Author Topic: What Linux Distro do the Linux users of GH use?  (Read 1150820 times)
Offline iri
Re: What Linux Distro do the Linux users of GH use?
« Reply #700 on: Wed, 17 June 2015, 17:08:01 »
Many arch users here. Anyone tried to replace systemd with OpenRC or something?
I want a distributive which is 1) not Gentoo 2) can be run without systemd 3) allows fine tuning. My ultimate goal is working all day on a single charge.
-Ray Bradbury
Offline 1o57
  • %10000100001
« Reply #701 on: Wed, 17 June 2015, 17:55:35 »
I kind of collect OSes, like a fish tank but with VMs instead of fish.  It's kind of a hobby.
Offline godly_music
« Reply #702 on: Wed, 17 June 2015, 23:22:20 »
Check out the two stickies with Manjaro OpenRC spins.
Offline sth
  • 2 girls 1 cuprubber
« Reply #703 on: Thu, 18 June 2015, 00:14:32 »
void linux!!! it feels like the olden days of arch (in a good way), it's fast, it uses runit and it has a ports collection.
Offline iri
« Reply #704 on: Thu, 18 June 2015, 09:47:42 »
yeah, thanks, i know about manjaro.
-Ray Bradbury
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #705 on: Fri, 19 June 2015, 09:23:23 »
I installed Ubuntu today, and everything works perfectly! I know, it's a small victory, but hey, I'm excited. I'm enjoying Linux already. :)
This is really the point of Ubuntu. It just works, pretty much every time. People can disparage it all they want for being a corporate distro, but IMO Canonical has done more to spread Linux to the desktop than anyone else.
I tend to agree with you.  Ubuntu has always been the Linux Easy Button and because of that more people have started trying a Linux install on their desktops.  It almost always just works.  I used to like it a lot more back when it was a lot lighter, but it is still alright...
Offline iri
« Reply #706 on: Fri, 19 June 2015, 16:05:46 »
I am now writing this from Manjaro on my macbook.
Concerning the battery life, here is the blog post whose author claims to reach almost 9.5 hours of battery life (he is using Arch).
-Ray Bradbury
Offline cakewizard
  • "**** me, that cow's got udders!"
« Reply #707 on: Sat, 04 July 2015, 05:37:46 »
Debian + i3wm on my desktop, Arch + i3wm on a laptop, OS X/Debian on a MacBook.
<3 Tiling window managers.
Cherry G80-3000, Apple Standard Keyboard
OS X, Debian + i3wm. GNU/Linux, pronounced "whatevs".
Offline flabbergast
« Reply #708 on: Sat, 04 July 2015, 06:18:54 »
Thanks guys - I didn't know about void linux before and I love it!
« Reply #709 on: Sat, 04 July 2015, 07:06:53 »
An actual new distro?  It's been a while since I've heard of one of them, will have to give Void a go!
On a sidenote I've tried Fedora, Suse and a couple of Ubuntu derivatives in the past year and none of them successfully boot my Windows installation without editing grub files.  Perhaps I did something weird but it doesn't seem newbie friendly and reminds me of the distant past when I installed Mandrake Linux (renamed to Mandriva in 2005, this was years before that) on the family computer, hosed the bootloader, and landed up reformatting to get Windows back and lost everything :-[
Offline user 18
« Reply #710 on: Sat, 04 July 2015, 13:24:02 »
This is my usual process:
1. Shut down the PC
2. Unplug the drive containing the Windows installation, use a second motherboard port to plug in the drive you're going to put linux on.
3. Install linux to the new drive, install grub (or other bootloader) when prompted during installation.
4. After your linux is up and running, shut down the PC.
5. Plug the hard drive containing the Windows installation back in.
6. Boot into linux (grub will not detect your Windows install yet).
7. Open a terminal, run sudo update-grub.
8. You should now be able to boot the Windows installation.
That has always worked for me for getting grub to pick up the previous installation. If the grub menu is not showing at boot for some reason, I believe editing configuration files will be necessary.
Avatar by ashdenej
Offline sth
« Reply #711 on: Sat, 04 July 2015, 14:55:42 »
yessss do it!! the installer is fudged up so you have to be a little deft but once it's on your disk it is the best thing since cup rubber
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #712 on: Sat, 04 July 2015, 17:10:24 »
I read that as daft instead of deft and got seriously confused. I must be daft.
« Reply #713 on: Sat, 04 July 2015, 17:24:42 »
1. Shut down the PC
Thanks, sounds like we have the same method - multiple drives are handy.  Grub always makes an entry for Windows but it just sits there rather with a black screen rather than booting it.  It's been a while so I just  tried to find what I had to bodge but everything's changed (running Fedora atm) so seems it now autodetects correctly, or it's copied my bodge when it upgraded...
