Author Topic: Best 60% keyboard with arrow keys  (Read 8067 times)
Offline thelittle0ne
« on: Thu, 17 April 2014, 20:34:45 »
Hey everyone,
I am interested in buying a 60% keyboard with arrow keys. As for switch type, I want ergo clear but I am not sure how to go about this. Is it easier to buy clear switch keyboard and look for the springs or the other way around? Anyway thanks in advance!  :thumb:
I love cupcakes!
Offline Pacifist
  • on hiatus
Re: Best 60% keyboard with arrow keys
« Reply #1 on: Thu, 17 April 2014, 20:38:43 »
pure pro is pretty much the only choice for ANSI
JIS layout if you want arrows
imo easiest way is to buy a board, buy clears and springs, and swap. Off the top of my head I do not know any 60% with clears
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Thu, 17 April 2014, 20:53:26 »
Go up a bit and get a KC 84 :)
Offline intelli78
« Reply #3 on: Thu, 17 April 2014, 21:12:05 »
Leopold FC660M?
« Reply #4 on: Thu, 17 April 2014, 21:24:45 »
Yeah I was trying to think what there is besides Pure Pro.. MX MINI but it has the F Row...
Offline SonOfSonOfSpock
« Reply #5 on: Thu, 17 April 2014, 21:48:39 »
It will be less expensive if you can get a board with clear switches. Buying a set of switches is more money than buying a set of springs.
You will have more options as far as what switches come with the board if you go slightly larger than a 60%. Also, you might make the spring swap easier if you can get a board that is PCB mounted. PCB mounted boards are not as easy to find though.
Qtan sells a Leopold FC660M with clear switches. I don't know of any others offhand that have clear switches that are currently available.
« Reply #6 on: Thu, 17 April 2014, 22:42:01 »
I don't use the RH modifiers, and just use my pure, which works out well.
Coincidentally it is ergo clear as well.
Offline combataran
« Reply #7 on: Thu, 17 April 2014, 22:48:49 »
Leopold FC660C?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline Pacifist
  • on hiatus
« Reply #8 on: Thu, 17 April 2014, 22:51:37 »
Leopold FC660C?
hes looking for clears so the C is not an option. Maybe the M
Offline tbc
« Reply #9 on: Thu, 17 April 2014, 22:55:16 »
filco minila
Offline RESPRiT
  • HHKB = ❤
« Reply #10 on: Fri, 18 April 2014, 03:58:38 »
FC660M is insanely solid if you ask me.
Offline V2Quiet
« Reply #11 on: Fri, 18 April 2014, 04:53:14 »
Where did you buy your KC84 with browns?
Offline Oobly
« Reply #12 on: Fri, 18 April 2014, 12:43:33 »
The original KBT Pure can set the right hand modifiers into inverted T arrow cluster. It's also PCB mount, so you can open the switches to mod them with only desoldering the LEDs (or get the unbacklit version and you don't need to desolder anything at all). Pure Pro has dedicated arrow keys but it's hard to find keycap sets that fit, but at least it's 60% size.
If you can get a board with Clears, you can then buy the springs from some place like Originative. Cheapest option.
The FC660M, Keycool 84 and Pure Pro are all good, but I really love my "true 60%" Pure for a lot of reasons. There are lots of case options for it, too.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #13 on: Fri, 18 April 2014, 12:46:19 »
Stock? I really liked the Filco Manila.
Custom? Epsilon
It's kind of hard to find a stock board in the 60% size with Clears. I think the 660M is the only option? So you'll probably have to source the board, switches, and springs.
Offline kohi
« Reply #14 on: Fri, 18 April 2014, 21:57:06 »
^this haha  :thumb:
Offline Pacifist
  • on hiatus
« Reply #15 on: Fri, 18 April 2014, 21:58:10 »
Custom? Epsilon
isnt epsilon 75%?
