Author Topic: [SPRiT] MX ALPS Springs/ LSS Lube/ Stabilizers/ Cherry RGB Clear (CLOSED!!!!!!!)  (Read 1514614 times)
Offline tjweir
Re: <SPRiT Edition> MX Gold Springs = Production Done
« Reply #1250 on: Wed, 18 February 2015, 19:01:35 »
See above, zeal bro.  Zeal.
Offline Gloomy Moonie
« Reply #1251 on: Sat, 21 February 2015, 02:02:19 »
Haven't been following this thread, so pardon my ignorance, but are sampler sets available, and if not, when will they be, if at all?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #1252 on: Sat, 21 February 2015, 02:03:09 »
He hasn't been on in over a month and hasn't been invoicing anyone.
Offline alexofthewest
« Reply #1253 on: Thu, 26 February 2015, 14:51:05 »
Placed an order for the 62g and a set of 65g. I used the order form, hopefully he is still taking orders.
Offline tjweir
« Reply #1254 on: Thu, 26 February 2015, 14:54:42 »
Offline Prelim
« Reply #1255 on: Thu, 26 February 2015, 15:00:00 »
hopefully he wont "steal" your money, like he did for the rest of the users lol
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Korth
« Reply #1256 on: Sat, 28 February 2015, 07:42:10 »
Anywhere else to order these sorts of springs from?  (Outside of a group buy, lol?)
I'm not actually looking for golden bling.  Especially since it's buried under keycaps and keyswitch plastics.
But I am attracted to the special tempering and weights.
Offline wlhlm
« Reply #1257 on: Sat, 28 February 2015, 07:54:08 »
Why does no one read previous posts?
Order from Zeal: http://zealpc.net/collections/accessories/products/18k-gold-plated-springs-100pcs
Offline Korth
« Reply #1258 on: Sat, 28 February 2015, 07:56:30 »
lol I did read previous posts.  About 10 pages worth, here and there.  42 pages was just too much.
But thanx for the reply and the linky, sir  :D
Offline jamster
« Reply #1259 on: Sat, 28 February 2015, 08:10:01 »
General tip: Read the last page or two, the most up to date info will probably be there. Zeal is mentioned two or three times on this page alone ;)
Offline pocketdrummer
« Reply #1260 on: Sat, 07 March 2015, 15:22:45 »
I contacted Zeal about springs in the 62g - 68g range, and I got the following response:
"The current "Sprit Springs" are all that is left and will most likely not be restocked. However, I am working on sourcing some new 62g gold springs in the near future. Stay tuned!"
That's very disappointing. The brown springs are too light and make the keyboard feel cheap, but the MX Clear springs in my ergodox are so stiff they negate any benefit of having an ergonomic design. I have RSI in both of my arms, so it's very important for me to find a happy medium between the browns and clears. A 65g or 68g spring sounded perfect, but they are now sold out and it doesn't appear they will return.
Does anyone know of another place to get 65g or 68g korean springs?
Offline DrHubblePhD
  • I am star stuff
« Reply #1261 on: Sat, 07 March 2015, 15:24:58 »
mx brown springs are actually heavier than 62 or 65g springs.
Offline Prelim
« Reply #1262 on: Sat, 07 March 2015, 15:27:38 »
no, they aren't. browns have almost the same springs as reds (about 55-58g on korean scale)
MX Springs Compared
    I follow the Cherry Original Specs and GeekHack Standard.
    For my 50g ~78g, I have tried to add some softer touch. They start slightly softer and mellow than stock ones.
-  My 50g   is a little bit softer and lighter than MX Red (55g)
-  My 55g   is slightly softer and lighter than MX Brown, MX Blue (58g-60g)
-  My 60g   is similar to MX Blue, but a little bit tighter and stable
-  My 62g   is slightly heavier than MX Blue
-  My 65g   is soft but quite heavier than MX Blue
-  My 68g-72g   is similar to Vintage MX Blacks (soft & cushiony)
-  My 78g   is a Soft MX Clear Edition, softer & lighter than MX Clear, but same cushiony too.
-  My 85g   is similar to MX Clear.   v1.0 starts little bit solid,  v1.1 starts softer
« Last Edit: Sat, 07 March 2015, 15:31:52 by Prelim »
« Reply #1263 on: Sat, 07 March 2015, 15:38:38 »
Actually I asked Zeal about that as well, and they said this:
"As for a spring that's comparable to MX Browns, that would be the 60g Korean spring. MX Clear springs would be 78g or 85g (78g is a bit lighter, 85g is almost identical to stock Clear spring)."
Offline DrHubblePhD
  • I am star stuff
« Reply #1264 on: Sat, 07 March 2015, 16:29:17 »
Offline Prelim
« Reply #1265 on: Sat, 07 March 2015, 16:31:41 »
....so?
MX Light = red/brown = 55/58-60g korean, which is obviously lighter than 62g!
