Author Topic: Make a 2 key keyboard?  (Read 55064 times)
Offline Coreda
Re: Make a 2 key keyboard?
« Reply #100 on: Wed, 22 January 2014, 02:02:11 »
This is epic lol! A little tricked-out 2-keyer. I probably missed it, but what keys will it be?
Offline YoungMichael88
  • HHKB Wannabe
« Reply #101 on: Wed, 22 January 2014, 02:43:29 »
Oh if this was Bluetooth I could use it as record / return and track drums way easier in protools!! A four key Bluetooth version would be really really usefull for recording.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #102 on: Wed, 22 January 2014, 12:18:39 »
Are diodes even necessary? I mean... obviously you aren't going to get more than 2KRO on this.
Anyway, I'm still down for offering these in a groupbuy. I can include it next time I do some novelty key dyesubs with imsto which will probably be soonish.
« Last Edit: Wed, 22 January 2014, 12:20:44 by IvanIvanovich »
« Reply #103 on: Wed, 22 January 2014, 12:37:42 »
I lol'ed. :D
NKRO where N=2
Offline Tranquilite
« Reply #104 on: Wed, 22 January 2014, 12:48:14 »
This has already been brought up in this thread, but this is almost exactly what you are describing. You can hook any kind of switch (including mx switches) up to those 12 inputs and configure them to send any mouse, media or keystroke.
Offline regack
« Reply #105 on: Wed, 22 January 2014, 15:47:30 »
I lol'ed. :D
NKRO where N=2
:P
Still need the zener diodes to get the usb data line voltage down, but the others could be probably be ignored for some minor savings.  Pads could be bridged with a bit of wire or something if you want to leave them out.
  • HHKB Wannabe
« Reply #106 on: Wed, 22 January 2014, 15:56:49 »
I think if anything, this 2 key PCB should be overkill.
« Reply #107 on: Wed, 22 January 2014, 16:04:22 »
The best way :D
Offline regack
« Reply #108 on: Wed, 22 January 2014, 16:16:20 »
You're probably right, but it would be hard to find a place to mount the USB otherwise.  Honestly, the whole concept is ridiculous, but I'm having some fun with it.
Anyway, all the parts to build one (PCB, usb, switches, resistors, caps, diodes, LEDs) cost me ~$8.  It would go down in quantities of more than 1-at-a-time.
If you wanted to build a bluetooth one based on the lady ada's bluefruit, you'd probably just wire up the switches directly and go with a little two-switch plate in lieu of the PCB.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #109 on: Thu, 23 January 2014, 18:51:49 »
make a micro-plate that has a loop on it, doubles as keychain
i wish you could have it type something when you press a key like the techkeys thing, but this is still cool
Offline kfmfe04
« Reply #110 on: Thu, 23 January 2014, 18:58:22 »
0 1
⌨White Blank HHKB P2 ⌨Filco TKL SA MXRed
Interests: ⌨AcidFire's Board ⌨Kinesis Advantage LF
« Reply #111 on: Thu, 23 January 2014, 19:41:32 »
0 1
dit dah
« Reply #112 on: Thu, 23 January 2014, 20:35:50 »
One has to be the Any key.  The other one?
« Reply #113 on: Thu, 23 January 2014, 22:39:30 »
1 A
it's the 1a keyboard
  • HHKB Wannabe
« Reply #114 on: Thu, 23 January 2014, 23:51:07 »
1 A
That would make too much sense
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #115 on: Fri, 24 January 2014, 00:30:38 »
WANT! :D
A Ghost From The Past
Offline Photoelectric
« Reply #116 on: Fri, 24 January 2014, 01:07:36 »
"G" and "H".
Looking good already!
« Reply #117 on: Fri, 24 January 2014, 03:28:24 »
Offline BlueBär
« Reply #118 on: Fri, 24 January 2014, 03:35:33 »
Will there be an ISO version?
« Reply #119 on: Fri, 24 January 2014, 03:37:20 »
:confused:
Next thing you know, someone will want Dvorak layout!
Offline BlueBär
« Reply #120 on: Fri, 24 January 2014, 03:38:29 »
What about a split design for better ergonomics?
Offline McWilloughby
« Reply #121 on: Fri, 24 January 2014, 06:06:42 »
ErgoDuoTM
« Reply #122 on: Fri, 24 January 2014, 13:22:14 »
It's the DUKE OF NEW YORK keyboard!
Offline HPE1000
  • Keycap Paparazzo
« Reply #123 on: Sat, 25 January 2014, 17:41:13 »
I know it's not really the thread for this but I would just love to see a programmable ~5-10 key board to use as a media controller. People could use it for play, pause, track forward, track backward, random, maybe volume down and up.
« Reply #124 on: Sat, 25 January 2014, 17:57:13 »
I wouldn't mind something like that either... maybe make PCB that fit inside the CM switch tester... nice easy project.
