Author Topic: Describe the perfect keyboard for yourself!!  (Read 16100 times)
Offline Comment
Re: Describe the perfect keyboard for yourself!!
« Reply #50 on: Wed, 05 February 2014, 13:45:45 »
Cherry switches also aren't really tactile.
They're not? I think clears are extremely tactile.
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline HPE1000
  • Keycap Paparazzo
« Reply #51 on: Wed, 05 February 2014, 13:52:27 »
Hence why I said "usable" thumb keys :)
Ergodox thumb cluster is too far away for me.
Ah, I have pretty massive hands so I don't think I would have any problems with an ergodox.
Also, what cherry switches have you tried?
Offline tricheboars
  • Keyboards are Important!
« Reply #52 on: Wed, 05 February 2014, 14:03:48 »
hopefully the ergodox i just ordered from massdrop with Round 5 SA caps.
but as of right now this very day i have to say my custom poker. the pom caps, plate mounted blue switches, and hammer aluminum case makes it feel so solid and wonderful.
POM is the ****.  it is just so awesome.
Offline kod
« Reply #53 on: Wed, 05 February 2014, 14:13:56 »
I've tried cherry browns, blues, clears.
The difference between them and really tactile interfaces (buckling springs, sanwa microswitched joysticks, clicky alps) is pretty profound.
Offline robertsig
« Reply #54 on: Wed, 05 February 2014, 14:17:59 »
* Realforce based 87-key layout, off-white/gray
* Better controller (so Scroll-Lock works on KVM's)
* Uniform Topre switches, 49g weight
Offline Touch_It
« Reply #55 on: Wed, 05 February 2014, 14:23:36 »
122 key IBM model F, standard (I think ANSI layout).
Offline Mr. C
« Reply #56 on: Wed, 05 February 2014, 16:28:25 »
I would be happy with FC660c with Function keys.
Offline Aer Fixus
  • And now, back to lurking...
« Reply #57 on: Thu, 06 February 2014, 16:36:41 »
Standard layout for an F122 is terminal ISO. ISO for the alphanumerics, but with a split + key on the numpad and some re-arranged key positions because of the terminal layout. However, they can be modded to ANSI with some precision elbow grease.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline BrokenGame
« Reply #58 on: Mon, 10 February 2014, 10:57:27 »
Titanium HHKB 55g keys + PBT Topre raindrop. That would be awesome.
Offline ferociousfingerings
« Reply #59 on: Mon, 10 February 2014, 11:17:14 »
My perfect keyboard would be cybernetic implants at the ends of my efferent neurons...
Hah, beat me to it.
I would prefer to simply think the words into the machine; there's no way my fingers will ever be as fast as my thoughts.
Consider this: If i think in visual imagery, and a "movie" is ~24+ fps, and "a picture's worth 1000 words..."
There's no way i will ever be able to "type" 24,000 WPM... and that's not even counting "gamers" who notice anything below monitor refresh rate.
What if we could convert fluid motion imagery directly to language, in real-time, just by thinking? Or even literally "stream" our very consciousness... all thoughts, dreams, memories, images, sounds... or even quantify and digitize actual feelings...
Logitech G710+
Offline 1pq
  • Hipster Doofus
« Reply #60 on: Sun, 23 February 2014, 22:07:45 »
This:
MX browns with 62g ErgoClears on the thumb clusters, Esc, Del, arrows and edit keys. All switches trampoline and latex modded. Fully programmable and plug and play (no special drivers), custom layout (ADnW BU-Teck with some modifications).
Or for a more conventional answer, a GH60 with the Nostalgia set in a white case (ANSI layout with custom function layers).
Oobly, do you have a thread on this keyboard? It looks awesome and I'd love to learn more about it.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Pacifist
  • on hiatus
« Reply #61 on: Sun, 23 February 2014, 22:10:15 »
This:
Oobly->show posts->topics->http://geekhack.org/index.php?topic=49721.msg1077639#msg1077639
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #62 on: Sun, 23 February 2014, 22:30:16 »
lubed ergo clears, Stainless plate x4 sandwiched and bolted together, stainless case, hard wired power switch, reset switch, all 304 stainless.  Because that is the same grade of stainless used in the DMC Delorean.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #63 on: Sun, 23 February 2014, 23:26:09 »
TKL w/ mx blacks. I'm a man of simple needs  :)
Offline Pacifist
  • on hiatus
« Reply #64 on: Sun, 23 February 2014, 23:28:52 »
55439-0+ QazPad
Offline Photoelectric
« Reply #65 on: Sun, 23 February 2014, 23:29:14 »
A beamspring keyboard in a TKL or 75% form factor, ANSI layout, and a low profile case for overall lower height.
