Author Topic: Most highly regarded MX keyboard?  (Read 16774 times)
Offline kskwerl
« on: Wed, 15 January 2014, 22:06:02 »
So I have the HHKB Pro 2 and I'm loving it, I always had rather cheap MX blue keyboards so I'm wondering what the most highly regarded MX keyboard is. I want to try MX reds as I've only ever tried blues.
HHKB Pro 2 - Leopold 210TP -
Re: Most highly regarded MX keyboard?
« Reply #1 on: Wed, 15 January 2014, 22:12:46 »
So I have the HHKB Pro 2,
HHKB Pro 2,
/thread
don't need a peasant MX board when you have the almighty already.
http://geekhack.org/index.php?topic=51282.0
join us. whenever you feel like you're being misguided out of the true path of righteousness, we'll be there to hold your hand and tell you it's okay.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #2 on: Wed, 15 January 2014, 22:15:21 »
HHKB Pro 2,
/thread
Having a bad day?
Offline neunelfer
  • HHKB Pro
« Reply #3 on: Wed, 15 January 2014, 22:18:24 »
H H K B H H K B H H K B H H K B
But really, I would say that for stock MX boards, Filco is generally considered to be the best brand.
« Reply #4 on: Wed, 15 January 2014, 22:19:41 »
but it also depends what type of reds you want to try.
plate or pcb mount?
if so, poker would be good for pcb mount. QFR for plate (well im not sure if they even have a red version) but you shouldn't be spending a ton of money on a board simply because you want to try the switch. you could also sign up for nubs' community switch tester and save yourself some cash.
hhkb comes CASE mount. your move cherry.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Wed, 15 January 2014, 22:21:57 »
Ahhh, case mount....
...making it nearly impossible for a custom case to be made for it.....
....unlike that of cherry switches.....
« Reply #6 on: Wed, 15 January 2014, 22:24:17 »
beast.
shut up.
hhkb > your wood
Offline neunelfer
  • HHKB Pro
« Reply #7 on: Wed, 15 January 2014, 22:27:12 »
HHKB Elitist
Offline Pacifist
  • on hiatus
« Reply #8 on: Wed, 15 January 2014, 22:29:47 »
Doesn't beast make metal plates too?
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #9 on: Wed, 15 January 2014, 22:39:07 »
Depends a lot I guess. I think in my case Cherry G80-5000 HAMDE would probably be interesting coming from MX realm.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #10 on: Wed, 15 January 2014, 22:45:50 »
Best Current keyboard using Cherry MX is Egdx...
It is now rivaled by the unreleased Ergo Pro..  (assuming everything is up to snuff, stabilizers, tenting etc.)
All non-ergo boards are not in the running for best-board...
Offline Pacifist
  • on hiatus
« Reply #11 on: Wed, 15 January 2014, 22:49:02 »
Is staggered better than matrix for ergonomics?
« Reply #12 on: Wed, 15 January 2014, 22:50:57 »
On a Nunchaku design, it doesn't matter..
On something that's static and not -rotatable (kinesis/maltron)  then matrix is better.
Offline atlas3686
  • HHKB Elite
« Reply #13 on: Thu, 16 January 2014, 00:48:39 »
I mean I would consider a nice Filco MJ2 as the best std. mx board but why would you want one? I have both and I haven't used my mx boards since the HHKB arrived. Rather get a switch tester if you want to check out the other switches.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #14 on: Thu, 16 January 2014, 02:06:26 »
Huh all this HHKB fanboyism.
It's like you guys are all full time programmers or something.
Well jokes aside, I do get the appeal of HHKB on this forum.
« Reply #15 on: Thu, 16 January 2014, 02:15:39 »
hhkb is probably the worst board for programmers.
You're essentially forcing yourself to get around a terribad layout with zero programmability..
You would think a "programmer" would know that "programmability" is a pivotal element of a good keyboard ... but... N000000oooooo... apparently rubber cups make a difference.... because u know, they're japanese rubber cups..
Most people here claiming to be programmers are just scrub weeaboos taking an intro to VB class...
ooo.. look at this... i can make a table and haz copy people's java script... oooo.. i'm a programmer...
Offline Oobly
« Reply #16 on: Thu, 16 January 2014, 02:17:56 »
I call BS. Vertically staggered always trumps horizontal if designed (and used) properly. Your fingers rest naturally on the home row keys and move within their comfortable range to reach the upper and lower row keys, without inducing twist.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #17 on: Thu, 16 January 2014, 02:25:23 »
vertically-----staggered-----vs  horizontal
what is vertically   staggered
and what is horizontal....
Offline gameaholic
« Reply #18 on: Thu, 16 January 2014, 02:49:02 »
Ergo Pro?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline The_Beast
  • I like wood ಠ_๏
« Reply #19 on: Thu, 16 January 2014, 02:50:18 »
« Reply #20 on: Thu, 16 January 2014, 02:54:07 »
beast.
shut up.
hhkb > your wood
No?
I like wood ok... but my fav building material is concrete..  except it's weak if the aliens attack us with microwave based weapons
« Reply #21 on: Thu, 16 January 2014, 02:57:28 »
HHKB Pro 2,
/thread
damn man, made me chuckle silently to myself  :))
« Reply #22 on: Thu, 16 January 2014, 03:05:13 »
Not quite.
