Author Topic: G80-1838HPU/01 Trouble  (Read 3606 times)
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« on: Sat, 22 March 2014, 22:55:27 »
So here is my issue... My G80 is connected to a Perixx PS2 to usb and everything works great when typing.
Now when playing a game, after holding W for a few seconds it cuts out... If the hit space to jump, I start moving again but only for a few seconds...
Pulled case off and all connections look great.
HALP!!!
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: G80-1838HPU/01 Trouble
« Reply #1 on: Sun, 23 March 2014, 07:58:54 »
Might be worth trying a different converter — sounds like a converter fault.
Bore Awards
Offline blackbox
« Reply #2 on: Sun, 23 March 2014, 10:41:37 »
Agreed, Try another converter. Cannot see why it should by an keyboard failure.
The LAN table!
Offline mougrim
« Reply #3 on: Sun, 23 March 2014, 10:45:54 »
Try it with a PS/2 motherboard first - just to be sure.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline blackbox
« Reply #4 on: Sun, 23 March 2014, 11:24:57 »
Good idea, if he has one.
The LAN table!
Offline mougrim
« Reply #5 on: Sun, 23 March 2014, 11:26:56 »
There always one nearby :)
Offline blackbox
« Reply #6 on: Sun, 23 March 2014, 11:46:49 »
For us it is but that might not be the case for him.
The LAN table!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #7 on: Sun, 23 March 2014, 22:41:32 »
Thanks dudes! Gonna try out a new converter! Both my rigs are missing PS2 ports (z87 sabertooth and P8Z77 I deluxe)
You're killing me Asus!!!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Mon, 24 March 2014, 12:58:26 »
I would highly recommend the idinnovations ps/2 to usb. I got a couple when there was a groupbuy on here for them. I find them to be the best and don't suffer from frequent reset problem like many others.
Offline mougrim
« Reply #9 on: Mon, 24 March 2014, 13:02:34 »
Asrock z68 and i5 Sandy Bridge. With native PS/2 port. I'm OK for time being :)
Offline blackbox
« Reply #10 on: Mon, 24 March 2014, 15:19:43 »
I see. The solution is to buy an asus rampage 4 black edition to test native ps/2. or maybe not.
Good, I have an ps/2 adapter that i am satisfied with but I do not remeber the name of the converter.
The LAN table!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #11 on: Mon, 24 March 2014, 20:15:00 »
Thanks for the link Ivan! I'll be ordering one now!
Nothing wrong with SB! I still have a 2700K kicking! It's a good chip.
Well now I have a reason to get one... My wife thanks you for your help!  :))