Offline Lastpilot
  • Power stance
« Reply #66 on: Sun, 23 February 2014, 23:31:42 »
For some reason I was expecting something with more...LEDs XD
« Reply #67 on: Sun, 23 February 2014, 23:33:04 »
I already have 2 keyboards for full LED madness and one with a lot of function LEDs :)
Offline Kitesurfer
« Reply #68 on: Mon, 24 February 2014, 00:34:19 »
In descending importance order :
fully programmable
buckling spring
split and tenting
matrix
compact, TKL
black blank PBT keycaps
integrated trackpad or trackpoint
alu case
USB hub
detachable cable
Offline simon_C
« Reply #69 on: Mon, 24 February 2014, 01:02:14 »
84key
Dvorak
no Winkeys
control instead of capslock
fully addressable rgb backlight
detachable cord
thick backlight-compatible doubleshot keycaps
ergoclears, browns, or blues
Stainless steel case like K65, with integrated wrist wrest.
Offline daerid
    • Rossipedia
« Reply #70 on: Mon, 24 February 2014, 01:06:34 »
Wireless ErgoDox with 55g Topres and movable thumb clusters on ball mounts.
Never. Gonna. Happen.
Offline Emospence
« Reply #71 on: Mon, 24 February 2014, 01:15:18 »
Perhaps a uniform 60g Topre..
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline pbtforever
« Reply #72 on: Mon, 24 February 2014, 08:16:25 »
Anything with PBT keys!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #73 on: Mon, 24 February 2014, 08:18:31 »
A man can dream...
  • Live long and prosper
« Reply #74 on: Mon, 24 February 2014, 08:23:01 »
60% Model M with NKRO and MX-compatible key caps.
tp thread is tp thread
Offline quake4mhg
« Reply #75 on: Mon, 24 February 2014, 22:39:55 »
Filco Lefty Keyboard DFK-901LF-II  :'(
Offline Kamen Rider Blade
« Reply #76 on: Mon, 24 February 2014, 23:17:16 »
For me, there isn't a perfect keyboard since I like to many styles, but a perfect keycap would be a e-ink keycap with clear polycarbonate top to protect the e-ink screen.
Offline type.n
« Reply #77 on: Mon, 24 February 2014, 23:26:54 »
Something with "Cherry MX Purple" linear switches with 50g-55g of actuation force.
Offline yasuo
  • spanengan puyeng newbie
« Reply #78 on: Mon, 24 February 2014, 23:31:31 »
Logitech MK220 Colemak DH
Offline type.n
« Reply #79 on: Mon, 24 February 2014, 23:36:07 »
No click! Just a smooth linear switch with 50-55g of actuation force.
Offline JPG
  • Model F is my new passion!
« Reply #80 on: Mon, 24 February 2014, 23:38:58 »
Or just a kishsaver and you keep them BS keycaps? :p
As for me, since falling in love with my F122, I now dream of a space unsaver (F122 without the numpad), and in fact, to be perfect, I would even prefer to have a F122 but without the navigation part (arrows and above). A 60% F could do the job since I aim to mostly use the 60% section with layers thx to Soarer, but I still find it nice looking to be just big, yet the F122 is just a little too big for my mouse to be at the right place so removing either the numpad or the nav cluster would be perfect. And since I remap the nav cluster on a layer anyway, as well keep the numpad for the rare occasions where it would be useful. And them 24+10 function keys, just badass and they use space that would not be used anyway. OK, I have yet to try a split ergo keyboard, but that's another story!
Offline gameaholic
« Reply #81 on: Tue, 25 February 2014, 10:26:14 »
Titanium color low profile aluminum case.
Winkeyless ansi layout with stepped capslock.
Costar stabilizers for except for spacebar which would have clipped cherry stabilizers so I could flip it around.
Lubed and stickered cherry mx clear with gold 62g springs.
New Cherry/Corsair RGB backlighting.
GMK two tone black on beige two tone double shots (with fixed tab).
Custom sleeved usb cable.
Photek's Tek-80 comes pretty damn close but I would prefer a low profile, rectangular case like my kmac.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
« Reply #82 on: Tue, 25 February 2014, 10:29:27 »
Idk, I think a Kishsaver would look killer with an orange case and a Nostalgia set...
« Reply #83 on: Tue, 25 February 2014, 10:31:05 »
This would be very nice.
