Author Topic: Remapping keys within OS X  (Read 1272 times)
Offline Imbulse
« on: Fri, 21 March 2014, 06:23:43 »
Hi all,
I figure I can't be the only person using OS X here!
Is there any way to make the top right hand keys of a Ducky Shine III so it can be used by the OS? The keys don't seem to have a mapping in the regular mapping table, so i'm not sure. The picture on the keys are generic pictures, a calculator, a PC, an envelope and a house. I'd love to be able to map them to things.
Thanks
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Remapping keys within OS X
« Reply #1 on: Fri, 21 March 2014, 07:14:40 »
Check out KeyRemap4MacBook. The name is ****ty, but the software itself is quite powerful and can definitely do what you want.
Offline QuadGMoto
« Reply #2 on: Fri, 21 March 2014, 10:55:02 »
Its setup is even rougher than the name. But it actually does work. None of your applications will even realize there's a difference. I'm using it to remap my Leopold numeric keypad. (It doesn't send the keypad codes, but now my software doesn't know that.)
Offline squarefrog
  • \m/_
    • Ergodox Layout Stats
« Reply #3 on: Fri, 21 March 2014, 13:27:02 »
Equally brilliantly named theres PCKeyboardHack which allows you to remap tricky keys such as caps lock. Combining the two is very powerful.
