Author Topic: my finished phantom keyboard with case. have a look!  (Read 6454 times)
Offline Chemoletter
« on: Wed, 23 April 2014, 14:00:04 »
hi folks,
as a noob with keyboards and having watched all the starcraft II casts for a night i stumbled upon whitefiredragon's youtube video about building a custom keyboard using the phantom pcb. three months later, having signed up to geekhack.org, having bought a soldering kit and everything else, having spent countless hours searching for parts like stabilisers in germany ( and not having found them here ), i've completed my (first) custom board. it is a phantom ISO 1.25x german keyboard with blue switches and cherry stabs ( thanks to whiskytango for providing my board with stabs - would be uncomfortable without them )
some of you may have seen this:
http://geekhack.org/index.php?topic=56161.msg1270713#msg1270713
so this was my idea of a case for my phantom. it should be accessible all the time without screws etc. in my original case-post the case was to be lasered. at my place they wanted to charge 100€ just for the lasering and i said "no way". so i went to my university where they'd do it for 25€. too bad that their lasercutter was broken at the time. so i decided to mill it which was a bad idea with this material. as you can see the edges are pretty uneven which i tried to compensate for by sanding quite a lot ( you should have seen it when it came out of the milling machine... ). the result is rough to the eye but very smooth to the touch in deed. all parts are glued together with "ponal holzleim". the end result was spray coated unprofessionally ( see the white stains ) with matte clear spray coating.
but besides that i have to say that i totally LOVE the case, it is heavy like a brick and sturdy as hell. it's a tank seriously. and it has this rough underground style to it. ( well the next one will be lasered for sure and will look and fit better at the end )
i wanted to thank you all for your support, your suggestions and your help. this is an awesome community!!!
PICTURES:
62128-062130-162132-262134-3
Re: my finished phantom keyboard with case. have a look!
« Reply #1 on: Wed, 23 April 2014, 14:01:34 »
Very nice! :thumb:
Offline Flyersfan1
  • Hi!
« Reply #2 on: Wed, 23 April 2014, 14:05:33 »
wow!! love that case!! great work.
Quote from: Photekq
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #3 on: Thu, 24 April 2014, 20:23:21 »
awesome handwork man!
how about the weight?
Offline Chemoletter
« Reply #4 on: Fri, 25 April 2014, 05:48:54 »
heavy for a wooden case i think. the recipe is 80g glue, 1,15kg of wood and roughly about 250g of enamel. that makes 1,48kg/2,2 lbs for the case. ( there are some rubber strips that i'm going to apply when i can spare some time. so add another 10g maybe ). the next case i'm going to build will be either the same material but lasercut - so no underground looks but nice burnmarks - or some kind of steel/wooden combination. but that is to be figured out designwise so it makes sense. ( and i will have to take a thorough look into my wallet for that )
speaking of money, is it just me or are the prices for material and cutwork in germany kind of insanely high? i hear a lot of people here doing their own designs in the US and paying moderate prices for good quality. that makes me wonder if it wouldn't be better for me having a bigger bunch of stuff manufactured somewhere other than germany. i mean this whole keyboard project ripped me off like nothing else and my keycaps aren't even of high quality... just wondering.
« Last Edit: Fri, 25 April 2014, 05:50:27 by Chemoletter »
« Reply #5 on: Fri, 25 April 2014, 06:03:10 »
Congrats!  It's awesome,
Offline whiskytango
  • Don't touch the trim
« Reply #6 on: Fri, 25 April 2014, 06:11:42 »
Nice dude! Did you sort out the stab issues?
Offline Chemoletter
« Reply #7 on: Fri, 25 April 2014, 06:37:19 »
stabs on backspace, enter and right shift are now working perfectly. spacebar stab needed a gentle scraping with a knife and runs smoothly now too. for some reason my F12 key does not respond on aqua. i'll resolder it to make sure. anybody know a remapping program that supports german layouts? ( ö,ä,ü an so on)
Offline blackbox
« Reply #8 on: Fri, 25 April 2014, 08:05:41 »
Smart case!
The LAN table!
Offline agodinhost
    • Dr Ian O Xaman
« Reply #9 on: Fri, 25 April 2014, 09:15:19 »
You did liked the PCB?
I assembled one last week and to be totally honest I didn't liked at all the MK PCB. There are a few missing titles (the caps lock led/resistor, maybe because of the white background) and the quality of the plated holes was kinda poor.
The most annoying detail, IMHO, is the limited options for the diodes. Actually the only option you do have is to solder or not the diodes.
I do love the layout, but I'm wondering about other options for a TKL board.
« Reply #10 on: Fri, 25 April 2014, 12:47:24 »
Read what I said when I responded to you in my thread.  The layout is supported, the only thing missing is the internationalization of the GUI.  For that I would need volunteers that are native speakers.
Offline Chemoletter
« Reply #11 on: Tue, 29 April 2014, 01:17:26 »
you know something about the proper type of rubber to get for anti slip feet? yesterday i tried to buy some but i didn't because after smelling all the softernizers in it i thought it would give me cancer within a week and i got sick immediately. now i got myself some foamy rubbery stuff with rather good grip but it is difficult to apply because of the porous nature of the material. i don't have hot glue, just double sided tape. any recommendations for applying this sucker underneath my case?
Offline Heezy
  • Formerly trynds
« Reply #12 on: Tue, 29 April 2014, 01:19:48 »
That looks cute, gonna paint it?
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
Offline Chemoletter
« Reply #13 on: Tue, 29 April 2014, 01:27:47 »
already coated it with clear matte enamel. i'll stick to the grungy looks this time and leave it as it is. the next one will be painted for sure.
Offline zeroni13
« Reply #14 on: Tue, 29 April 2014, 04:54:45 »
I have the same PCB and there was no issues with it what so ever. What do you mean with missing titles? And the holes for me was perfect, they were cut in some places to make room for the switch in different layouts but it wasn't a problem when it came to soldering. And limited diodes? you can have any diodes you want on there that uses 5V or less, you also have the choice of putting them in filco style on under the respective keys (caps and scroll lock).
The PCB I got was super nice quality.
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline strict
  • TKL Zealot
« Reply #15 on: Tue, 29 April 2014, 10:02:52 »
I was very impressed with mine as well. I would have liked if there was printing for the diode holes like the black PCB had but thats a very minor complaint. I'm seriously considering picking up another PCB and building second one.
« Reply #16 on: Tue, 29 April 2014, 20:22:03 »
much better than my phantom case:
Excellent work!
Offline Chemoletter
« Reply #17 on: Wed, 30 April 2014, 00:57:42 »
those caps!! where did you buy those - i want them  :eek:
btw your case is  beautiful. i guess it's light, portability=good thing.
Offline Pacifist
  • on hiatus
« Reply #18 on: Wed, 30 April 2014, 01:12:28 »
dsa retro set. classifieds
Offline mrklaw
« Reply #19 on: Wed, 30 April 2014, 15:33:22 »
Looks great. Great job.
Ducky Zero with DSA Dolch and SA Vim key
« Reply #20 on: Sat, 03 May 2014, 10:20:06 »
It's just some cardboard. I used it like that for almost a year to game with, etc. It worked quite well, all things considered.
Keycaps are DSA retro and DSA meebcaps. I prefer the meebcaps to clacks and they are the only custom keycaps I've considered getting.
It's not very portable though. The cardboard will fall off.
