Author Topic: Kishsaver Club  (Read 910004 times)
Offline Parak
Re: Kishsaver Club
« Reply #150 on: Sat, 08 March 2014, 17:15:44 »
I took it completely apart today, partly because my Q key was acting up and I am going to see what was wrong, when I press it, it makes this odd sound, first 3 presses are a normal switch, and the last 3 are the Q key. What could be wrong?
https://soundcloud.com/user343835333/kishsaver-spring-problem
That can happen if the barrel/flippy/sping/key are somehow not seated correctly. It may be that the barrel is too loose due to insufficient foam, or that the flippy is out of alignment, or that the spring is not inserted on the flippy fully, etc.
My PCB is dusty, anything I should know about cleaning this thing? Proper way of doing it?
I just use isopropyl, just be careful of any exposed traces - those are not common, but should be protected with some clear nail polish on a budget, or chemtronics overcoat if not.
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #151 on: Sat, 08 March 2014, 17:53:16 »
I guess it could have been the barrel and spring not being alighted, I will find out once it is put back together. I will probably clean the PCB tomorrow, I can probably get away with lightly dusting it.
As for the barrels and springs, any ibm experts want to shed light on why the barrels are labeled G(random #) and the springs are labeled (random #)E? Some of them have the same numbers, but most dont, I was just interested in finding out.
Offline wcass
Re: Kishsaver Club
« Reply #152 on: Sun, 09 March 2014, 23:37:48 »
I tweaked the label slightly. Replaced the dot matrix font with one I made and made the logo slightly larger. Both changes to more closely match the original. I have not printed them on the label stock yet, but it should look like the picture below. I still have three more spots is anyone wants one.
56988-0
Re: Kishsaver Club
« Reply #153 on: Tue, 18 March 2014, 12:18:29 »
I'd like a label. I'll post a picture of my sticker later today if that works for you wcass?
Wcass, I'd be interested in a wire spacebar adapter that fits a Model M spacebar to a Model F body. And one of the logos. However, I'm traveling right now. Can we talk when I'm back? I tend to lose PMs when I'm on Tapatalk/my phone :(.
And is my request part of the 16 you spoke of earlier? I'd still really like an adapter. :D
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Kishsaver Club
« Reply #154 on: Tue, 18 March 2014, 12:30:35 »
Looks awesome!
Offline wcass
Re: Kishsaver Club
« Reply #155 on: Tue, 18 March 2014, 20:43:29 »
Wcass, I'd be interested in a wire spacebar adapter that fits a Model M spacebar to a Model F body. And one of the logos. However, I'm traveling right now. Can we talk when I'm back? I tend to lose PMs when I'm on Tapatalk/my phone :( .
Sorry CPT. I lost you in the mix. I would be happy to send you a PDF with embedded fonts of your label that you can print yourself on a label sheet. You can order a single sheet of label from www.labelsbythesheet.com for about $5 including delivery. this looks just like the stock silver label.
Rant at USPS hidden below.
I used all of the 15th to print the labels, box everything up, and get it mailed out. I wanted to reduce the chance that a label or stabilizer would get bent in shipping to as close to zero as possible, so I put everything in plastic RAM boxes and put those into 15 cardboard boxes. I took it down to the post office and the lady at the desk said, "you can't use those boxes!"
See i had cut up some Priority Mail boxes to make my boxes - which is a mortal sin apparently. She would not accept them as they were. So I spend another couple of hours Sunday wrapping the 15 packages like Christmas presents making sure that no one can tell what the box is made of. On Monday I stop at the PO on my way to work - it is the same woman behind the desk, but i feel confident that the boxes can not be identified. Ah, but she knows that i just wrapped the same boxes i had before, so she again refuses to accept the boxes.
I told all this to my wife and she has graciously volunteered to take the boxes to a different post office tomorrow. She is handicapped, so it is very much an inconvenience for her, but hopefully it will improve the chance that these will be accepted for delivery.
The same goes for anyone that wants a label (I make replicas of other labels too). I'ld be happy to do the art, but would prefer you do the actual printing.
« Last Edit: Sun, 23 March 2014, 10:06:40 by wcass »
Re: Kishsaver Club
« Reply #156 on: Tue, 18 March 2014, 21:20:07 »
No worries wcass, I don't mind printing myself. The adapters are still fine though right?
Offline wcass
Re: Kishsaver Club
« Reply #157 on: Tue, 18 March 2014, 22:46:18 »
A close up of my new label. The case is Rustoleum hammered bronze.
57919-0
Offline Photoelectric
Re: Kishsaver Club
« Reply #158 on: Tue, 18 March 2014, 23:17:21 »
Nice  :thumb:  Rust-Oleum has some great colors in the Hammered and Universal lines.
Offline wcass
Re: Kishsaver Club
« Reply #159 on: Wed, 19 March 2014, 11:46:18 »
For putting the switch assembly together, I use a box with a big hole for the barrels. The box also doubles as a place to store caps, barrels, and other parts.
