Author Topic: LightSaver V2 Group Buy  (Read 744785 times)
Offline elton5354
Re: LightSaver V2 Group Buy
« Reply #300 on: Wed, 30 April 2014, 01:50:46 »
https://docs.google.com/spreadsheet/pub?key=0Akw9rY8oi1o6dDZDVE9IWWc0OGNkc19hcGx6TjN3c2c&single=true&gid=2&output=html
Here's a form for you guys to check it over and let me know if there are any errors..
Offline pasph
« Reply #301 on: Wed, 30 April 2014, 03:23:28 »
Can you add to my order 2 Stabilizer Set and 15 Duck Blockers?
Offline dragonken
« Reply #302 on: Wed, 30 April 2014, 06:03:49 »
Hi, what's the dead line to fill the assembly form?
Regards,
Ken
Offline witbliz
« Reply #303 on: Wed, 30 April 2014, 06:19:38 »
Hi Elton, thanks for the spread sheet which made me realized I need the stabilizers as well. Two sets. One for light saver and the other as spare. Also would want to buy the spare plate just in case my layout needs modifying.
Offline elton5354
« Reply #304 on: Wed, 30 April 2014, 08:37:31 »
I'd try to finish filling the assembly form in a week or 2.
If you are getting assembly, you don't need to buy any stabilizers, they're included. If you want extras, I think it's okay though. Max 2 sets.
Offline tadbitnerdy
« Reply #305 on: Wed, 30 April 2014, 11:18:41 »
Checked the spreadsheet.  Order is all good!  Thanks Elton!
Offline Zombly
  • Zombie Enthusiast
« Reply #306 on: Wed, 30 April 2014, 13:08:27 »
I'm pretty sure my order looks good, so the cost so far is 295 + 70 (assembly) + shipping?
In the process of my custom Zombie board
[WTB MX Zombro's]
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #307 on: Wed, 30 April 2014, 13:24:10 »
my order should be silver, not gray. I need whichever plate supports 1.25x,1.25x,1.25x,6.25x,1.5x,1.5x,1x,1x which I believe is the original plate and that spreadsheet shows me with the new plate? thanks
Offline elton5354
« Reply #308 on: Wed, 30 April 2014, 13:35:16 »
Weird, I'll fix it. No plates will fit that layout. Read my previous posts please. You can do that without a plate.
Offline Lastpilot
  • Power stance
« Reply #309 on: Wed, 30 April 2014, 13:58:15 »
My order should be gray, with original plate. I will go ahead and refill assembly form since it looks like it didn't go through.
Offline elton5354
« Reply #310 on: Wed, 30 April 2014, 14:05:11 »
Oh ok I seem to be missing changes from posts. Please PM me the changes.
« Reply #311 on: Wed, 30 April 2014, 14:56:06 »
I'm curious why some people are getting 15 blockers??  Is it just to have extras?
Offline digi
  • elite af tbh
« Reply #312 on: Wed, 30 April 2014, 15:14:21 »
So which 6.25x space bar layout option(s) do I have that uses a plate?
Offline rapax24
« Reply #313 on: Wed, 30 April 2014, 15:20:14 »
i saw there were only 15 available in the first post but now i see around 30 orders.
is there any chance to buy one of these keyboard? maybe OP ment 15 per colour choice?
Offline elton5354
« Reply #314 on: Wed, 30 April 2014, 15:24:31 »
Digi, please look at the layout options on the assembly form which you filled out...
It increased to 30
Offline ninjadoc
« Reply #315 on: Wed, 30 April 2014, 15:59:03 »
One setup I saw used 15 blockers. It is easier to buy blockers now than to need them later and not be able to get them. I'm sure I can find some use for them in other circumstances.
« Reply #316 on: Wed, 30 April 2014, 16:00:28 »
Any chance you could find a link to that setup?  I completely agree about buying now rather than needing later, that's why I asked.  Maybe I'm missing out on a really cool layout option!   ;)
Offline rapax24
« Reply #317 on: Wed, 30 April 2014, 16:29:28 »
one last question, i'm usually out for work all day and i'm unsure of my work address in the near future so i will probably have to ship this to my mother or a friend of mine if i choose to buy one. will there be any problem with changing the shipping address during the production process?
Offline digi
  • elite af tbh
« Reply #318 on: Wed, 30 April 2014, 16:56:43 »
It increased to 30
Elton, I see the layout options but it doesn't say which options use plate and which do not? The only 1800 themed layout with a 6.25x spacebar can't use a plate?
