Author Topic: What Linux Distro do the Linux users of GH use?  (Read 1120857 times)
Offline smknjoe
Re: What Linux Distro do the Linux users of GH use?
« Reply #450 on: Thu, 30 April 2015, 21:37:59 »
I've gone through many distros over the last ~15 years and I keep coming back to Debian or Debian variants like Ubuntu.
- If you want something that's almost as good out of the box that requires a little more know-how and is the epitome of FOSS, Debian is the way to go.
How much steeper would the learning curve be if I chose Debian with KDE?
Somehow, Canonical has become distasteful to me, but I do not want to jump through hoops of aggravation for silly ideology.
edit - a huge plus is a good user forum.
My experience was that the Ubuntu forum was generally friendly and helpful while the openSUSE forum was mostly snotty and arrogant.
You'll run across arrogance in much of the Linux world unfortunately. Most people are pretty cool though.
KDE shouldn't be any different other than KDE specific apps. I have only used KDE with Slackware in the last few years since I much prefer Gnome. It's "cool" to hate Canonical but it's hard to hate the contributions they have made to the Linux desktop. And the "evil" online search function is not even an option in Ubuntu Gnome. The Gnome distribution looks and feels just like Debian with better software compatibility for me. I'm still a big fan of Debian, but with the project I have going on right now I just needed to get something up and running quickly and easily and Ubuntu Gnome worked much better for me in this particular case than Debian did.
Unless you have some specific software you need to use, Debian should be just as easy as Ubuntu for the most part.
SSKs for everyone!
Offline smknjoe
« Reply #451 on: Thu, 30 April 2015, 21:47:44 »
...and for the user forums...I haven't used them in a long time. Debian and Ubuntu are cross-compatible for the most part though. So, you could use either one or both.
SSKs for everyone!
Offline iri
« Reply #452 on: Sat, 02 May 2015, 07:14:27 »
I use both interchangeably now, but when given the choice, I usually pick Ubuntu.  Keep in mind that I never use a GUI with Linux, so I just care about ease of use and package availability.
i always use GUI with linux. this is why i have cinnamon desktop installed on my work macbook. looks better than mac os .
-Ray Bradbury
Offline Ngt
« Reply #453 on: Sat, 02 May 2015, 08:27:30 »
I use Ubuntu with Gnome3 at work and at home I use windows because the games I played are not available on Linux otherwise I'll always been on Linux.
Offline ttzhou
  • in your base, belonging
« Reply #454 on: Sat, 02 May 2015, 12:38:13 »
Get two hard drives. One has Linux the other Windows. You can use syslinux, which is a much cleaner and understandable boot manager, IMO, to be able to select which hard drive to boot. At least that way you can use the superior kernel at home as well.
Offline jerue
  • (Whenever that happens :P)
« Reply #455 on: Sat, 02 May 2015, 15:39:49 »
While I normally hop around Windows and OS X, I did put Ubuntu on my work laptop (boots alongside Windows) and I have a netbook handling my networking setup (it acts as a bridge).
« Reply #456 on: Sat, 02 May 2015, 19:39:13 »
So, my son and I are building a new/used computer for him. We have it together, 2 hard drives, 1 each for Windows (not yet installed) and Ubuntu 14.04. I went back to Ubuntu/Unity for the sake of simplicity and compatibility.
The installation went fine, and the icon shows a proper internet connection, but it is not really there. (PS - this is true with a real ethernet wire as well as a USB wireless dongle)
If you click on Firefox, it hangs and does nothing.
Type "apt-get" anything and you get nothing.
Is there a way to download and install Firefox on another computer and install it from a flash drive? I suspect that the problem is the browser software itself.
The Ubuntu forum's "networking" section is so loaded down with "wi-fi connects but no internet" questions that I do not expect a valid answer any time soon.
- D Trump 2026-09-28
Offline smknjoe
« Reply #457 on: Sat, 02 May 2015, 19:44:21 »
Yes you can download for Ubu/Deb 32 or 64bit and copy to a flash drive. It's most likely not a problem with the browser though. The network manager was a little buggy in Ubuntu 14/15 until recently. I would try just rebooting the machine first.
What do you get with "sudo ifconfig eth0" (for Ethernet)?
Edit: do you get a valid IP for your LAN setup? You don't have to post all of the output here if you don't want to.
 ...if you do have a valid IP can you ping stuff on your LAN and the Internet? ie. "ping -c 5 10.0.1.1"  or  "ping -c 5 8.8.8.8"
Edit #2: If you plan on using Win7 or higher I would install Windows first so you can use GRUB (or Lilo), the Linux bootloader, instead of the Windows bootloader. I've had problems with the Windows bootloader seeing Linux installations before.
« Last Edit: Sat, 02 May 2015, 20:28:52 by smknjoe »
SSKs for everyone!
