Author Topic: Post Pictures Of Your Desk/Set Ups!  (Read 2438708 times)
Offline MJ45
  • HHKB Pro
Re: Post Pictures Of Your Desk/Set Ups!
« Reply #1700 on: Tue, 29 October 2013, 07:40:42 »
According to the diagram, I just need Sw4 off for it to function as Windows.. But it's not! :/
When changing dip switches the keyboard must be disconnected change settings then reconnected for new settings to take effect.
« Reply #1701 on: Tue, 29 October 2013, 07:44:57 »
Sorry i dont own a decent camera
This setup I like......if only I had 4 monitors....
Offline Emospence
« Reply #1702 on: Tue, 29 October 2013, 11:04:08 »
Did that, still nothing
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline hcry4
  • HHKB Hoarder
« Reply #1703 on: Tue, 29 October 2013, 11:12:56 »
Did you try having SW 1 AND SW 2 on? I know it has a "-" there, but all my HHKBs work right with them both on.
Offline Emospence
« Reply #1704 on: Tue, 29 October 2013, 11:25:42 »
Ahhhh much better! Thanks!
Offline BakaPhoenix
« Reply #1705 on: Tue, 29 October 2013, 11:37:39 »
Offline jinxedx84
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #1707 on: Wed, 06 November 2013, 07:44:18 »
It's been a while since I posted pics of my setup - here it is. Nothing new though just a little more crowded since I really needed native Ubuntu box to test vagrant deployments so I installed it on my old trusty MBP 2010 :)
Only new addition is Filco wrist rest which just came in today.
The keyboard is my daily driver for last few months and it will stay so until I get working Ergodox (or longer if I don't like it eventually).
It's Filco Metallic Blue with MX Blues and blank black think PBT keycaps from eBay.
42824-0
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #1708 on: Wed, 06 November 2013, 14:00:00 »
Thought I would add an update on my setup.
Sorry about the noise in the picture. Still refuse to buy a new camera.
« Last Edit: Wed, 06 November 2013, 14:04:54 by HUNTERANGEL121 »
Offline Asininity
« Reply #1709 on: Mon, 18 November 2013, 01:37:56 »
My new setup since I moved. Unfortunately I've had to really downsize.
« Last Edit: Mon, 18 November 2013, 01:40:38 by Asininity »
« Reply #1710 on: Mon, 18 November 2013, 03:38:07 »
Are you sure there's enough room under the desk for your feet, what with that subwoofer ;)
Offline Asininity
« Reply #1711 on: Mon, 18 November 2013, 12:58:20 »
Subwoofer > leg room. It's all about priorities.
« Reply #1712 on: Tue, 19 November 2013, 03:58:04 »
I completely understand :)
Offline Asininity
« Reply #1713 on: Tue, 19 November 2013, 17:41:18 »
I do have 18 inches of leg room though, so I think I'll be good. Plus, when in doubt use your sub as a foot rest.
« Reply #1714 on: Tue, 19 November 2013, 23:56:25 »
Mmmm good vibrations :)
Offline rolito223
« Reply #1715 on: Sat, 23 November 2013, 09:17:14 »
this is my desktop setup! :D
Offline czarek
    • FalbaTech
« Reply #1716 on: Thu, 28 November 2013, 08:28:39 »
Downsize my @$$ :) I moved from Hex Core Mac Pro to a Mini just over year ago :)
What are those speakers? They look cool indeed.
Offline ynrozturk
« Reply #1717 on: Thu, 28 November 2013, 09:57:46 »
Been meaning to add a monitor shelf forever now. Finally got around to it today.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #1718 on: Thu, 28 November 2013, 21:25:03 »
And it looks great!
What did you use for materials?
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline ynrozturk
« Reply #1719 on: Fri, 29 November 2013, 02:10:16 »
Thanks! I just picked up a shelf from Ikea, the black Ekby. It had no places to mount feet on it as it's meant to be mounted on a wall, but I was sure I could find some generic furniture feet for it, which I did. But since it had no places to actually screw the feet it, I just used some heavy duty double sided foam tape (the red 3M stuff) on the feet and stuck them on. That stuff is amazingly secure, so it's not going anywhere.
Offline Internauta
« Reply #1720 on: Sat, 30 November 2013, 12:51:56 »
Just bought a new case and a whole bunch of watercooling gear, build 2.0 coming soon... But for now i'm pretty happy of it except for the cables that need some work.
http://imgur.com/a/N5zpu
Offline pr1me
« Reply #1721 on: Sat, 30 November 2013, 13:26:01 »
46334-0
Offline ynrozturk
« Reply #1722 on: Sat, 30 November 2013, 14:39:59 »
Looks fantastic.