Void is downloading as I type so I will find out shortly :)
Edit:  The Void installer uses NCurses?!  Haven't seen that since Slackware :))
It wants an EFI partition though, and the iso I download doesn't come with fdisk, cfdisk or parted so I couldn't make one.  Is there anything else I should know about the installer?
« Last Edit: Sat, 04 July 2015, 18:23:26 by suicidal_orange »
Offline sth
« Reply #714 on: Mon, 06 July 2015, 01:49:56 »
i dont know about parted but the iso i had came with cfdisk. you might need to be root to run it. i am   running bios instead of uefi because lazy so i haven't had to deal with that crap in a while
you should however be able to download and install anything on the live CD using xbps-install <pkgname> as root.
« Reply #715 on: Mon, 06 July 2015, 19:51:12 »
I went with the Enlightenment iso, it has firefox and a terminal thing but that's about it :))
Void is installed but didn't overwrite grub like I asked it to.  Running grub2-update on my old Fedora install finds Void, but it doesn't actually add it to the list.  Trying to load Void manually from the grub console when booting also doesn't work as I can't make it find the root fs (it thinks sda-f are removable so seems to be picking USB card reader first, but later letters also don't work)
Next on the list to try is chrooting into Void and installing grub there, then if still no joy it's "dd if=/dev/zero of=/dev/sda" time (if you don't know what this does don't be tempted to run it!)  I've not tried a proper distro since all this UEFI stuff came into being so not sure what I'm running and that's worrying, so the last option might actually be the best.
Offline t888
  • CONNECT 14400 ... Welcome to Skynet
« Reply #716 on: Sat, 11 July 2015, 11:13:09 »
I use Mint Linux on my notebook PCs, Raspian on RPi (though I might try Fedora Remix on RPi2), and CentOS/RHEL or Amazon Linux for professional stuff.  I used to like to try different distributions, but now I just want something that works for my purposes.
Unicomp ♡ HHKB Pro 2 ♡ Realforce 87u 55g
Offline Vizir
« Reply #717 on: Sat, 11 July 2015, 15:06:54 »
Pretty much what I do with my machines at with and home.
« Reply #718 on: Sun, 12 July 2015, 17:27:23 »
Void has finally installed in a bootable state and I'm pleased to report it is the first distro to add a working entry for Windows install.
The only problem is that the installation from the Enlightenment ISO is so bare I'm lost - the terminal doesn't even have double-tab autocomplete enabled, and my arrow keys are sending character codes so I have to type everything manually and perfectly :))
Not sure whether this is a good thing as I'll have to relearn Linux and type better, or if it's just going to annoy me.
Edit: updated and the flashy double tab now works, as do arrows.  Guess the installer is newer than the image it installs...
So far - no audacity.  This is not acceptable but if it's the only problem I encounter I'll try and get it added to the repository.
Edit 2: Failed to restart after updates, even using the old kernel.  Some breakage is to be expected but this is too much I think.
« Last Edit: Sun, 12 July 2015, 18:22:19 by suicidal_orange »
Offline sean
  • Mechanical newb
« Reply #719 on: Sun, 12 July 2015, 18:19:20 »
I use Arch on my desktop and laptop and Debian on my server.
I've never heard of Void but I think I need to check it out now.
Offline sth
« Reply #720 on: Mon, 13 July 2015, 01:20:40 »
installer does not enable bash completion by default, esp. not for root and root runs dash, not bash by default.
also i have audacity, i might have built it from the packages but it works fine, wish i could be more helpful. hopefully it will work out for you, if not... well, there are lots of distros   :cool:
« Last Edit: Mon, 13 July 2015, 01:40:37 by sth »
« Reply #721 on: Wed, 15 July 2015, 16:45:54 »
So finally got back to this, there's a new Void iso so I installed from that and guess what?  It's renamed all my hard drives and put the USB card reader first.  I guess that's why it didn't reboot last time, though fstab is using UUID so it shouldn't have mattered.
Just as a warning to anyone thinking of installing watch out if you're adding partitions without reformatting them - despite saying no to format it marked them all as "NEW FILESYSTEM" when I chose the install option.  Going back to the mount point bit and re-doing the partition I did want formatted corrected the issue.  So close to losing all my stuff! :eek:
Edit: Audacity is now available and installing!  I'm thinking the Enlightenment iso must have been really old...