« Reply #125 on: Sat, 25 January 2014, 17:58:34 »
Yeah a PCB for the switch tester would be pretty sweet. But first thing's first is the 1a
« Reply #126 on: Sat, 25 January 2014, 19:04:06 »
Offline regack
Offline HPE1000
  • Keycap Paparazzo
« Reply #129 on: Sun, 26 January 2014, 16:04:16 »
You know thanks to this I started playing Osu again. And I'm starting to think I'd have to bolt this thing to my desk in order to be able to play Osu with it.
#intenseapm
Offline BlueBär
« Reply #130 on: Sun, 26 January 2014, 17:08:28 »
No, what you need is a metal case to go with it, that should have enough weight to keep it on your desk.
« Reply #131 on: Sun, 26 January 2014, 17:09:55 »
I think it would still tip over or slide around because of how small it is, and how much I'd be mashing.
Offline BlueBär
« Reply #132 on: Sun, 26 January 2014, 17:26:46 »
Hmm that depends on the size of course. Or maybe some kind of clamping mehcnaism to clamp it onto your desk?
Offline Comment
« Reply #133 on: Sun, 26 January 2014, 18:15:00 »
Lead case. Problem solved.
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
« Reply #134 on: Sun, 26 January 2014, 20:07:26 »
I'll think of something once I get a few ;)
Offline hargon
« Reply #135 on: Tue, 28 January 2014, 04:26:55 »
Please make the PCB available to all of us!
Offline Oobly
« Reply #136 on: Tue, 28 January 2014, 05:02:27 »
Depleted Uranium is denser... Hmm, new keycap material everybody! If you thought thick PBT caps were heavy....
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline moonexe
« Reply #137 on: Tue, 28 January 2014, 06:52:04 »
Solid gold for a safe alternative :rolleyes:
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
Offline Grendel
« Reply #138 on: Tue, 28 January 2014, 12:41:00 »
Tungsten -- about the same density as Gold but cheaper :p
« Last Edit: Tue, 28 January 2014, 12:42:45 by Grendel »
- I'm game !
Offline moonexe
« Reply #139 on: Tue, 28 January 2014, 12:47:27 »
But not as cool.
« Reply #140 on: Tue, 28 January 2014, 22:47:36 »
I'm a'll about the osmium / iridium.
As far as cases, you can fabricate something that's heavy pretty easily (and cheaply). though you may run into height concerns. I plan to bolt mine to some scrap metal and have done.
Offline ebacho
« Reply #141 on: Wed, 29 January 2014, 00:42:32 »
Depending on how much you 2 key and whether you 1 key using your index/middle finger will probably affect how you want to weigh it.  I have a tendency to favor my middle finger for both streams and single taps, at any rate.  BPM will probably affect things too, as well as pcb flex if there's no plate.
« Last Edit: Wed, 29 January 2014, 00:46:15 by ebacho »
Offline regack
« Reply #142 on: Thu, 30 January 2014, 18:31:56 »
I should probably actually test the electronics first, but...
52760-0
52762-1
Offline BlueBär
« Reply #143 on: Thu, 30 January 2014, 18:35:06 »
Very nice! Total cost of the PCB + case?
Offline HPE1000
  • Keycap Paparazzo
« Reply #144 on: Thu, 30 January 2014, 18:38:01 »
Awesome, I could see it being used as an upvote/downvote tool  :)
« Reply #145 on: Thu, 30 January 2014, 18:57:34 »
ROFL nice
Offline regack
« Reply #146 on: Thu, 30 January 2014, 19:18:55 »
The shapeways case was $14.52 shipped.  This is only the second time I've had anything 3d printed before, it might be possible to tweak it cheaper, I don't know.  Might be cheaper to not use shapeways as well.  Not really an area I have a lot of experience with.
As a one-off, the PCB + parts came out to <$8 (inclusive of shipping charges from me buying some bits from mouser).
In quantities of 100, the per-unit price of components goes down to like $2.  I'm not sure about the PCBs, but it's probably pretty low as well.  I was going to get an estimate, but I've been short on time lately and keep forgetting to get to things.
Offline ebacho
« Reply #147 on: Fri, 31 January 2014, 01:23:11 »
Don't have much to add, but if there's ever a group buy I'd be interested in picking up several of these.
« Reply #148 on: Fri, 31 January 2014, 12:16:08 »
Not bad... so perhaps in the groupbuy we can do a kit of case + pcb + 2 PBT dyesub keycap for around $20-22? Unless shapeway does volume pricing, then it would be cheaper? Let me know all the details and I will launch a buy if you don't want to do it.
Offline moonexe
« Reply #149 on: Fri, 31 January 2014, 15:10:09 »
Quote from: Shapeways
Do you offer volume discounts?
Due to the nature of 3D Printing, the price per object does not decrease with larger volumes. As a result, we do not offer volume discounts.
Although if you print several cases in a single file, you could skip the per item setup fee, saving a very small amount per case... But I doubt it would be significant.
« Last Edit: Fri, 31 January 2014, 15:13:40 by moonexe »
