Author Topic: What Linux Distro do the Linux users of GH use?  (Read 1151108 times)
Offline Ridingmac
Re: What Linux Distro do the Linux users of GH use?
« Reply #2150 on: Thu, 26 July 2018, 23:07:49 »
Fedora on my laptop and desktop and porteus on usb for everywhere else.....when no linux is installed i bring my own
Sent from my SM-N915W8 using Tapatalk
Offline redleaf
« Reply #2151 on: Fri, 27 July 2018, 00:06:57 »
ubuntu on my web server
« Reply #2152 on: Mon, 30 July 2018, 05:56:23 »
I distro hop a lot at work - basically whatever has the packages I need and performs reasonably well.  For various reasons I need a GUI, usually running in a VM on my main workstation.
I was using Fedora, but switched back to Ubuntu.  One of our clients setup an Ubuntu server in Azure and I was encouraged to duplicate their setup to test our app in Azure.  Ubuntu seemed reasonably stable, so I setup an Ubuntu Mate desktop in a VM for miscellaneous purposes.
Although a lot of what I used Linux for I am now doing with Docker, like installing a certain combination of Python packages without corrupting the Python install on my main workstation.  Previously done in a VM, now done in Docker.
Offline SBJ
  • Tactile pls
« Reply #2153 on: Wed, 01 August 2018, 02:18:02 »
Docker seems pretty awesome, if you're a programmer.
Offline no, the other guy
  • actually, this guy
« Reply #2154 on: Sun, 05 August 2018, 13:17:47 »
I rarely have a Linux system around. Currently, I am evaluating Gentoo and I might keep it. The community is absolutely awesome and it does not force me to do anything, which is great.
« Last Edit: Fri, 21 September 2018, 06:22:06 by no, the other guy »
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
« Reply #2155 on: Tue, 07 August 2018, 10:24:23 »
Man alive. I leave my distro untouched for a couple of weeks, come back, and there's a snafu. I should never have installed the f**kin' proprietary Nvidia driver...
Offline Jackorias
  • Jack, UK.
« Reply #2156 on: Tue, 07 August 2018, 10:51:57 »
Only time I've ever used Linux is on my Raspberry Pi... so Raspbian! Has made me want to try other linux distros though.
Offline SBJ
  • Tactile pls
« Reply #2157 on: Tue, 07 August 2018, 11:07:40 »
I'm sure you could get some good recommendations as to where to start. And there's always the option of running them in a VM like Virtualbox.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2158 on: Tue, 07 August 2018, 11:18:29 »
Only had 9 updates on the 5th. Yet, one day later I had 300 updates waiting for me on the desktop, and 199 updates on the laptop. No AUR, all pacman.  0_0
« Reply #2159 on: Thu, 20 September 2018, 12:11:04 »
Sounds like a stupid question but how do I know what I'm using when it comes to booting these days?  I have a flashy UEFI bios and thought I was using it but the Arch install guide talks about adding grub to the list of UEFI OSes held in bios, accessed by a hotkey on boot.  I don't use this menu, instead I think I have grub installed on the MBR as has been the way things were done since grub took over from lilo.
Only confused because openSUSE is what I'm currently running and it has the 100mb partition windows created mounted at /boot/efi, so that's what I've copied :confused:
(In case anyone's trying to follow I have two drives - one dual boots Win7 for my old i3 and openSUSE, the other has win7 for my new mobo and I'm adding Arch to it)
Edit:  Succesfully used 'grub-install /dev/sda' which claims to use UEFI mode as it's default but to add Windows I had to use the msdos entry as that's apparently what my partition table is.  Was created by Windows 7 so I would have expected GPT but apparently not...  I still have no idea how my computer works but it does so can't complain!  So far I have firefox and audacity installed, not much use without any WM/DE :))
« Last Edit: Thu, 20 September 2018, 16:01:00 by suicidal_orange »
« Reply #2160 on: Thu, 20 September 2018, 12:24:52 »
I guess this is progress...
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2161 on: Thu, 20 September 2018, 12:55:01 »
Nice :)
Offline Leslieann
« Reply #2162 on: Thu, 20 September 2018, 18:51:00 »
If you open a disk partitioning program you should be able to see if it's partitioned using GPT (uefi) or MBR (dos). Windows 7 can use Uefi, but it's tricky to do and was really only done by a few OEM manufacturers, generally you don't see UEFI boot until Windows 8 or 8.1. Copying the UEFI parition or files will not make a disk UEFI, this goes deeper as to how the partitions are actually created and identified to the system.
