com
Re: Kishsaver Club
« Reply #256 on: Tue, 17 June 2014, 12:41:26 »
So, to summarize: Don't drop the hammers. Move some of the around.
Got it :thumb:
Re: Kishsaver Club
« Reply #257 on: Tue, 17 June 2014, 12:42:18 »
I spent....three nights(?) trying to reseat those ****ing hammers 'cause i'm a klutz :(. IT'S VERY IMPORTANT, NO DROPPING HAMMERS. I recommending trying to do it phosphorglow style to save yourself the frustration.
Got it :thumb:
Yup, you got it.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Kishsaver Club
« Reply #258 on: Tue, 17 June 2014, 13:54:18 »
This is a club I need to be a part of :eek:
Offline MTManiac
Re: Kishsaver Club
« Reply #259 on: Tue, 17 June 2014, 17:11:08 »
I don't want to let the hammer drop let alone multiple hammers?!? where do I find this video?
Offline sleepy916
Re: Kishsaver Club
« Reply #260 on: Tue, 17 June 2014, 17:53:43 »
That is why you bought me a drink! to steal my kish ideas..  :))
Re: Kishsaver Club
« Reply #261 on: Tue, 17 June 2014, 18:47:07 »
Got it :thumb:
TBH, I modified my layout (removed a few hammers and did something similar to what you're doing - turned it into a more standard layout), and it was actually quite simple.  If you just remember to always keep it upside down so you don't lose hammers you should be good.
Actually, I'll be taking mine apart soon to clean glass shards out of it, so if you think you would benefit from a video I'd be happy to put something together.
  • Cherry Peasant
  • keycult.com
Re: Kishsaver Club
« Reply #262 on: Tue, 17 June 2014, 18:49:12 »
Got it :thumb:
I actually did it earlier today and it wasn't so bad :). I just gave everything a thorough cleaning. Some of the hammers aren't seated quite right and don't click correctly though, but I'll fix that when I take it apart again to install my controller when it arrives.
Re: Kishsaver Club
« Reply #263 on: Tue, 17 June 2014, 18:53:58 »
Got it :thumb:
Oh, nice.  :)  Also, you probably already realized this, but just in case not: I had a bunch of trouble getting the caps to seat on the springs properly.  I basically had to have the board propped up at a 90 degree angle, on its back, to get the springs to "relax" so as to allow me to put the caps on the right way.  Without doing that, they wouldn't click, or really work at all.  Maybe that's causing it?  If not, then yeah you'll have to re-seat them.  :)
  • Cherry Peasant
  • keycult.com
Re: Kishsaver Club
« Reply #264 on: Tue, 17 June 2014, 19:05:19 »
Got it :thumb:
I appreciate the tips :). I happened to know that one already and I think that the hammers aren't seated quite right, but I'll make sure first.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Kishsaver Club
« Reply #265 on: Tue, 17 June 2014, 19:12:01 »
So much did you guys have to shell out for yours?
Re: Kishsaver Club
« Reply #266 on: Tue, 17 June 2014, 19:20:32 »
I think it was on the order of $130 to get the board sent to CPTBadAss, and then another $17 or so from him to me.  But the first number (the important one, I know  :P  ) is a guess as I can't find the paypal transaction to confirm it.   :-X
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Kishsaver Club
« Reply #267 on: Tue, 17 June 2014, 20:10:43 »
Wow that's not even that bad  :)
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #268 on: Tue, 17 June 2014, 20:15:05 »
It's a bit painful after you figure in powder coating, new keycaps, and a controller for it.  :-X
Although I doubt everyone is going to powder coat theirs as well as replace the keycaps.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Kishsaver Club
« Reply #269 on: Tue, 17 June 2014, 20:17:02 »
Yeah, a Kishsaver would definitely be an "all in" project.
Re: Kishsaver Club
« Reply #270 on: Tue, 17 June 2014, 20:37:10 »
It was $84 for the board and $36.50 for shipping from HK. Then $17.30 for shipping within CONUS from me to the buyer.
This is the phosphorglow video I was referring to.
