Author Topic: Most highly regarded MX keyboard?  (Read 16777 times)
Re: Most highly regarded MX keyboard?
« Reply #50 on: Thu, 16 January 2014, 21:20:16 »
You can get MX boards with HHKB  layout
Offline kfmfe04
« Reply #51 on: Thu, 16 January 2014, 23:04:26 »
I'd be very interested in this, if someone has cranked out an MX board close to Filco quality, but with a HHKB layout (I still prefer topre, but I need some MX boards to hold all these extra keycaps  :)) ).  Any suggestions?
⌨White Blank HHKB P2 ⌨Filco TKL SA MXRed
Interests: ⌨AcidFire's Board ⌨Kinesis Advantage LF
« Reply #52 on: Thu, 16 January 2014, 23:06:31 »
kmac happy
GH60
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #53 on: Fri, 17 January 2014, 00:53:42 »
a kmac is like a kit to build a classic horse pulled carriage..
The whole concept of the horse drawn cart itself is obsolete and slow as balls..  BUT it's pretty and reminds people of simpler times.
The Egdx on the other hand is like a modern gasoline car..  It's better in everyway.. you may or may not find it aesthetically pleasing, since to most people, it's not what they're used to seeing with respect to the rectangle in front of their computers.
Make no mistake... extended use of classic keyboards inevitably leads to Repetitive stress disorder...
There is no question that this is what's going to happen if you lead a computer-oriented lifestyle..
If you had to dig trenches with a shovel,  vs a tractor...   That is the difference...
tp, your title should be "Ergodox Enforcer"
You're definitely not alone there - I have said something similar before. Also that is ignoring the fact that there's dime-a-dozen more ergonomic keyboards floating out there on the market, plenty more fancy varied shapes and sizes to choose from. When talking about ergonomics, there's plenty of ways to skin a cat - to say ErgoDox is superior to all of the ergonomical keyboard designs out there is really a bold (yet naïve) statement.
Anyway OP, I think your question is too open. For HHKB equivalent in Cherry MX realm (whilst retaining 60% factor) you have KMAC. For μTron keyboard equivalent, you have the likes of Cherry G80-5000 for instance, and so on and so forth.
The reason I ask this and started this thread is because of my concern that one day the HHKB will no longer be available. This scares me as I'm learning this layout and then I'll have to go back to a standard layout.
There will be clones comes the day when there is a need to. Also I think it is mainly the left Control key that gets swapped. There's honestly a fair few 60% boards which look somewhat a little similar to HHKB (minus the left control key being in the same position).
Also, I guess it wouldn't hurt to swap around with other keyboards as well. That is pretty much what I am doing, swapping around with other keyboard so that I can then paint a mental image of the keyboard in my head along with the keys and what not.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline Oobly
Re: Most highly retarded MX keyboard?
« Reply #54 on: Fri, 17 January 2014, 03:18:52 »
Perhaps this:
Or the iOne Scorpius M10 or an older Razer Blackwidow.... Oh wait, you said "regarded", not "retarded"... Oh well.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #55 on: Fri, 17 January 2014, 04:00:15 »
Or thinking about it a different way, if by most highly regarded you would consider one that is most recommended, I have probably seen CM QFR recommended more than almost any other keyboard around here.
Offline Oobly
« Reply #56 on: Fri, 17 January 2014, 04:28:25 »
Nah, that would be most often recommended. Most highly regarded is the one considered to be best overall, QFR is just considered best value.
I hadn't thought about the Korean customs, just "normal" commercial boards. A custom is very nice, but hard to pin down one design that gives the best idea of how MX feels. Some custom sellers offer completed boards, but it costs more. Personally I think a Filco comes close to the customs if you simply replace the case with a metal one. A big advantage of customs, though, is a plate that allows you open the switches without desoldering them.
« Reply #57 on: Fri, 17 January 2014, 04:31:17 »
I was thinking that the keyboard you regarded the highest is the one you are most likely to recommend to a friend.
A Korean custom, or HHKB-S might be your favourite, but they are not often the first keyboard recommended to a newbie due to cost.
Offline terran5992
  • One With The Cup Rubber
« Reply #58 on: Fri, 17 January 2014, 04:34:13 »
Filco or a korean custom
Offline epzy
  • HHKB Fiend
  • ded
« Reply #59 on: Fri, 17 January 2014, 04:36:20 »
Perhaps this:
What a nice spaceship keyboard.  :cool:
Offline Grim Fandango
« Reply #60 on: Fri, 17 January 2014, 05:33:55 »
Most highly regarded. So that is about having the reputation of being the best right? I have not tried enough of them to answer which is actually best, but if you comb through the forum and have to find some kind of consensus, then I think you would find that Filco is the brand often mentioned when people are talking about a quality MX board. That is not to say that other brands like Leopold and so on are thought of as bad, but it seems that at least in the minds of people Filco is the benchmark.
Of course, that does not mean that everyone would agree with it. While a non-issue for most, some people would rather get a board that does not have the infamous ping. Or a board with other stabilizers. Or a board which comes with PBT stock keycaps instead of Filcos crappy padprinted ABS ones, and so on. But, we are talking overall reputation here.
« Last Edit: Fri, 17 January 2014, 05:36:45 by Grim Fandango »
Offline neunelfer
  • HHKB Pro
« Reply #61 on: Fri, 17 January 2014, 09:08:22 »
Really, the layout of the HHKB isn't that different. A few lines in Autohotkey and you can basically replicate it.
Offline kskwerl
« Reply #62 on: Fri, 17 January 2014, 09:47:22 »
Is there any way to swap the control with the shift on the HHKB?
HHKB Pro 2 - Leopold 210TP -
« Reply #63 on: Fri, 17 January 2014, 09:55:18 »
If your on windows you could use keytweak, not sure why you'd want to swap them though :P
Offline neunelfer
  • HHKB Pro
« Reply #64 on: Fri, 17 January 2014, 10:07:40 »
Either that or autohotkey.
Offline kskwerl
« Reply #65 on: Fri, 17 January 2014, 10:09:36 »
Thanks guys, not sure if I'm gonna reprogram it like that or not or just give it more time
Offline Wildcard
  • When caffeine isn't enough
« Reply #66 on: Fri, 17 January 2014, 10:15:23 »
H H K B H H K B H H K B H H K B
MXBLUESMXBLUESMXBLUESMXBLUESMXBLUESMXBLUESMXBLUESMXBLUESMXBLUESMXBLUESMX
« Last Edit: Fri, 17 January 2014, 10:16:57 by Wildcard »
« Reply #67 on: Fri, 17 January 2014, 10:24:45 »
wow...that almost makes me want to puke...
Offline neunelfer
  • HHKB Pro
« Reply #68 on: Fri, 17 January 2014, 10:32:04 »
You might be sitting too close to your screen
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #69 on: Fri, 17 January 2014, 12:17:20 »
Perhaps this:
****, the chevrons are locking!
Quote from: Samuel Adams
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #70 on: Fri, 17 January 2014, 19:11:14 »
Perhaps this:
brb grabbing hologram projection technology.
Muhahahhaahahahahaha
and now you cannot escape.