Basically, if the disk was first initialized with Win7 or older, it's going to be MBR unless you specifically went in and purposely recreated the partition table (not the partitions) to GPT, and doing so will destroy the partitions and data on the disk (this does not wipe the data, do not use it and think your data is now safe!). Windows generally will not format it to something other than it already is and tends to default to MBR unless you are using 8.1 or Win10, so if you do want to convert it, setup your Windows install stick using Rufus and set the stick to use GPT or use a Linux Distro with Gparted to set the drive partitioning to GPT.
Grub works in UEFI and MBR.
All that said, it's not a big deal.
I've looked into it many times to see why GPT was supposed to be better, and not once has anyone really made any compelling argument as to why GPT is actually better. Yes, UFI has some advantages (less than people think) but UEFI is not GPT, it's just the preferred partitioning system for GPT, UEFI will boot MBR just fine.  What I wish they would do though is fix the darn bios/uefi load time, I find it insane that for all these "imrpovements", bios load times have gotten longer while the system load time has gotten shorter. At this point bios loading takes up almost 50% of my boot time.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2163 on: Thu, 20 September 2018, 21:31:56 »
I think I had dual boot issues when Windows tried to fix a 'boot problem'. Nope, in the future Windows will (if any) reside on a separate hotswap drive. I automate daily snapshots with Borgbackup but I'd rather not go through the trouble of restoring Arch. Even if it only takes a few hours--it's still a headache I'd rather avoid.
Offline Leslieann
« Reply #2164 on: Fri, 21 September 2018, 00:48:43 »
Arch, it's a headache.
Fixed that for you.  :))
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #2165 on: Fri, 21 September 2018, 04:24:00 »
Thanks for the explanation Leslieann - I've been a mainly Linux user for so long I don't really know what Windows does but Win7 creating an EFI partition lead me to believe it was using something new and flashy when it wasn't.  After a drive failure I read it was easier to install Windows first then Linux and sure enough it worked with all the 'newbie friendly' distros (no need to recover grub and sometimes Windows was even added automatically) so I've stuck with it.  Now I'm looking for something a bit more interesting I actually have to know - UEFI/MBR it is.
This is more worrying, I thought most people loved Arch?  Hopefully I'm with them not you :))
Boot live DVD/USB, mount and chroot to the installed Linux, run grub-install, reboot?  Windows only kills the bootloader, it's annoying but shouldn't take more than 15 mins to fix.  Unless you need to download/burn an ISO...
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2166 on: Fri, 21 September 2018, 06:16:16 »
Meh,  chrooting every other time I recieve a Windows update that needs multiple restarts is not my preferred cup of tea. You're braver than I am. :confused:
And automating a pacman log isn't that difficult. I use a wrapper script I wrote (5-10min) that records package names/date/size before every update on both of my arch boxes. I have had more headaches with my Debian netinstall to be honest. Trying to wade through all the bad ubuntu/debian advice has been a treat. Thankfully I'm only using Buster (deb10 works fine--It's just been a while since my last full debian install) to test out Proton/protontricks and a few esoteric scripts.
« Reply #2167 on: Fri, 21 September 2018, 06:21:45 »
I can only imagine that this is some kind of Stockholm syndrome. The way to a running Arch installation is so painful that they won't even dare to go anywhere else when it's done.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2168 on: Fri, 21 September 2018, 06:26:26 »
Arch is not for everyone.
« Reply #2169 on: Fri, 21 September 2018, 06:55:45 »
Pretty sure I've not had this problem this year, maybe win8/10 are worse though.  When I started in Linux you had to remember to update the config file and reinstall lilo after a kernel update (compiled from source after carefully going through the new feature options by hand) as lilo didn't read the options from a file as grub does.  Couple this with a small hard drive and the irresponsibility of youth meaning the old kernel was deleted without trace while the new one was compiling and the ratio of kernel updates (at least weekly to play with the latest patchset) to times you needed to do a liveCD/chroot recovery was probably 80%.  I feel like the old guy telling a 'back in my day...' story :))
I see.  So far it's ok - I'm typing this as a user in enlightenment and it was easier to get here than I remember the gentoo installation being.  Time will tell...
« Reply #2170 on: Fri, 21 September 2018, 06:57:54 »
Installing Gentoo only took me four days.  ;)
Offline Leslieann
« Reply #2171 on: Fri, 21 September 2018, 06:58:27 »
You're welcome.
I haven't messed with Win7 on GPT enough to tell you how it goes I only know it wasn't native to it, it was patched in long after launch, and that it doesn't install to it the same way Win8 does. I didn't bother experimenting with it because it really wasn't necessary. Usually if I want Win7 I just use MBR for everything and if I use anything newer I set everything to UEFI, there's no performance lost really.
