Author Topic: Make a 2 key keyboard?  (Read 55065 times)
Offline FrostyToast
  • Litshoard
Re: Make a 2 key keyboard?
« Reply #150 on: Fri, 31 January 2014, 15:17:23 »
Would it be possible to use a plate and slab to sandwich the pcb in order to make it cheaper? That way you don't have to 3D print and can instead use a CNC.
Quote from: elton5354
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #151 on: Fri, 31 January 2014, 17:21:51 »
|||My other keyboards :
x
Offline WangZi
« Reply #152 on: Sun, 02 February 2014, 08:29:05 »
Nice job regack
Offline regack
« Reply #153 on: Mon, 03 February 2014, 15:16:33 »
The good:
1) The LEDs work... but I'm adding a jumper, because they're always on (unless of course, you don't install them)
53075-0
2) Created a little jig board to aid in programming this thing (which went fine) but now I have to wait for those to show up.
The bad:
1) I need different zener diodes.  The ones I got are 500mW, and they don't seem to be activating with the low current going on here.  I've ordered some replacements, but also had to adjust the footprint down to match (SOD-323).
Offline BlueBär
« Reply #154 on: Mon, 03 February 2014, 15:49:34 »
The good:
The bad:
Maybe make one of the keys a dedicated on/off switch for the LEDs?
« Reply #155 on: Mon, 03 February 2014, 16:54:29 »
Damn... looks awesome though lol. Time to go play some Protoss
« Reply #156 on: Mon, 03 February 2014, 19:04:28 »
The good:
The bad:
Great job man!
Offline BlueByLiquid
« Reply #157 on: Mon, 03 February 2014, 23:43:52 »
Has anyone thought of doing on of these for the CM storm key switch tester? The case is really solid and would make for a cheap option for six keys.
http://www.cmstore-usa.com/mechanical-key-switch-demo-board/
Here is the side profile so you can see the case: http://www.cmstore-usa.com/productimage.php?product_id=659
I was thinking about doing point to point on mine but would rather just but a one off board? Thoughts?
Offline Comment
« Reply #158 on: Mon, 03 February 2014, 23:48:02 »
Whats that case made out of?
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline Grendel
« Reply #159 on: Tue, 04 February 2014, 02:25:36 »
Yea. I did conclude that a board w/ the Teensy hanging underneath would fit and messed around w/ upverter a bit. It should be pretty easy for an EE to do a layout, but being a CE I didn't get far in a reasonable amount of time, so I put it on the back-burner :/ I still have an empty tester, if someone wants to make a layout I could measure the box out and provide a connection list.
« Last Edit: Tue, 04 February 2014, 02:31:56 by Grendel »
- I'm game !
Offline LadyPecs
« Reply #160 on: Tue, 04 February 2014, 16:57:56 »
Oh my that thing is cute. Makes me want to play super hexagon.
« Reply #161 on: Tue, 04 February 2014, 17:53:29 »
Its made of a hard and thick plastic material
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #162 on: Tue, 04 February 2014, 18:30:10 »
4 keys would be nice. as it can be used for dota 2
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
« Reply #163 on: Tue, 04 February 2014, 18:46:39 »
If you play dota with only 4 keys I don't know what to tell you
unless you meant league of lesbians
Offline shrapneL
« Reply #164 on: Tue, 04 February 2014, 19:40:20 »
Ouch
hello.
« Reply #165 on: Wed, 05 February 2014, 01:00:57 »
That looks exactly like was I was looking for. Awesome work! If you can get someone to do the pcb I would buy a small run of the boards. This would be pretty nice I bet we could get it sized to have holes so it would be stabilized by the spikes inside the com storm case and all we would have to do is Dremel the plastic for the USB hole.
Offline neun_sechs_zwei
« Reply #166 on: Mon, 10 February 2014, 21:59:33 »
Got a couple TechKeys cards today... needed something to mount a few switches to for fun. Also wasted too long probably this weekend building the toolchain to flash this thing...
The two-key board is nice!
« Reply #167 on: Tue, 18 February 2014, 09:09:51 »
« Reply #168 on: Tue, 18 February 2014, 09:19:43 »
CNC is not necessarily cheaper.
Offline hargon
« Reply #169 on: Sun, 13 April 2014, 10:08:10 »
I'm curious: Any news? Did you finish it or encounter any new problems?
I'm interested in building something similar as a little project myself. Hopefully you don't mind me using your thread to ask if anyone can check the schematic I have prepared so far. Should this work? Did i do anything wrong?
60883-0
Thanks in advance.
« Reply #170 on: Fri, 09 May 2014, 11:09:56 »
did you make the board? I'm interested.
« Reply #171 on: Fri, 09 May 2014, 23:25:01 »
The boards are done I think it's just regack hasn't had time to play around with the firmware.