« Last Edit: Wed, 15 July 2015, 17:08:37 by suicidal_orange »
Offline StormyMonday
« Reply #722 on: Sat, 25 July 2015, 07:07:18 »
I started with Red Hat, back in the mid-90's. Even though I like to explore, I've always had Mint on a machine, since ver. 7. I'm currently running Mint 17.2 / Cinnamon on my Lenovo T420.
 I've been tinkering with FreeBSD lately and it's starting to grow on me.
Offline dndlmx
« Reply #723 on: Wed, 05 August 2015, 05:44:41 »
Anyone using a 4K monitor? What distro or desktop environment does high DPI scaling?
Offline sth
« Reply #724 on: Wed, 05 August 2015, 06:47:07 »
cool thanks for the info - ive been running a build from void-packages. what version is in xbps repos?
Offline iri
« Reply #725 on: Wed, 05 August 2015, 06:57:39 »
Let me look that up for you.
-Ray Bradbury
Offline dndlmx
« Reply #726 on: Wed, 05 August 2015, 07:52:08 »
I mean it says it works but it could be total ass.
Offline sth
« Reply #727 on: Wed, 05 August 2015, 07:55:35 »
what is being a linux user if not one of the two:
you buy expensive new stuff and figure out how to get it working
you buy old stuff and stay conservative (me)
Offline iri
« Reply #728 on: Wed, 05 August 2015, 07:55:37 »
It's total ****.
To answer your other question -- I use Apple's 4K monitor.
-Ray Bradbury
Offline dndlmx
« Reply #729 on: Wed, 05 August 2015, 09:03:44 »
Apple's 4K monitor.
You mean you got the 5K iMac?
Offline iri
« Reply #730 on: Wed, 05 August 2015, 09:19:21 »
I use the macbook pro.
-Ray Bradbury
Offline Goggles2114
    • Cheapie Theatre
« Reply #731 on: Wed, 05 August 2015, 09:31:27 »
I use xbuntu 14.10
Then again I've used Mint, Vector, Crunchbang, Peppermint, puppy...
I'm on a single core atom as my linux deice so always on the hunt for something that balances usability with leanness. Just trying to keep ye olden CR48 running. It's been a fairly good box.
Offline dndlmx
« Reply #732 on: Wed, 05 August 2015, 10:59:20 »
Ha the proto-Chrome Book. Nobody kept Chrome OS, they just wanted a free computer to run X distro.
Offline sth
« Reply #733 on: Wed, 05 August 2015, 12:50:08 »
I use xbuntu 14.10
most egregiously large ctrl alt to grace a laptop
Offline Goggles2114
    • Cheapie Theatre
« Reply #734 on: Wed, 05 August 2015, 14:24:31 »
It was less 'do away with chrome OS' because i ran with Chrome OS until the commercial products shipped. It was more 'I needed someting because this was the only working computer.'
I've kept it since because decent backup.
« Reply #735 on: Wed, 05 August 2015, 14:35:33 »
I kept Chrome OS on mine. :(
Until the hinge broke, and the battery wouldn't charge anymore. :'(
Offline Vizir
« Reply #736 on: Wed, 05 August 2015, 20:50:00 »
Linux Mint Cinnamon does work, it might not always auto-detect, but you can enable/disable scaling in the preferences pane.
Offline iri
« Reply #737 on: Thu, 06 August 2015, 06:51:05 »
It's Cinnamon, not necessarily in Mint. Supports HiDPI out of the box.
-Ray Bradbury
« Reply #738 on: Sat, 08 August 2015, 18:23:32 »
I use xbuntu 14.10
Thanks for reminding me about Crunchbang. It's so sad that project was finally abandoned; that was a great distro and it is still influencing other distros to this day. If not for #!, I probably would have never learned how to write a Conky script, so I'm thankful for that. Speaking of influence, I've just got to get around to checking out ArchBang. One of these days ...
Offline user 18
« Reply #739 on: Sat, 08 August 2015, 19:18:31 »
I use xbuntu 14.10
BunsenLabs has a pretty solid alpha build of Hydrogen out, I need to download and play around with it at some point, but so far I really like the look of what that team has done: http://crunchbang.org/forums/viewtopic.php?id=39994&p=1
Avatar by ashdenej
Offline godly_music
« Reply #740 on: Thu, 13 August 2015, 01:22:22 »
Related question. I'm looking to grab a Thinkpad X200. I know it's old, but it's on eBay for 100€ whereas an X201 would be 150ish. Am I crazy for thinking a P8600 2,4 GHz dual-core is enough for most Linux tasks?