Offline smknjoe
« Reply #458 on: Sat, 02 May 2015, 19:47:56 »
Also, I just installed the new version of Debian 8 earlier today and it's pretty awesome. So far no trouble getting my hardware or software to run...
SSKs for everyone!
« Reply #459 on: Sat, 02 May 2015, 20:23:12 »
fohat, if you have a working windows system, you can use Universal USB Installer with a downloaded ISO of your preferred distro to install it onto a USB stick. I use it all the time.
Offline Ngt
« Reply #460 on: Sun, 03 May 2015, 05:24:31 »
Well I would have to reboot every time I want to play so it is not desirable IMO. I did have 2 partitions on the machine. One for Ubuntu and the other one for Windows but the result was that I never loaded Ubuntu pretty much.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #461 on: Wed, 13 May 2015, 19:46:03 »
I've been using arch for a little while now, and I'm down to try  another Distro, any suggestions? I've tried Ubuntu, and mint.
Offline user 18
« Reply #462 on: Wed, 13 May 2015, 20:24:00 »
Debian Jessie is a lot of fun -- probably not as bleeding edge as you're used to with Arch. If you use the netinstall and choose to install as little as possible when prompted, you'll end up just installing the core distro, and you can build it up much like you would with Arch.
I can't think of another distro off the top of my head that I'd recommend for desktop use. If you're looking for something a little more special than base Debian, BunsenLabs is the spiritual successor to CrunchBang Linux, and it seems to be providing an excellent experience, although it's still in development and I've yet to try it out myself. Bunsen is essentially Debian Jessie with a few decisions already made for you, but it gets you closer to a functional system than a straight Jessie netinst.
Avatar by ashdenej
« Reply #463 on: Wed, 13 May 2015, 21:34:07 »
+1 for Debian Jessie (8.0) - working well for me on a desktop (in a VM, btw).
Offline Air tree
« Reply #464 on: Wed, 13 May 2015, 22:14:36 »
Alright, I'm going to do a full wipe and give it a go a little later, I'll share my thoughts after using it for a little while.
Offline iri
« Reply #465 on: Thu, 14 May 2015, 06:16:07 »
out of the debian family! try gentoo.
-Ray Bradbury
Offline osi
« Reply #466 on: Thu, 14 May 2015, 06:30:37 »
slackware!
Offline iri
« Reply #467 on: Thu, 14 May 2015, 06:51:40 »
yeah, or slackware.
-Ray Bradbury
Offline ttzhou
« Reply #468 on: Thu, 14 May 2015, 06:51:49 »
If you're gonna try those distros mentioned above, also try Arch LFS (joking)!
« Last Edit: Thu, 14 May 2015, 08:10:03 by ttzhou »
Offline iri
« Reply #469 on: Thu, 14 May 2015, 07:45:18 »
which he has been using for a while.
-Ray Bradbury
Offline ttzhou
« Reply #470 on: Thu, 14 May 2015, 08:09:42 »
sorry didn't see the quote, was on phone  :(
Offline kaminbobby
  • -_^
« Reply #471 on: Fri, 22 May 2015, 00:11:20 »
Arch linux :p
-_^
Offline Air tree
« Reply #472 on: Fri, 22 May 2015, 16:24:42 »
Rocking Debian like everyone said to do, and after making it all pretty, it's really nice!
Offline davkol
  •  Post Editing Timeout
« Reply #473 on: Fri, 22 May 2015, 17:18:04 »
The upgrade to Kubuntu 15.04 seemed like a major ****-up at first, but it's okay after all… only the panel/systray is quite useless in Plasma 5.3, and I've had to get rid of (surprise-surprise) systemd.
Offline micr0n
« Reply #474 on: Fri, 22 May 2015, 17:38:43 »
For home, I mostly use windows with cygwin.  All my VMs use ubuntu server for various software testing I do.  I can also still use linux software as well with good old x11.  The only real reason for windows is gaming and steam.
Offline Air tree
« Reply #475 on: Fri, 22 May 2015, 17:41:44 »
I hope linux starts getting some real support and a large backing. I would love to use linux as my only OS. But I like to game and all that...
Offline rm-rf
« Reply #476 on: Fri, 22 May 2015, 18:16:59 »
its been growing a lot the past few years.
went to this a few weeks back...
http://linuxfestnorthwest.org/2015
take a look at their schedule. 2 days of seminars and more
its always fun, and every year it gets bigger and bigger. people come from all over.
and there is always a huge after party, which is pretty damn fun.
great for networking.
although the first one i went to in 1999, it was just 5 guys in a room talking about BBS's...
not so interesting. but this year there was a massive turn out. i think there was 3,000 + people that showed up
looks like there may be something similar in Seattle WA, in October.
http://seagl.org/
their site seems a bit non informational.
and i've noticed lately on steam a lot more products being available for linux
but i usually don't play games when in linux, and if i do its just in a vm anyways :P
but my distro of choice would probably be gentoo...
