Author Topic: Can you remap the ctrl and Caps lock on a Realforce 104ub-dk?  (Read 4848 times)
Offline luis911
« on: Wed, 05 March 2014, 19:25:02 »
Hey guys, I was just wondering if anyone knew how I would go about doing that. I much prefer to have my CTRL right next to my pinky. Thanks.
Check out my website FDMPrints.org
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Can you remap the ctrl and Caps lock on a Realforce 104ub-dk?
« Reply #1 on: Wed, 05 March 2014, 19:30:58 »
AutoHotkey for Windows, xmodmap for Linux.  Not sure about OS X but I'm sure it's possible.
Offline luis911
« Reply #2 on: Wed, 05 March 2014, 19:33:16 »
Oh, I was hoping there was a mechanical way like there is on my ducky.  :mad:
Offline Pacifist
  • on hiatus
« Reply #3 on: Wed, 05 March 2014, 20:02:27 »
No dip switches nor programibility means nope. This goes for pretty much any board without dip switches and programibility--even some with dip switches choose not to add this feature :-\
Offline esoomenona
  • Gnillort?
« Reply #4 on: Wed, 05 March 2014, 20:10:05 »
Are there no dipswitches on fullsize RFs? I know there are on TKLs.
Offline Schwarz
« Reply #5 on: Wed, 05 March 2014, 20:34:25 »
Sharpkeys (Windows)
HHKB Pro2 |  Poker II (Red) | Filco MJ2 (Brown)
Offline jabar
« Reply #6 on: Wed, 05 March 2014, 20:36:08 »
I know the High Profile keyboard doesn't have DIP switches... all of them should have some at their price points.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline ideus
  • Björkö.
« Reply #7 on: Wed, 05 March 2014, 20:57:22 »
As someone already referred use Sharpkeys and any board hooked to your computer will have the control key where you defined. If you are using more than one computer you can set all in the same way it is fairly easy, and due to the registry approach latency is close to zero.
Offline hasu
  • @tmk
« Reply #8 on: Thu, 06 March 2014, 10:06:41 »
Just cut trace on PCB and patch with soldering wires.
Offline ideus
  • Björkö.
« Reply #9 on: Thu, 06 March 2014, 11:29:02 »
Why mess with the hardware, if there are very good software solutions? Just wondering.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #10 on: Thu, 06 March 2014, 12:13:42 »
Because solder doesn't forget new key-mappings.  (just like patch cables don't forget their VLANs.)
[edit]
To be less flip about it, if you modify the hardware, then no matter what computer you plug that keyboard into (or OS you boot)  -- the re-mapping is retained.
[/edit]
 - Ron | samwisekoi
« Last Edit: Thu, 06 March 2014, 15:34:41 by samwisekoi »
Offline khaangaaroo
« Reply #11 on: Thu, 06 March 2014, 12:33:28 »