57972-0
I use a slightly different "clamp" than other folks to hold the plates together ...
57970-1
They clamp tight enough to keep the plates together, but loose enough to allow the front and back to slide easily. If you try this, I would suggest using electrical tape inside the "jaws" to prevent scratches.
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #160 on: Wed, 19 March 2014, 12:34:47 »
So, I hunted down that company, they moved to a new location, changed their name and got a new website. They told me they estimate $100-125 to blast, mask off the inside of the keyboard, and powder coat it. Does this seem reasonable? I haven't ever had something powder coated and I have no clue what it should cost, I was initially expecting something like $80.
Re: Kishsaver Club
« Reply #161 on: Thu, 20 March 2014, 09:25:12 »
I think that's about the pricing from mkawa's powder coater. You might want to PM him to verify the costs.
Offline wcass
Re: Kishsaver Club
« Reply #162 on: Sun, 23 March 2014, 09:56:22 »
Has anyone done a 3D model of the  rubber feet or that plastic spacer between the top cover and key assembly?
Offline vivalarevolución
Re: Kishsaver Club
« Reply #163 on: Sun, 23 March 2014, 11:06:57 »
Label arrived Saturday.  Looks great.  Thank, wcass.
On another note, for case re-painting, did anybody just paint over the existing paint? Or did you scrape off the existing paint, and then add another layer?  I'm wondering how hard it will be to scrape off all the existing paint, and maybe what I could use to do so.
Offline Michael
  • Formerly Bro Caps
Re: Kishsaver Club
« Reply #164 on: Sun, 23 March 2014, 11:29:13 »
I plan to have it sand blasted off. It's a lot cleaner than most methods. Also, depending on the grain you use, it leaves a nice texture (if you like that) for the new paint. Also, less chance to damage the case.
« Last Edit: Sun, 23 March 2014, 12:47:23 by Bro Caps »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: Kishsaver Club
« Reply #165 on: Sun, 23 March 2014, 11:58:45 »
JWaZ schooled me on the provenance and availability of the Kishavers.   :'(
However, if a Club Member hears of a way I could gain one and join, I would be very grateful.  And I have many interesting things to be grateful with!
Anyhow, please accept my application to be a Kishsaver Club "Member in Waiting".
 -  Ron | samwisekoi
p.s.  jdcarpe, if you are serious, I am interested!
Offline wcass
Re: Kishsaver Club
« Reply #166 on: Sun, 23 March 2014, 13:20:57 »
Great to hear.
I stripped paint using stuff i got at the Home Depot; Klean Strip Premium Stripper 15 minute paste, 1" plastic paint scraper, 1" chip brush. The paint came off very easy. I was tempted to just clear-coat it - the bare metal looked so nice.
Re: Kishsaver Club
« Reply #167 on: Sun, 23 March 2014, 15:44:53 »
Great to hear.
Thanks.  That does not sound too complex, but could get messy.  Sandblasting would be ideal, but getting access to one is a bit of a difficulty.
Re: Kishsaver Club
« Reply #168 on: Sun, 23 March 2014, 20:01:19 »
I've received my labels today.  :)  Thanks once again wcass for all the effort you put into making those for everyone, it's much appreciated.
Now to get this case repainted and everything cleaned up!
Offline wcass
Re: Kishsaver Club
« Reply #169 on: Mon, 24 March 2014, 16:35:19 »
I changed a few keys, but the nav cluster will not work right until i get a replacement controller.
58616-0
58614-1
Re: Kishsaver Club
« Reply #170 on: Mon, 24 March 2014, 16:41:07 »
It's delicious!  Great job!
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Kishsaver Club
« Reply #171 on: Mon, 24 March 2014, 16:42:03 »
Wow... That is just stunning. Probably one of my favorite and cleanest keyboards on here in my opinion.
Offline tbc
Re: Kishsaver Club
« Reply #172 on: Tue, 25 March 2014, 01:05:19 »
honestly, this is the best 'club' on geekhack by far.  before I even knew the cases were metal.
Offline mashby
    • Mashby
Re: Kishsaver Club
« Reply #173 on: Tue, 25 March 2014, 16:00:45 »
FOR THE LOVE OF ALL THAT'S HOLY, WCASS!!!!!!  :eek: THESE STICKERS LOOK AMAZING  :eek:
*Ahem* err.. I mean, well done sir. Very well done and thank you for making these for us.
Re: Kishsaver Club
« Reply #174 on: Tue, 25 March 2014, 16:03:38 »
My thoughts exactly!!  I was expecting a single gold sticker, not silver + gold & IBM logos!  wcass went above and beyond the call of duty, by far.
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #175 on: Tue, 25 March 2014, 16:14:44 »
Got mine today as well, thank you so much wcass! This is awesome  :thumb:
Offline Michael
  • Formerly Bro Caps
Re: Kishsaver Club
« Reply #176 on: Tue, 25 March 2014, 16:19:00 »
There's one in classifieds :P
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #177 on: Tue, 25 March 2014, 16:25:22 »
samwisekoi might be interested :)
:( because you are getting rid of yours though
Offline wcass
Re: Kishsaver Club
« Reply #178 on: Tue, 25 March 2014, 18:37:03 »
I guess you missed the late night TV infomercial.