Anyway. As far as operating systems to go with it, I'd like some input from people who use that laptop. Was thinking either Manjaro as a replacement for Arch (I don't wanna deal with a manual install. RIP install scripts.), Crunchbang++ representing Debian or possibly Void. Can anyone tell me if all your important hardware worked properly on those distros? Mute-button I can do without or fix it by hand. Low power draw is very important. I'll probably undervolt it as well.
Offline user 18
« Reply #741 on: Thu, 13 August 2015, 10:11:35 »
The machine I'm using right now is running Crunchbang on a six year old machine with a 1.6 GHz single core and 2GB of RAM. I find it to be quite capable as long as I keep those limits in mind. I've never used an x200 myself, but Crunchbang in my experience has been very kind to machines without much in the way of system resources.
The only hardware function my machine had issues with was the button to disable the trackpad. WiFi, audio, video, SD card reader, laptop brightness control, etc. all worked out of the box, so to speak.
Now, #!++ is not crunchbang, so I can't say for certain how it handles similar challenges. But I know it was designed to meet similar criteria, so I would say it has a reasonable chance of working similarly.
Avatar by ashdenej
Offline Leslieann
« Reply #742 on: Thu, 13 August 2015, 18:20:04 »
Traditionally, IBM and Lenovo has had good support for Linux.
I can't speak specifically for the X200, but I can for the individual parts in it. In terms of speed, my Sony has a P8500 and runs Linux just fine (good processor actually). Where you may have issues is with the wireless card, it's probably going to need the Iwlwifi driver, which frankly, I think isn't all that great, it works, but shutting down can be slow, it's better than it used to be though. Other than that, you should have no problems. Worst case, buy a different wireless card for $10. If you have an old SSD, throw that in, newer ones will not be any faster due to the Sata2 speed. With that, the system will perform similar to a modern mid-level notebook, or at least feel like it.
I initially wrote a post about encouraging you to reconsider the x201 for future proofing reasons but after researching it, there's almost no difference between the two. Both have an 8gig limit, ddr3, sata2, same screen resolution, Win10 support... Even battery life and processing power is similar. The only real benefit over the x200 is that the x201 adds a touchpad, 300meg wifi (vs 150), and more readily accepts 8gigs of memory (the x200 requires specific memory and/or bios tweaks to do so).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Online tp4tissue
« Reply #743 on: Thu, 13 August 2015, 19:12:47 »
I really don't think a p8600 makes a good lappy these days..
In the USA,  we have  boat loads of used T420, for  $185 USD..  this is almost always on sale at this price..
T420 has 2520m.. which is more than twice as fast as the p8600
But it's larger than the x201..
I still roll an x220 myself, also a 2520m..  but it was one of the first to get IPS screen albeit low res.
Offline godly_music
« Reply #744 on: Fri, 14 August 2015, 00:31:36 »
I'm kinda sold on the ultrabook form factor so it'd be either the X200, the 201 or the 220 I suppose. But performance isn't free and the question is - do I really need it? Running Linux of all things? That means work, word processing, internet, youtube, social, vintage and indie games.
You're right, the P8XXX line is pretty damn good. They stay cool and don't draw much power. Of course the various i5's give you a performance bump, but I'd have to pay 150-180 for one of these other two laptops.
Offline merfed
« Reply #745 on: Fri, 14 August 2015, 14:25:09 »
I recently switched over to arch for my T430 and I'm liking it a bit more once I ditched the DE. It's mainly just for small projects an school related stuff. For actual classes I still have to use W7, and that's still what I'm using at home for daily use, but I am enjoying what arch has to offer.
Pok3r (Clears) // Noppoo Choc Mini (Black) (Blacks) // Noppoo Choc Mini (White) (Blues) // Poker X (Browns) // KBT Pure (Reds)
Offline iri
« Reply #746 on: Fri, 14 August 2015, 18:45:08 »
you ditched the DE for what?
-Ray Bradbury
Offline user 18
« Reply #747 on: Fri, 14 August 2015, 18:50:28 »
My guess would be for nothing -- DEs are optional.
Avatar by ashdenej
Offline Leslieann
« Reply #748 on: Sat, 15 August 2015, 01:29:57 »
High end C2D's were extremely fast, faster than most people realize, a P8600 keeps up with mid level second gen Core I5's and is barely slower than a 3rd gen.
Hardware simply has not marched on like you think it has since the Core2 era. The primary focus has really been on power consumption, performance improvements have come from SATA3, more memory, and SSD's. Not so much from the processors really.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline merfed
« Reply #749 on: Sat, 15 August 2015, 02:16:44 »
Yep. I use Openbox for window management.