Offline hwood34
  • underwater squad
  • #1 CL stan
Re: Kishsaver Club
« Reply #271 on: Tue, 17 June 2014, 20:38:08 »
Even better ;D
Offline Techno Trousers
  • ʘ_ಠ
Re: Kishsaver Club
« Reply #272 on: Tue, 17 June 2014, 22:19:48 »
I think the important thing about the price is that these are a precious resource with a miniscule supply. I had to spend over $200 for mine a couple of months ago, but I still feel lucky to have gotten one since I missed out on the original GB. It's not like there will ever be more of these made.
Personally, I value mine much more than I would any Korean custom.
Offline newchemicals
Re: Kishsaver Club
« Reply #273 on: Thu, 19 June 2014, 01:18:42 »
Now that is how I would like my keyboard to look like. Very sweet looking prdlm.  :thumb:
Offline phosphorglow
  • Model M Mechanic.
    • Phosphor Glow
Re: Kishsaver Club
« Reply #274 on: Thu, 19 June 2014, 12:25:55 »
That is absolutely gorgeous!!!
  • Cherry Peasant
  • keycult.com
Kishsaver Club
« Reply #275 on: Sat, 12 July 2014, 10:33:00 »
Potato, toe for scale
Offline mashby
  • What Up Shoney? (ツ)_/Ż
    • Mashby
Re: Kishsaver Club
« Reply #276 on: Sat, 12 July 2014, 12:12:47 »
Very clean riotonthebay. Nicely done sir!
  • Cherry Peasant
  • keycult.com
Re: Kishsaver Club
« Reply #277 on: Sat, 12 July 2014, 12:20:12 »
Thanks mashby :)
There's a few things that need to be changed/fixed still:
- The flippers on 8* and a need to be replaced.
- The right shift is sitting funny. Not totally sure what to do to fix that.
- I'm also not entirely sure how the spacebar is supposed to be stabilized. The wire is thicker than can fit in the inserts that are already in the plate – are other people making their own inserts or doing something else entirely?
- Unicomp's dyesub QC is really bad. I ordered an APL set and one of the 1.5u Alt and 1.5u Ctrl were aligned very poorly. I asked for replacements, specifying '1.5unit "Alt" from APL set' and '1.5unit "Ctrl" from APL set' and I received the Option/Alt key pictured and a "Control" key :|. Also the alignment on the Ctrl in the caps lock position is messed up.
All that said, I'm typing on a living dinosaur :D
Re: Kishsaver Club
« Reply #278 on: Sat, 12 July 2014, 16:58:30 »
Thanks mashby :)
I believe this thread has some information on how to make custom wire atabilizers for the Model F.  Wcass made a bunch for Kishsaver owners.  He com led some thin wire with metal tubing so a Model M spacebar could work with Model F inserts.
Offline wcass
Re: Kishsaver Club
« Reply #279 on: Sun, 13 July 2014, 00:35:01 »
If you re-used the insert that came from an ISO Enter or num pad Enter, then you are using a vertical insert (hole is off center) - you want to use a horizontal insert (hole is on center).
That sounds like you got a Model M space bar; these need a stabilizer wire replacement to function properly. At least one other KS came with an M space bar, so you are not alone. I'm out of stainless steel tubing at the moment, but will get some the next time I order from McMaster. PM me your address and i will send one to you.
APL != Apple
Re: Kishsaver Club
« Reply #280 on: Sun, 13 July 2014, 03:07:00 »
Call me strange, but I prefer the full touch keys, like Alt and Ctrl.  Exception permitted for Caps Lock, except you have Ctrl on there, ;D
Re: Kishsaver Club
« Reply #281 on: Sun, 13 July 2014, 06:44:57 »
You're strange.
Offline sleepy916
Re: Kishsaver Club
« Reply #282 on: Sun, 13 July 2014, 22:36:53 »
Just the top half, it still needs some work. The bottom half still has a lot of spaces I need to get to.