... but wait. If you act now, I'll triple your order. Not only will you get the super amazing Kishsaver label in luxurious polished gold with painstakingly recreated font and logos - but also two additional labels; one in high reflectivity polished silver and the other in water resistant brushed silver. AND IF YOU ACT NOW - I'll throw in FOUR logo stickers at NO ADDITIONAL COST!
Making these really was a lot of fun for me.
Offline sleepy916
Re: Kishsaver Club
« Reply #179 on: Tue, 25 March 2014, 18:49:49 »
I just got mine today, thank you very much wcass!
Offline E TwentyNine
    • Some of My Keyboards
Re: Kishsaver Club
« Reply #180 on: Tue, 25 March 2014, 18:50:02 »
The generosity on your part is absolutely awesome.   I don't even have a Kishsaver but was entertaining to see the reactions of those who do.
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #181 on: Tue, 25 March 2014, 18:51:19 »
Sounds about right, once I saw mashbys post I had to run to the mailbox :P
The brushed one is so sexy.
Offline Monster-Toys
Re: Kishsaver Club
« Reply #182 on: Tue, 25 March 2014, 20:31:06 »
I could make them tomorrow if you want (with autocad and or inventor, accurate to ca. 0,3 mm)  but i only have an educational licences (what should be ok, because it is not for commercial use). Just let me know (and what is the prefered file-format).
Offline tinlong117
Re: Kishsaver Club
« Reply #183 on: Wed, 26 March 2014, 09:30:58 »
nvm
« Last Edit: Wed, 26 March 2014, 09:43:37 by tinlong117 »
Offline ComradeSniper
  • HHKB Pro
Re: Kishsaver Club
« Reply #184 on: Thu, 27 March 2014, 18:25:37 »
Just out of curiosity, how much did these originally sell for (from tinlong)?
I need one  :'(
Offline Pacifist
  • on hiatus
Re: Kishsaver Club
« Reply #185 on: Thu, 27 March 2014, 18:27:39 »
I need one  :'(
$159 i think
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #186 on: Thu, 27 March 2014, 18:30:11 »
About 150 after all the shipping and such. A steal imo.
Re: Kishsaver Club
« Reply #187 on: Thu, 27 March 2014, 18:36:46 »
I should have joined :(  Stupid finances made me hesitate.
Offline tinlong117
Re: Kishsaver Club
« Reply #188 on: Thu, 27 March 2014, 21:44:44 »
I need one  :'(
80+35+shippping in the states.
Yet someone still said I taken advantage.
I will give you one if I can be your bf.  :eek:
« Last Edit: Thu, 27 March 2014, 21:48:41 by tinlong117 »
Offline Pacifist
  • on hiatus
Re: Kishsaver Club
« Reply #189 on: Thu, 27 March 2014, 21:58:35 »
tinnie don't you already have a gf?
Offline Michael
  • Formerly Bro Caps
Re: Kishsaver Club
« Reply #190 on: Thu, 27 March 2014, 22:01:04 »
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #191 on: Thu, 27 March 2014, 22:03:35 »
Offline Techno Trousers
  • ʘ_ಠ
Re: Kishsaver Club
« Reply #192 on: Thu, 27 March 2014, 22:47:34 »
Just to go on the record, I would also like to be in the club one day. I already have experience restoring an F-122, so any potential seller can rest assured that I would give their kishsaver a good home.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Kishsaver Club
« Reply #193 on: Thu, 27 March 2014, 22:53:12 »
Weird... they seem to be much more expensive in the classifieds these days...
Re: Kishsaver Club
« Reply #194 on: Thu, 27 March 2014, 22:59:55 »
Shipping in the states was about $18.
Offline HPE1000
  • Keycap Paparazzo
Re: Kishsaver Club
« Reply #195 on: Fri, 28 March 2014, 10:34:24 »
Everybody seems to be selling theirs, is there something I don't know about?  :-X
How close are the converters to being done btw?
Re: Kishsaver Club
« Reply #196 on: Fri, 28 March 2014, 10:36:20 »
People are just needing money, and have too many projects I think.
There is a working converter, but the replacement controller is still being tested.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Kishsaver Club
« Reply #197 on: Fri, 28 March 2014, 10:36:27 »
Just a chain reaction :). One person sells because they realize they don't have time for it, then someone else realizes they're in the same boat, etc.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Kishsaver Club
« Reply #198 on: Fri, 28 March 2014, 10:54:23 »
riot is right,  I think many of us jumped at the occasion when tinlong sold them,  however after receiving them and having it for a couple of months the realizing that we just don't time.
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: Kishsaver Club
« Reply #199 on: Fri, 28 March 2014, 10:57:32 »
im similar to that, even if i found time to get it up and going, id never use it, but was too cool of an opportunity not to jump on