« Last Edit: Sat, 07 March 2015, 16:35:02 by Prelim »
Offline DrHubblePhD
  • I am star stuff
« Reply #1266 on: Sat, 07 March 2015, 16:34:49 »
....so?
I know bro, thought I would just share the facts  :p
Offline Prelim
« Reply #1267 on: Sat, 07 March 2015, 16:45:06 »
note that Originative's graph can also lead to misinterpretations as we don't know which spring they are testing as "MX Light"... is it red or brown? :/
Offline DrHubblePhD
  • I am star stuff
« Reply #1268 on: Sat, 07 March 2015, 16:45:52 »
The spring from mx red and mx brown is virtually identical
Offline Prelim
« Reply #1269 on: Sat, 07 March 2015, 16:47:19 »
the problem is that they aren't completely identical (red/brown/blue) as Sprit or even Ripster have reported ;) the reds springs are always more lighter than browns/blues
Offline DrHubblePhD
  • I am star stuff
« Reply #1270 on: Sat, 07 March 2015, 16:48:09 »
ripster= best keyboard scientist  :p
« Reply #1271 on: Sat, 07 March 2015, 17:03:03 »
Did they measure the springs by themselves, or did they measure them assembled into the switch? I'm sure the stems have a lot to do with the measured / perceived force of the spring.
Offline Prelim
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: <SPRiT Edition> MX Gold Springs (Order Open)
« Reply #1273 on: Sun, 29 March 2015, 19:29:23 »
The orders have all shipped out.  Track sent
Thanks!   ;)
« Last Edit: Sun, 29 March 2015, 19:41:33 by sprit »
Offline tjweir
Re: &lt;SPRiT Edition&gt; MX Gold Springs (Order Open)
« Reply #1274 on: Sun, 29 March 2015, 19:38:53 »
The orders have all shpped out.  Track sent
Thanks!   ;)
Great stuff Sprit!
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1275 on: Sun, 29 March 2015, 21:06:42 »
Thanks!   ;)
Sprit,
Does this mean that you are taking new orders again?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline sprit
« Reply #1276 on: Wed, 01 April 2015, 21:11:20 »
Sprit,
Yes!  it's open,  it takes 2 min to pack.   ;)
Most of Springs are All in Stock !  :thumb:
« Last Edit: Wed, 08 April 2015, 19:51:09 by sprit »
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #1277 on: Wed, 01 April 2015, 21:43:41 »
Sprit,
Thanks Sprit  :)
WTB/WTS/WTT ---->
Offline KnivesM
« Reply #1278 on: Thu, 02 April 2015, 01:53:25 »
No stabs at the moment? Got invoice for just springs and I put a couple sets of stabs in the form.
Edit: invoice corrected  :)
« Last Edit: Thu, 02 April 2015, 03:49:23 by KnivesM »
Others
Offline m1k3l08
« Reply #1279 on: Thu, 02 April 2015, 08:01:59 »
Ordered, looking forward to receiving them :)
Offline joey
« Reply #1280 on: Thu, 02 April 2015, 16:59:19 »
Are the stabs just the wires, or the plastic fixings too?
Offline KnivesM
« Reply #1281 on: Thu, 02 April 2015, 17:08:07 »
Usually both, but he's out of the plastic mounts at the moment so just the wires.
Others
Offline theanyday
  • love love love
« Reply #1282 on: Thu, 02 April 2015, 17:44:27 »
Ordered, hopefully I did that correctly too being as I'm new 'round these parts. ;D
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline asgeirtj
« Reply #1283 on: Thu, 02 April 2015, 20:05:38 »
Gold stabs don't make any difference in feels do they?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline sprit
« Reply #1284 on: Fri, 03 April 2015, 07:52:54 »
not sure,  but pics.   https://geekhack.org/index.php?topic=33155.msg1567497#msg1567497
Most of Springs are All in Stock!
96161-096163-196165-2
« Last Edit: Wed, 08 April 2015, 19:50:04 by sprit »
Offline razenos
« Reply #1285 on: Fri, 03 April 2015, 10:04:41 »
Is that come with 7.00x Unit wires, or just only 6.25 ?
Offline gravenshard
  • vagabondage
« Reply #1286 on: Fri, 03 April 2015, 10:10:10 »
My set has both 6.25x and 7.00x
« Last Edit: Fri, 03 April 2015, 11:04:40 by gravenshard »
Offline justify
  • Great news!
« Reply #1287 on: Fri, 03 April 2015, 11:02:46 »
I was allowed a slightly early preview for the gold stabilizers, they look very nice indeed. Can't wait to use em!
AFAIK, the set only comes with the 6.25u wire.
Offline animated
  • uhhhhhhhhhhhhhhhh
« Reply #1288 on: Fri, 03 April 2015, 11:27:49 »
I was about to order some springs and the stabs.....then I see you have a switch swap kit coming out on April 10th? Cant wait to see  :thumb:
Das Browns, Filco Reds, Filco Blues, Leopold FC750R Reds, B.87 and B.Pad Gateron Blacks 65G Korean Springs, Varmillo VA87MR Gateron Blacks w/ Aluminum Case
Offline ideus
  • Björkö.