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #477 on: Fri, 22 May 2015, 19:17:18 »
Slowly but surely my friend  ;D
There are a lot of games running on Linux these days with more being added everyday.
Offline rm-rf
« Reply #478 on: Fri, 22 May 2015, 19:41:50 »
i think with steam kicking off towards linux there should be more to come in time.
Offline user 18
« Reply #479 on: Fri, 22 May 2015, 19:57:15 »
Unfortunately, linux still only has less than 1% of Steam installs, and OSX only has around 3% (April Steam survey). It may come, but it's not coming quickly.
Avatar by ashdenej
Offline Air tree
« Reply #480 on: Fri, 22 May 2015, 20:07:03 »
We would probably see a lot more if tripple A games where on linux. I'm betting a lot of people would install a free OS that you can play GTA V on..
Offline user 18
« Reply #481 on: Fri, 22 May 2015, 20:14:21 »
Well we've got a bit of a self-fulfilling prophecy here. Developers won't develop for platforms that have low market share, and gamers won't switch to a platform that doesn't have games.
Most Valve games, and a good number of indie games work on linux, although I've personally had a lot of trouble making them work as well as on Windows.
Avatar by ashdenej
Offline Air tree
« Reply #482 on: Fri, 22 May 2015, 20:33:07 »
I was hearing reports of people having much better performance on CS GO with linux than windows with Nvidia, but AMD seems to be lacking on their driver front even more so with linux.
I'm glad Nvidia has stepped up to the plate for drivers for Linux.
Offline Ngt
« Reply #483 on: Fri, 22 May 2015, 20:37:00 »
Same situation here ^^.
Offline rm-rf
« Reply #484 on: Fri, 22 May 2015, 20:44:45 »
i think i need to install nix now.
thanks. haha
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #485 on: Fri, 22 May 2015, 20:45:38 »
I used to be all about AMD...until Nvidia came along and crushed them.
Warms my heart to see a company pushing the Linux market forward.
Offline ttzhou
« Reply #487 on: Sat, 23 May 2015, 10:06:53 »
stop windowsing, ie stop gaming :)
dual hard drive boot master race.
well, except for windows stupid pesky UTC clock correction.
Offline rm-rf
« Reply #488 on: Sat, 23 May 2015, 10:12:30 »
dual boot is crap!
it interrupts workflow having to reboot.
i've decided that i just need one computer dedicated to games, and one for crunching.
Offline ttzhou
« Reply #489 on: Sat, 23 May 2015, 10:40:05 »
dual boot is crap!
i do my crunching on my laptop. i just can't stand using windows as an OS. but it doesn't make sense to buy ANOTHER machine just for that.
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #490 on: Sat, 23 May 2015, 10:44:55 »
dual boot is crap!
You can never have enough computers.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #491 on: Sat, 23 May 2015, 12:51:06 »
Use winex for gaming. I got 2x the performance on Linux playing WoW instead of windows on the same hardware.   There is no reason to not use Linux for gaming.
Offline micr0n
« Reply #492 on: Sat, 23 May 2015, 13:00:49 »
dual boot is crap!
I do agree that it does interrupt the workflow as well.  Hence the use of a mini VMware data center and cygwin.   I can use both environments at once without stopping a beat.  The dual boot method was just to inefficient for me.
Offline Ngt
« Reply #493 on: Sat, 23 May 2015, 19:26:14 »
Are you running it on wine?
« Reply #494 on: Sat, 23 May 2015, 19:52:55 »
dual boot is crap!
This - been there, done that several times.  Just doesn't work.
Now I have 2 or 3 computers, each dedicated to a single operating system.
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #495 on: Sat, 23 May 2015, 20:18:09 »
dual boot is crap!
It is also reasonably cheap to build computers for certain tasks (gaming, general, media, storage, etc.) You can always find decent components to build something at a price tag that doesn't make you cry.
« Reply #496 on: Sat, 23 May 2015, 20:26:20 »
dual boot is crap!
My biggest problem is now multiple monitors and keyboards on a moderately sized desk.
Offline Air tree
« Reply #497 on: Sat, 23 May 2015, 20:26:23 »
I'm just going to cave in and get windows 10 once I build my PC.
I was going to install linux, but Candy Crush sold the power of the new operating system.  :)
Offline iri
« Reply #498 on: Sun, 24 May 2015, 07:17:27 »
amen.
-Ray Bradbury
Offline nova779
« Reply #499 on: Sun, 24 May 2015, 11:00:25 »
I really miss crunchbang so I started using crunchbang++ and really enjoy it