Offline elton5354
« Reply #319 on: Wed, 30 April 2014, 17:07:35 »
Yes I can change your address as long as it's not shipped yet.
Plate only layouts on the form. As I've said it won't fit on any plates offered here.
Offline digi
  • elite af tbh
« Reply #320 on: Wed, 30 April 2014, 17:10:43 »
1.25x,1.25x,1.25x,6.25x,1.5x,1.5x,1x,1x is on the assembly form (Space bar Option D) but you also said this layout only works without a plate?? Man, I'm super confused now, lol.
Offline elton5354
« Reply #321 on: Wed, 30 April 2014, 17:11:50 »
Oh opps. Let me double check.
Edit: okay I added that one later on and that layout D is only without plate. Forgot about that.
No need to be confused. Either way I've already said that layout can't be used with plate anyways.
« Last Edit: Wed, 30 April 2014, 17:25:14 by elton5354 »
Offline digi
  • elite af tbh
« Reply #322 on: Wed, 30 April 2014, 17:33:01 »
You just said that all options on the assembly form use plate then you said that statement was a mistake. Then said there is no need to be confused because you posted earlier in the thread that option doesn't use plate? Now I'm REALLY CONFUSED!! :D
Offline elton5354
« Reply #323 on: Wed, 30 April 2014, 17:46:20 »
Ok last time.
1.25 1.25 1.25 6.25 1.5 1.5 1 1 IS NOT SUPPORTED BY THE PLATES.
If anyone ask again, I'll drop them off this buy. ;)
Offline digi
  • elite af tbh
« Reply #324 on: Wed, 30 April 2014, 17:51:17 »
Ok last time.
Wow, just asking for clarification and you were wrong in your earlier statement. What information should we assume is correct and incorrect? I'm not trying to be a butthole, I'm really not. I just want to be %100 sure. Thanks for doing this GB Elton, we still buds? <3
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
« Reply #325 on: Wed, 30 April 2014, 20:17:00 »
Is it too late to be in for a red one with 5 blockers?
Offline DamienG
    • DamienG
« Reply #326 on: Wed, 30 April 2014, 20:45:07 »
There were 30 available (shown on front page) and as the spreadsheet shows (above) 30 are gone.
[)amien
Offline anoxy
  • Deal with it
« Reply #327 on: Wed, 30 April 2014, 20:59:12 »
Sorry for the dumb question, but as someone fairly new to keyboards, what is a blocker?
Offline Latin00032
« Reply #328 on: Wed, 30 April 2014, 21:02:16 »
I regret not getting in on this.
Is this hard anodized?
It's the Viper GB going to have assembly service?
« Reply #329 on: Wed, 30 April 2014, 21:02:54 »
They are these
http://geekhack.org/index.php?topic=56877.msg1288763#msg1288763
And they are meant to block certain switch positions so that you don't need to put a switch there but it won't look like a hole.  So they're aesthetics for giving a certain functionality.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #330 on: Wed, 30 April 2014, 21:09:13 »
I hope so, otherwise I'll have to send everything to kmiller8, and have him sort it out
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline ninjadoc
« Reply #331 on: Wed, 30 April 2014, 22:37:38 »
I found it before but I couldn't earlier when I replied to your post. I will look again tomorrow and if I find it I will post the link.
Offline elton5354
« Reply #332 on: Wed, 30 April 2014, 22:43:59 »
This one has 14, but why would you make a TKL out of this?
Offline digi
  • elite af tbh
« Reply #333 on: Wed, 30 April 2014, 22:47:53 »
I agree, kind of defeats the whole purpose of the lightsaver layout.
« Reply #334 on: Wed, 30 April 2014, 22:49:08 »
Cool, thanks for finding that!  It's kind of a fun idea, but obviously yes I would not be interested in making it a TKL.   :)
Offline elton5354
« Reply #335 on: Wed, 30 April 2014, 22:57:53 »
You can now order black Duck Blockers since there are over 100 silver blocks
Offline dragonken
« Reply #336 on: Thu, 01 May 2014, 10:48:35 »
Hi elton,
I just send you a pm.
Regards,
Ken
Offline dragonken
« Reply #337 on: Fri, 02 May 2014, 11:59:24 »
Does any1 know if I relocate the num lock to the place next to F12. The num lock led toggling still work? Sorry for asking such stupid question.
Offline Kfactork
« Reply #338 on: Fri, 02 May 2014, 12:20:37 »
It's not a stupid question so don't worry. I think it's possible, but I'm not sure what the firmware program can do regarding capslock, numlock and special keys. It might have to hardwired differently in which case you have to ask elton to ask duck and see if he's willing to do it.