« Reply #1289 on: Fri, 03 April 2015, 12:05:59 »
Have a reference for it?
Offline animated
  • uhhhhhhhhhhhhhhhh
« Reply #1290 on: Fri, 03 April 2015, 12:08:51 »
It's on the Google order doc, just says coming April 10th, no other information on it
Offline DanielT
« Reply #1291 on: Sun, 05 April 2015, 10:48:03 »
Well, after almost half a year of using 50g and 55g gold plated springs I can share some feedback.
First the plating, it looks good but that is less important, the gold plating makes the surface smooth. Compared to non plated springs there is no squeaking or scratchy sound when you press the switch and this is whithout lube. I have compared SPRiT springs with springs from GON (55g) and Originative (50g) and the gold plated feel much smoother.
Also there is a difference in the compression curve, I use only linear switches, in particular MX Black Old or Vintage, the springs from Originative and from GON feel linear, SPRiT springs feel more like topre there is a small resistance at the beginning inthe middle the travel is linear and in the end you feel some resistance making the landing soft. This feel is more accentuated with the 55g springs. As a HHKB user I could say that 55g feel almost as 45g Topre.
All of this is based on my daily usage I don't have any tools to measure this, only my fingers.
For me 55g springs make MX Black feel exactly how MX Red should feel.
50g are bit too light, but I think if your are a floating typing or whatever it is called and don't bottom out these are perfect.
Because I like only light and linear switches I can't provide info on other weights except 68g on the spacebar which is great.
SPRiT has done a great job with the design of these springs  :thumb:
As a side note, forget the graphs for spring weights published in the past, these don't apply to SPRiT springs at least from what I could notice.
Offline ideus
  • Björkö.
« Reply #1292 on: Sun, 05 April 2015, 12:18:29 »
Your report is very interesting, thank you very much for sharing it. It informs our decision to explore this springs. I already got some but I have not had the chance to test them yet.
What board and key caps did you use when trying the springs?
Offline DanielT
« Reply #1293 on: Mon, 06 April 2015, 02:36:05 »
I have only 60% boards, 2 GON NerD60 and one SPRiT 60%, all of them have either Old or Vintage MX Blacks, 2 of the boards use 55g SPRiT springs and one 55g GON springs. I use only Cherry or GMK caps, so maybe with thinner caps the feeling will differ, didn't test that. The boards are rotated depending of the mood I have.
One the boards with SPRiT 55g has Vintage Blacks plate mounted. The plate doesn't change the feeling too much.
All the switches are stock that means no lube and no stickers, made some tests with lubing and stickers only to realize that for me it was a waste of time, the switches feel nice and smooth without lube, the springs make the switch feel very smooth so for me the lube doesn't add an extra benefit.
Stickers are for me just waste of time, don't understand why people use them, but that's me  :p
Anyway, the conclusion is "Use the springs, don't just keep them in a bag!" , I have swapped the springs on all my boards and will do the same on my future boards. My personal favorite are the 55g springs but also 50g are nice, my guess is that 50g with thinner caps like SP DSA (PBT or ABS) should feel really nice.
Offline ideus
  • Björkö.
« Reply #1294 on: Mon, 06 April 2015, 10:07:48 »
In particular, I believe the caps and the case make a lot of difference in the typing besides switches and their springs, of course; also, I concur lubing and stickering add very few to the overall feeling of the board.
I am waiting for the Gaterons to put together the last Nerd60 I got from Gon. I will make blacks and blues with 65g gold springs both, on the Nerd60 with a semi ANSI/ISO layout (ANSI with ISO enter and 1.75u right shift) , vintage Cherry WoB alphas with purple or blue modifiers and a TEX acrylic machined case I am still waiting for from MD.
I will use the blues for the alphas and the blacks for numbers and modifiers; but, I am not sure about this mix, though.
Offline Photoelectric
« Reply #1295 on: Mon, 06 April 2015, 12:05:22 »
Will 55g be restocked any time soon?
Interested in the answer to this question as well.  Looks like the 55g variety wasn't produced for this round, but will it be made again sometime soon?
Offline DanielT
« Reply #1296 on: Mon, 06 April 2015, 12:31:37 »
55g was produced in R2 but sold out really fast. Talking with SPRiT I understood that 55g will be produced again.
Offline wlhlm
« Reply #1297 on: Mon, 06 April 2015, 15:19:54 »
Interested as well.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #1298 on: Mon, 06 April 2015, 15:30:50 »
Interested as well.
There's your answer
Offline sprit
« Reply #1299 on: Wed, 08 April 2015, 20:33:11 »
It was produced 80sets only in R2, all sold out.  If ppl want it may produced in quantity in late May.
« Last Edit: Wed, 08 April 2015, 21:23:33 by sprit »