It is the layout that is particularly appealing for Unix programmers (or those programming on Unixy systems).
Ctrl where Caps Lock is makes sense as Unix makes much use of control characters.
Backspace where \| is also makes sense as the Backspace is closed to Enter, and the "home row" (should you choose to use it).
I alternate between TKL and HHKB, and it always feels more natural having Ctrl and Backspace where they are on the HHKB.
I am a programmer, but mostly under Windows, and I miss having dedicated arrow keys on the HHKB when using HHKB under Windows in the various GUI IDEs we use.
« Reply #23 on: Thu, 16 January 2014, 03:09:38 »
Not quite.
These arguments are M0000t
non-programmability is a major hindrance to ANY KEYBOARD..
your hand is different than my hand..
you have different usage statistics for different keys...
Why should our layouts be stuck to some baseline that existed well before modern computing.
I find it a bit of madness that any true-programmer, outside of script-kids would at all CONSIDER a NON-programmable board.
Offline tbc
« Reply #24 on: Thu, 16 January 2014, 03:13:03 »
ahk
makes any keyboard programmable
« Reply #25 on: Thu, 16 January 2014, 03:14:13 »
ahk
right.. i agree.. this is the last resort...
but hardware programmability... no additional latency relative to AHK..
« Reply #26 on: Thu, 16 January 2014, 03:47:29 »
Not quite.
A customised programmable keyboard would just mean that you would be lost when using someone else's workstation, or vice versa.  Using a standard layout means the same key sequences work in the same way on any standard keyboard you use.  Unless either everyone has the same customisable keyboard and you upload your configuration to it each time you move to a different workstation, or you carry your keyboard around with you everywhere.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #27 on: Thu, 16 January 2014, 05:07:44 »
Ahh man here we go again, off to the tangent of HHKB vs * again...
ErgoDox has what.. a teensy controller. Try telling me teensies aren't programmable... ErgoDox is a kit or can be fan-made, HHKB isn't fan-made, it is made commercially by a company who probably doesn't have much interest in letting out their specs let alone firmware. Therefore it would make practical sense for companies to ship fairly average mechanical keyboard with some flexibility. If you are going to try and compare HHKB like that, compare it first against Ducky for instance. Ask Ducky Channel to see if they would give out the firmware. Then don't forget manufacturers whom offer neither DIP switches nor customisable firmware.
As if to also prove the point, there is always hasu's TMK firmware _and_ TMK controller board for HHKB which not only gives one flexibility but more customisation (in the future), like teensy and therefore like ErgoDox (but controller-wise).
« Reply #28 on: Thu, 16 January 2014, 07:06:57 »
Something plate mounted with stock mx clears and cherry or GMK doubleshot ABS caps.
« Reply #29 on: Thu, 16 January 2014, 07:11:52 »
I keep coming back to my metal cased customs. KMAC LE and Epsilon
Offline ynrozturk
« Reply #30 on: Thu, 16 January 2014, 07:26:04 »
While the HHKB looks cool, Topre is just not for me. I think people just feel the need to glorify them because of their ridiculous price tag.
As far as commercial, fairly easy to get boards, I would say that Filco wins the MX realm. My preference would be browns. I'd much rather have a KMAC than a HHKB any day of the week.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Wildcard
  • When caffeine isn't enough
« Reply #31 on: Thu, 16 January 2014, 07:33:02 »
beast.
shut up.
hhkb > your wood
Elitist...
Offline Oobly
« Reply #32 on: Thu, 16 January 2014, 07:46:38 »
It's personal.....
I'd have to say any plate mounted board with a good PCB and decent caps will give you a feel of top shelf Cherry MX. Filco Majestouch seem to be quite highly regarded.
The problem is, there are so many options and so many mods, that the "ultimate" Cherry MX board is a very personal thing, and will feel unique. Mine has custom plates, no PCB, heavily modded Brown switches (trampoline, latex, stickers) and a mix of PBT and POM caps. That's the attraction of the MX switches for me, they can be tweaked to give the feel, travel distance, sound, etc, that I want.
Another advantage is the switches are complete self-contained units that can be replaced individually or used for custom physical layouts easily.
Vertical columns of keys staggered with the respect to the columns on either side of it, vs horizontal rows of keys, staggered with respect to the rows above and below. The former allows for the natural difference in resting positions of the fingers, equal movement to upper and lower rows, true vertical finger movements instead of diagonal, etc. The latter doesn't. BIG difference in ergonomics.
ErgoDox is vertical stagger (although not enough on the pinkie rows), Ergo Pro is horizontal stagger.
Ergo Pro has best of both worlds in terms of programmability, though. It's apparently going to be "hackable", allowing custom firmware to be flashed to the controller, but has a stock, unprogrammable layout by default.
With the HHKB you can install a replacement controller with programmable firmware on it, but it requires more work and cost. Some people really like how they feel and think it is worth the cost. Others don't. All I can say about them is that I didn't like how the Topre switches felt in the few seconds that I tried a RealForce in a shop, but that's not really a fair evaluation (different board and not enough time spent using them).