Offline digi
  • elite af tbh
« Reply #339 on: Sat, 03 May 2014, 08:49:34 »
Yes, I believe you can. http://duck0113.tistory.com/84 - ty to Photoelectric for posting in the Lightsaver thread. I plan on programming the left and right arrow keys to the right-click mouse / right windows key.
Offline Kfactork
« Reply #340 on: Sat, 03 May 2014, 11:16:03 »
That is seriously cool. You mean I can now change my caps lock to the timeout corner - where it should be - without a DIP switch?  :))
That alone justifies this keyboard for me. 8)
Offline Photoelectric
« Reply #341 on: Sat, 03 May 2014, 11:19:02 »
Just make sure you program your layer toggle key somewhere far out of reach.  I used to hit mine accidentally and would then get "delete" instead of "right arrow" on the numpad when viewing photographs--not fun  ;)
Offline geniekid
« Reply #342 on: Sat, 03 May 2014, 11:22:56 »
Layers make you super efficient!  Maybe move the delete key under the layer instead :p
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #343 on: Sat, 03 May 2014, 13:35:42 »
I am in the Orion group buy. Would it be possible to get some of the black blockers?
|||My other keyboards :
x
« Reply #344 on: Sat, 03 May 2014, 13:41:05 »
I think you misunderstood, the layer toggle changes layout if you have your layers set up differently.  And there are 4 layers!  So if you hit the key accidentally and don't notice, most things behave normally, but say your numpad might now be doing different things from the previous layer.  So like "delete" instead of a directional arrow :)  I think it would actually be very helpful to show layers in a way that does not involve LED blinking x number of times constantly (that gets old quickly, so I disabled it), but there's no display attached, and those who use LEDs for everything would not benefit from having extra indicator LEDs (like on F4 for Layer #4).  There are other ways to swap layers too, but it's definitely something to think about and experiment with.  I used to have Layer Toggle as a 1x function key to the right of the right Shift, and quickly moved it away farther out of reach.
« Last Edit: Sat, 03 May 2014, 13:43:44 by Photoelectric »
Offline Kfactork
« Reply #345 on: Sat, 03 May 2014, 13:54:35 »
Hmm that's some food for thought. Does the layers go in circles (so 1 -> 2 -> 3 -> 4 --> 1) ?The easiest way I can see is to solder in some non-switched LEDs and use those as indicator (like the poker 2 spacebar LED); but it might not be very visible if you turn on every single LED on the board.
Ultimately though, you have to look at some kind of indicator when the layer is changed, usually after the wrong key is pressed. So I think as long as the indicator is clearly visible and recognizable, it shouldn't be too much trouble.
« Reply #346 on: Sat, 03 May 2014, 14:08:24 »
You can have it go in a loop like that every time you press a key (Ly TG) or you can switch to a layer directly (Ly CH+ number).  2 different binding options.  Or you can bind "Ly 4" to go directly to layer #4, etc.
The indicator is by default the top right-most LED. It either blinks x number of times quickly every 2 seconds ALL THE TIME or only shows the layer number when you switch.  The blink succession is very fast.  Best to not bind Layer Toggle and instead bind actual layer numbers or Ly CH for more precision.
« Last Edit: Sat, 03 May 2014, 14:10:34 by Photoelectric »
Offline Kfactork
« Reply #347 on: Sat, 03 May 2014, 20:21:30 »
That's what I will probably end up doing. I would only use 2 layers anyway, how could you remember more than 2? o.O
Offline nuclearsandwich
« Reply #348 on: Sat, 03 May 2014, 22:05:46 »
If you think of number lock as the second layer, I think a third is doable on top of navigation / numberpad even if it's just a media/macro layer that doesn't cover the whole keyboard. On a keypad I've got a layout that's regular numpad navigation on layer 1, numeric keypad on layer 2, and media hotkeys on layer 3 and it works pretty well. I was experimenting with copy / paste macros on the third layer as well but they were too unwieldy and I ended up sticking those on my extra mouse buttons where they are actually much handier.
Offline blighty
« Reply #349 on: Sun, 04 May 2014, 18:50:00 »
I just want to say thanks to whomever gave up their spot in this GB, thus allowing me in.  Now I have a reason to get rid of my random g80-18xxs that are sitting around collecting dust or are in pieces.  I don't think I'll need another 1800 layout after this V2.   :thumb:
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