From this:
To this:
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #283 on: Sun, 13 July 2014, 23:01:40 »
I just need to get some of those little white plastic stabilizer inserts so I can assemble the board first(To make it ansi). It's all apart and I don't want anything to happen to it. Then I need the converter as well ;_;
Has anyone ordered a pack of 3 PCBs from oshpark yet?
Offline mashby
    • Mashby
Re: Kishsaver Club
« Reply #284 on: Mon, 14 July 2014, 10:06:22 »
From this:
To this:
Looks great Sleepy! What did you use to remove the paint?
Offline sleepy916
Re: Kishsaver Club
« Reply #285 on: Mon, 14 July 2014, 11:46:37 »
From this:
To this:
I used this, it has worked really well.
Re: Kishsaver Club
« Reply #286 on: Mon, 14 July 2014, 13:47:40 »
From this:
To this:
Did you use any other tools to remove the paint, like a paint scraper and such?
Offline sleepy916
Re: Kishsaver Club
« Reply #287 on: Mon, 14 July 2014, 15:46:55 »
From this:
To this:
After you spray the paint remover, the paint gets a bubbly and is easy to remove. But I used an old box cutter to scrape off the paint. It didn't scratch the metal too much. I used the right end piece in the picture where it is rounded. I'm sure you can use pretty much anything, the paint comes off really easy.
Offline mashby
    • Mashby
Re: Kishsaver Club
« Reply #288 on: Mon, 14 July 2014, 15:51:44 »
I was planning on using my Skrapr, but I think I'll try and find a metal putty knife instead. Don't know that the Skrapr would survive the chemicals.
Offline MTManiac
Re: Kishsaver Club
« Reply #289 on: Wed, 16 July 2014, 09:29:49 »
From this:
To this:
That is freaking awesome!
I knew there had to be an easier way than sanding the poor bugger!
(I'm totally adding this to my shopping list)
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: Kishsaver Club
« Reply #290 on: Wed, 16 July 2014, 11:39:58 »
just have to post this pic also here  ;D
71067-0
  • ʘ_ಠ
Re: Kishsaver Club
« Reply #291 on: Wed, 16 July 2014, 11:47:18 »
You got two! And going for the Darth Vader look? Do you have white on black caps to complete it?
Offline snoopy
  • The Flying Ace
Re: Kishsaver Club
« Reply #292 on: Wed, 16 July 2014, 11:59:43 »
one will become blank black keycaps... the other one... i don't know yet.
btw, it looks black on the pics. But it is a dark grey. :)
Re: Kishsaver Club
« Reply #293 on: Wed, 16 July 2014, 12:08:21 »
Pretty sure this is the cleanest case I've ever seen very nice bro!
Offline JPG
  • Model F is my new passion!
Re: Kishsaver Club
« Reply #294 on: Wed, 16 July 2014, 12:10:33 »
Just WOW!
Re: Kishsaver Club
« Reply #295 on: Wed, 16 July 2014, 12:17:48 »
Sexy time. Looking forward to the final product. You've got a nice BS Clack collection too for that little extra touch on top of the case and whatever keycaps you use :D.
Offline MTManiac
Re: Kishsaver Club
« Reply #296 on: Wed, 16 July 2014, 12:43:40 »
hmmm you make me want to take mine down to a local powder coating shop...
wonder if they have jdcarpurple  :cool:
Re: Kishsaver Club
« Reply #297 on: Wed, 16 July 2014, 16:27:33 »
From this:
To this:
Awesome.  The paint remover and scraper that I used required a lot of elbow grease, and I wondered  how you were able to remove the paint so cleanly without any deep scratches.
Re: Kishsaver Club
« Reply #298 on: Wed, 16 July 2014, 16:28:17 »
Gorgeous.
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #299 on: Mon, 11 August 2014, 20:05:27 »
Ok, I am probably going to throw in an order to unicomp in the next few days to get keycaps for this thing. I am converting it to a standard layout and I was wondering, how many little stabilizer inserts am I going to need in total?
I am ordering the following items, tell me if I am grabbing the right stuff.
101 Pearl/Pebble Set
Large Pearl Spacebar
2 Unprinted Pebble 1x Keys