I could spend the time to figure it out and mess with it, but generally I recommend people switch to 8.1 with an alternate start menu if they don't want to switch over to Win10 (which I don't blame them for). Win7 support is going to dry up fast, evangelists will try and keep it alive just like they did with Xp, but honestly, they can't, it's not up to them. At some point in the very near future if you want new hardware or peripherals you will be forced to update if you stick with Windows. While 8.1 it has fewer users (by A LOT), Win10 uses it's driver and power management subsystems so it can use the same driver most of the time so it's easy for companies to make one driver for both or you can force backwards compatibility.
I use Antergos which is basically Arch without all the installation hassle (still not as easy as Mint), but I'm familiar with and work with a variety of operating systems from Windows servers down to Arduino and Android (sooo many Isos on file). I don't hate Arch, I just tend to look at it as a hobby OS, it's great, it's fast, it's cutting edge, which is the problem. Stability is generally good until a developer forgets to cross a T or dot an I and crashes the system, or like last time, they didn't flag it to update grub after installing an update causing it to not boot. It has far fewer levels of checks than something like Mint, which if you like messing with operating systems can be downright boring due to how stable it is. I don't hate Arch, it's just more work to keep it running than something like Mint.
Use what works for you.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2172 on: Fri, 21 September 2018, 07:12:25 »
My Arch install took about 1.6 years to 'complete' :))
« Reply #2173 on: Fri, 21 September 2018, 07:42:28 »
Four days?!  I did it in two on a 2ghz pentium 4 laptop with 512mb back in the day :p
This, however, sounds like a different level of completeness - are you sure it's done?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2174 on: Fri, 21 September 2018, 07:58:37 »
Maybe. Though it might need a few more tweaks, heh.
edit - side note: (pre-hidpi binge) I tried Kubuntu and liked it but some calendar things were meh imo; I'll try KDE Neon instead (same startup ram--liveiso); Elementary is still not for me; and Pop OS might be the one. I won't be sure until I've exausted the possibility of using my bspwm fraken desktop with hidpi, and or I've actually installed all of the above. Some liveISOs ship with notificationy things pre-installed and some do not, etc..
« Last Edit: Sat, 13 October 2018, 09:10:42 by csmertx »
Offline iri
« Reply #2175 on: Sat, 27 October 2018, 17:27:48 »
Manjaro is #1 on DistroWatch for the last 12 months. Looks like it's been long since I have last checked that website.
-Ray Bradbury
« Reply #2176 on: Sat, 27 October 2018, 17:41:38 »
The DistroWatch "top" list only counts access statistics. The ranking is different. :)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2177 on: Sat, 27 October 2018, 17:47:24 »
Star Linux, Slackware, and Shark Linux are the top three reviewed distros of Distrowatch? Atleast Slackware has 141 reviews.. so that's probably legit--totally not botted at all.
« Reply #2178 on: Sat, 27 October 2018, 17:51:28 »
That's why DistroWatch is generally unreliable in the top lists. Slackware is quite legit though.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2179 on: Sat, 27 October 2018, 17:58:23 »
I see.
Offline iri
« Reply #2180 on: Sun, 28 October 2018, 06:16:17 »
Yeah, the fact that Manjaro gets twice as many hits as Mint was very surprising to me.
-Ray Bradbury
Offline _rubik
« Reply #2181 on: Sun, 28 October 2018, 10:31:14 »
I left Arch and went back to Debian some 3 years ago because I didn't have enough time in my day to keep up with it/fiddle with everything. I switched to Manjaro a few months back and (I think) I'm here to stay.
Not sure if there's a major difference, but the ease of installation/out of box feature set makes it perfect for someone who wants to use arch, but doesn't care too much about the 'little stuff'
Offline Leslieann
« Reply #2182 on: Sun, 28 October 2018, 17:18:48 »
One problem with Distrowatch stats is that only people looking for a different distro go there, not those who are perfectly happy with the one they have.There is also the obvious problem of people who have no idea that site even exists and still another problem with ranking on that site is age, some of the distros listed are no longer developed. Apricity (ranked 27) last saw an update 2 years ago and is marked inactive on Distrowatch.
Going based on Google (based on traffic, inbound links and Google rank), the most popular is:
1. Ubuntu
2. Mint
3. Debian
4. Redhat
5. Gentoo
6. Fedora,
7. Slackware
8. Suse
9. Arch
10. CentOs
Going by Alexa (which is based solely on traffic):
1. Ubuntu
2. Redhat
3. Mint
4. Debian
5. Cent
6. Arch
7. Gentoo
8. Elementary
9. Fedora
10. Suse
Note that Manjaro doesn't even make top 10 on either list, yet has almost as many votes as Mint (#2) and Elementary (#3) combined, that screams manipulation. I'm not saying Manjaro isn't popular, but to say it's almost as popular as Mint, Debian and Ubuntu combined? Not a chance.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
« Reply #2183 on: Sun, 28 October 2018, 17:25:58 »
There is.
