Author Topic: LF: phantom PCB, Filco or phantom-compatible case, possibly teensy  (Read 1680 times)
Offline berserkfan
  • Trade Count: (0)
HI
I'm looking for a Phantom PCB, Filco Case/ any case that will fit a phantom.
Since I'm looking to do a 7bit mod (will get the plate from somebody awesome), it's ok if you've cut the casing on the right side!
I can also buy the teensy if you have it.
No need for switches or stabilizers.
Would prefer a normal case, not aluminium or acrylic, to keep cost down and also because I don't have suitable cutters.
Offline Reckthor
  • Trade Count: (0)
    • PC Stuff
Re: LF: phantom PCB, Filco or phantom-compatible case, possibly teensy
« Reply #1 on: Tue, 18 March 2014, 13:51:40 »
Are you looking for this type of plate?
http://imgur.com/a/yVTi8
Offline berserkfan
  • Trade Count: (0)
« Reply #2 on: Tue, 18 March 2014, 15:08:06 »
I already have a 7bit plate. I could consider buying another 7bit plate, but that does not look like a 7bit plate at all. It's got a standard spacebar.
Offline MOZ
  • KING OF THE NEWBIES
  • Trade Count: (0)
  • Busy making stuff
« Reply #3 on: Tue, 18 March 2014, 15:38:11 »
I have a scarred PCB from MK, new, there are what should be cosmetic defects on the soldermask only. White color. I can ship to you for shipping price only. If it works, you can pay me $25 for it, if it doesn't you only lose the shipping cost.