I think a nice layout is the 75% layout on the Epsilon or Siig Minitouch. Or the 22MX mini. But I'd like Blue Alps switches. Aluminum case in the vein of a KMAC case/TEK-80/Hammer, stainless steel plate, true Purple LEDs, GMK/Cherry profile doubleshot ABS caps in a purple/pink colorway.
If we're going for dream keyboard status, swap out stainless steel and aluminum for inconel.
« Reply #84 on: Tue, 25 February 2014, 10:32:07 »
There is no such thing as a perfect keyboard :eek:
Offline Melvang
« Reply #85 on: Wed, 26 February 2014, 11:34:39 »
Do you realize how much of a PITA that stuff is to machine and work with??  That stuff almost has to be waterjet.  Tooling for typical machining is STUPID expensive.  That stuff as a plate would be ultra stiff though.  I love the idea.
« Reply #86 on: Wed, 26 February 2014, 11:38:11 »
Of course I do haha. Hence why it's a dream keyboard and not anything practical :P.
Offline Melvang
« Reply #87 on: Wed, 26 February 2014, 11:40:27 »
If I had the financial means to do so I would totally go in on that with you.
« Reply #88 on: Wed, 26 February 2014, 11:43:13 »
If I had the means I'd be at the shop watching them break bits instead of dreaming about it ;).
Offline Melvang
« Reply #89 on: Wed, 26 February 2014, 11:44:11 »
Better take a cam.  I want to see.
Offline johndavis33
« Reply #90 on: Wed, 26 February 2014, 17:15:59 »
My ducky g2 pro PBT with greens, but with a better color scheme (gray on gray - boring), and a metal case. Keep everything else the same.
And a 60% bluetooth version with a trackpoint for travel!
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
Offline TheRavenDog
« Reply #91 on: Thu, 27 February 2014, 20:32:02 »
Buckling spring
USB, PS/2, and Bluetooth support.
LiPoly battery for Bluetooth. Charged by the USB or PS/2 connection.
Integrated USB hub with additional USB ports on the left and right side.
Programmable via a micro SD card that has a simple XML file describing the scan codes sent for each key
Transparent Key stems
Integrated LED for each key. Or Promethium-147 radioluminescent ink used for the keycap legends.
Each key is a separate switch with an integrated diode to prevent ghosting.
PS/2 version would have N-key rollover.
Each key is secured via a bolt to a back-plane.
The back-plane has trace positions for key in many different locations (so you can add more switches).
Open source and fully programmable firmware (loaded from the SD card).
A reset switch on the back.
Adjustable weight and tilt.
Integrated PIR motion detector that sends the "lock computer" command when you're no longer in front of your computer for 15 seconds.
No CapsLock key. Instead another modifier key.
No NumLock key. Instead another Esc key. The number pad is just numbers.
No ScrollLock, Print Screen, Break/Pause keys. Instead F1-F30!
No Insert-button. Instead a "Close" button that the OS understands to mean "close the window with focus".
Some extra keys: Lock, Sleep, and Power.
Extra modifier keys: Option, Function, Command, and Cmd.
137 key format (see the picture below)
The dream...                     The reality...
Offline 1pq
  • Hipster Doofus
« Reply #92 on: Fri, 28 February 2014, 19:37:26 »
My dream keyboard: a topre board that felt as good as the FC660C but in 40% form factor, with cherry compatible stems and an titanium case (not just the color—the metal :D).
Offline Snarfangel
« Reply #93 on: Fri, 28 February 2014, 20:09:17 »
A capacitive buckling spring Maltron L90 with reprogrammable and relegendable keys might not be perfect, but it would keep me happy until perfection came along.
Perhaps something with Hall effect switches and OLED keycaps...
« Reply #94 on: Fri, 28 February 2014, 20:21:09 »
cooks dinner and runs my bath.
if my hhkb could do that i'd marry it.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #95 on: Fri, 28 February 2014, 20:52:27 »
A 60% keyboard, with ISO layout, MX Clears, fully programmable backlights.
At the moment.
And now it's a full size, ISO layout, Keycool built, titanium case, buckling spring topre MX Clear Ergo Clear I DONT KNOW, PBT keyboard, with a FN row full of V1 and V2 brobots and CCs (4 of each)
Offline Melvang
« Reply #96 on: Sat, 01 March 2014, 00:05:35 »
Stainless steel cased Ergo Dox with buckling springs and the thumb switches mounted so you pushed "in" instead of down.