Offline ideus
  • Björkö.
« Reply #33 on: Thu, 16 January 2014, 08:27:21 »
I wonder why we are always comparing topre and cherry based boards as if they were the same. They are not, besides caps, they are based in different physical principles to produce a switch signal. How a rather complex pcb based capacitive switch technology can be compared with a self contain simple plastic and metal switch? Well, maybe these never ending discussions are what fueled our beloved GH site...
Offline kskwerl
« Reply #34 on: Thu, 16 January 2014, 09:09:12 »
omg what did I do  :p
« Reply #35 on: Thu, 16 January 2014, 10:08:53 »
Not quite.
this rarely happens... very rare..  and most people who have custom setups would have an extra keyboard at their station for guests.
« Reply #36 on: Thu, 16 January 2014, 10:14:20 »
It's personal.....
The pinky row on Egdx is fine...  Th pinky doesn't really have 3 rows of movement anyway with a wrist lift.. it has 2..
If you staggered the top key further what would it achieve ??
my setup is tilted around 35*,  this way  the "a " position key is directly under my pinky and I hit the "q" key with my ring finger..
If the A was moved down further, it would make z a bit harder to reach same with ". " on the right
Offline Folio
  • I'm a nice guy.
« Reply #37 on: Thu, 16 January 2014, 10:52:30 »
This thread made me laugh with every post. You guys are going completely off tangent. I love everyone here. So glad I still come to this forum.   :-*
Offline kskwerl
« Reply #38 on: Thu, 16 January 2014, 11:04:26 »
lol I know right, all I wanted to know was what are some of the best MX keyboards in terms of overall quality and high praise here on GH.
Offline Oobly
« Reply #39 on: Thu, 16 January 2014, 11:32:47 »
hihiii... guilty.
TLDR; Filco
Offline kskwerl
« Reply #40 on: Thu, 16 January 2014, 11:55:19 »
hihiii... guilty.
I wanted to know this because as I have the HHKB Pro2 I always have cheap MX keyboards and I'm just wondering how the higher end ones would compare.
TLDR; Filco
Offline Linkbane
« Reply #41 on: Thu, 16 January 2014, 13:38:00 »
Filco is great, but it's not as good as those Korean customs by any means. They're far above any commercial keyboard in terms of quality and price.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline kskwerl
« Reply #42 on: Thu, 16 January 2014, 15:32:06 »
What are some other custom ones besides the KMAC? If I'm understanding this correctly you build them yourself?
« Reply #43 on: Thu, 16 January 2014, 15:40:58 »
a kmac is like a kit to build a classic horse pulled carriage..
The whole concept of the horse drawn cart itself is obsolete and slow as balls..  BUT it's pretty and reminds people of simpler times.
The Egdx on the other hand is like a modern gasoline car..  It's better in everyway.. you may or may not find it aesthetically pleasing, since to most people, it's not what they're used to seeing with respect to the rectangle in front of their computers.
Make no mistake... extended use of classic keyboards inevitably leads to Repetitive stress disorder...
There is no question that this is what's going to happen if you lead a computer-oriented lifestyle..
If you had to dig trenches with a shovel,  vs a tractor...   That is the difference...
Offline Folio
  • I'm a nice guy.
« Reply #44 on: Thu, 16 January 2014, 15:49:14 »
tp, your title should be "Ergodox Enforcer"
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #45 on: Thu, 16 January 2014, 17:37:41 »
You're definitely not alone there - I have said something similar before. Also that is ignoring the fact that there's dime-a-dozen more ergonomic keyboards floating out there on the market, plenty more fancy varied shapes and sizes to choose from. When talking about ergonomics, there's plenty of ways to skin a cat - to say ErgoDox is superior to all of the ergonomical keyboard designs out there is really a bold (yet naïve) statement.
Anyway OP, I think your question is too open. For HHKB equivalent in Cherry MX realm (whilst retaining 60% factor) you have KMAC. For μTron keyboard equivalent, you have the likes of Cherry G80-5000 for instance, and so on and so forth.
« Last Edit: Thu, 16 January 2014, 18:02:16 by tuxsavvy »
Offline ideus
  • Björkö.
« Reply #46 on: Thu, 16 January 2014, 17:49:53 »
If the dox is a "gasoline car", you said. Then what would be the board "equivalent" to a modern hybrid or an F1 car? what an imagination to make this metaphor up.  :D
Offline Novus
  • Mondai nothing~
« Reply #47 on: Thu, 16 January 2014, 17:56:12 »
Don't forget modern diesel cars too. Those things are beast.
Offline ideus
  • Björkö.
« Reply #48 on: Thu, 16 January 2014, 21:13:25 »
Yeah, tp4 should extend his metaphor to cover all the vehicles then. Haha! Wonder how he may still position his beloved dox at the top of them.
Offline kskwerl
« Reply #49 on: Thu, 16 January 2014, 21:15:22 »
The reason I ask this and started this thread is because of my concern that one day the HHKB will no longer be available. This scares me as I'm learning this layout and then I'll have to go back to a standard layout.