Manjaro uses their own servers for updates, this makes them a bit less bleeding edge than Arch, which is good for stability, but not so good for zero day threats.
Compared to Arch it's way easier to install, though almost every time I used it I've had to fix their security key to get updates which didn't inspire a lot of confidence (seriously, WTH?).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2184 on: Sun, 28 October 2018, 17:27:40 »
I suppose I did the opposite. I used one Manjaro GUI tool to try to install the proprietary gpu rather than a few minutes on the arch wiki which caused me to fubar my graphics stack. So after eights months of Manjaro and installing arch in vms I finally made the switch to vanilla. Although, the Manjaro i3wm community edition and the Calamares installer are both pretty great.
As far as the differences between Manjaro vs. Arch: some package updates are tested a bit longer before release when compared to arch, and some are injected with Manjaro-ness (for better or worse). Completely different repos. So you might see less instances in which an application is borked due to dependency point releases. Or they might hold on to a package while they inject Manjaro-y css/xml/art assets/etc..
Offline Leslieann
« Reply #2185 on: Sun, 28 October 2018, 17:32:16 »
I tended to use the Cinnamon community edition, which is probably why I had issues with security keys, but still.
As for vanilla Arch... Just use Antergos.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline iri
« Reply #2186 on: Sun, 28 October 2018, 17:33:06 »
Anyway, I installed MX Linux and my battery life extended by 100%.
-Ray Bradbury
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2187 on: Sun, 28 October 2018, 17:56:37 »
Oh my, I swear I've used that Conky config before (MJRDarkConky?). I enjoy the heck out of Lubuntu but I do need to take MX for a spin one of these days. Debian based huh? Interesting.
Offline iri
« Reply #2188 on: Sun, 28 October 2018, 18:48:48 »
And no systemd!
-Ray Bradbury
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2189 on: Sun, 28 October 2018, 19:27:30 »
Nice. I guess non-systemd would be confusing at first when people need to restart server stuffs. I make use of a systemd weekly SSD trim timer--other than that timers seem like an industry thing. crontab -e ftw
« Reply #2190 on: Sun, 28 October 2018, 19:28:05 »
Now Gentoo has a systemd flavor if you insist.
« Reply #2191 on: Sun, 28 October 2018, 20:50:31 »
IBM just bought Red Hat.
Is anyone going to switch to, or from, Red Hat or a derivative because of this?
We use CentOS around here, which was absorbed into Red Hat a while ago.  Unlikely that we'll change.  I'm just hoping that IBM doesn't kill off CentOS to focus on Red Hat and cloud.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2192 on: Sun, 28 October 2018, 23:40:09 »
Holy moly, I feel for those Red Hat employees (indirect or direct) that read about the sale before the internal emails were sent out. And yea, Fedora is in my practical top five list for when I switch to hidpi.
« Reply #2193 on: Mon, 29 October 2018, 02:12:39 »
"What do you get when you add a Red Hat to Big Blue? You get a Big Purple Hat, obviously. I wonder if they're thinking of adding an ostrich feather?"
« Last Edit: Mon, 29 October 2018, 02:16:07 by Findecanor »
Offline iri
« Reply #2194 on: Mon, 29 October 2018, 06:24:07 »
ewwwww
-Ray Bradbury
Offline _rubik
« Reply #2195 on: Mon, 29 October 2018, 21:19:31 »
I think we'll largely be fine for a year or two before any major changes are made. After that, I'm banking SUSE starts developing an enterprise distro... no well and hell I'm relying on Ubuntu :puke:
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2196 on: Mon, 29 October 2018, 21:26:04 »
https://www.suse.com/products/desktop/
Offline _rubik
« Reply #2197 on: Mon, 29 October 2018, 21:39:53 »
Enterprise "Desktop"
Offline Belfong
« Reply #2198 on: Mon, 29 October 2018, 21:41:56 »
I’m hoping IBM wise up and leave Redhat alone, much like how every other successful acquisitions behave - eg Dell and VMware
Nice read:
https://www.cringely.com/2018/10/29/red-hat-takes-over-ibm/
« Last Edit: Mon, 29 October 2018, 21:44:57 by Belfong »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2199 on: Mon, 29 October 2018, 22:10:17 »
I'm not sure what you want me to say here. It's an Enterprise distro. And the support subscriptions are pretty reasonable.
Well, there's always SUSE Linux Enterprise Server