  • Keyboard Hipstar
« Reply #1723 on: Sat, 30 November 2013, 22:22:47 »
Offline pr1me
« Reply #1724 on: Sun, 01 December 2013, 17:59:06 »
Is that one of those Tex Poker cases?
How is it?
Yes it is the tex poker case
I can't compare to other aluminium case since it's my first one.
Compared to the stock poker case, it feels like it's an entirely new keyboard, it's really solid now, with quite a bit of weight.
 :thumb:
Offline Pacifist
  • on hiatus
« Reply #1725 on: Sun, 01 December 2013, 19:01:19 »
Offline stancato9
Poker 2 - MX Red
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1728 on: Sat, 07 December 2013, 13:06:06 »
New place.
Before "rebuilding".
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline jaymatter
« Reply #1729 on: Sat, 07 December 2013, 13:11:29 »
A couple of shots of my standup desk! I don't have multiples - that extra screen on the left is for the temporary computer under it that is for testing. I find one 27" screen is more than enough. I have a similar setup at work, with the 27" monitor and M8 arm, but with an adjustable standup.
 :D
« Last Edit: Sat, 07 December 2013, 13:13:17 by jaymatter »
Offline ynrozturk
« Reply #1730 on: Sat, 07 December 2013, 13:43:25 »
New place.
Looks very neat and comfortable, I like it. Also the new wall color seemed to have opened the place up a lot.
Offline Morwrath
« Reply #1731 on: Sat, 07 December 2013, 14:11:07 »
I never understood how you could enjoy standing up all the time when using the computer.
Maybe it is just me being lazy :P
Ducky Mini w/ white LEDs [Browns]
WTB SLUSHY RED CC/BROBOT!!
Got 3D and Hack Orange for trade, both MX.
Offline phatdood9
« Reply #1732 on: Sat, 07 December 2013, 14:12:26 »
i thought thats a stool
Offline jaymatter
« Reply #1733 on: Sat, 07 December 2013, 14:14:41 »
I don't usually stand all day - my home desk only sees 3-4 hours at a time. My desk at work adjusts between sit and stand so I don't stand all day there either. More about keeping the body positions varied than always standing for me.  :thumb:
Offline reziak
  • Topre/60% Enthusiast
« Reply #1734 on: Tue, 10 December 2013, 16:15:05 »
Sorry for the photo quality, but here's my station :) Built the PC in March and have been slowly adding to it. I had all these grand plans for exciting keycaps for both the tenkeypad and the HHKB, but I actually like how it is now. Clean and ready for work.
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline Pacifist
  • on hiatus
« Reply #1735 on: Tue, 10 December 2013, 16:15:58 »
is that a fk or a am?
Offline reziak
« Reply #1736 on: Tue, 10 December 2013, 16:21:25 »
It's an FK! I love it. I've tried lots of mice, and this is hands down my favorite I've ever used. I had a Sensei Raw and liked the form factor, but the drivers kept crashing my computer. Still have no idea why, and SteelSeries wasn't extremely helpful about it. Anyway, this feels like the Sensei in my hand, while having an optical sensor and no drivers! Plus I love the yellow on black  :thumb:
Offline Pacifist
  • on hiatus
« Reply #1737 on: Tue, 10 December 2013, 16:22:43 »
Are you claw or palm grip? I don't know if I should go FK, AM, or EC1 EVO
Offline reziak
« Reply #1738 on: Tue, 10 December 2013, 16:24:51 »
I feel like I'm a hybrid lol...I've used a Deathadder and palmed it just fine. With the FK, I'm sort of in between. I basically claw it but the bottom end is long and sloped so nicely that my palm can rest on it.
From what I've read, most people prefer the FK to the AM. I'd love to try an EVO at one point just for fun, but I'm so happy with my FK that I really feel no need....
« Last Edit: Tue, 10 December 2013, 16:27:18 by reziak »
Offline RougeR
« Reply #1739 on: Thu, 12 December 2013, 15:35:59 »
first and last photo ive posted of my desk in its current iteration, i start moving out friday.
Buckling spring warrior!
« Reply #1740 on: Thu, 12 December 2013, 15:50:34 »
Offline MJ45
  • HHKB Pro
« Reply #1741 on: Thu, 12 December 2013, 15:57:12 »
Very nice soothing blue hues on your keyboard :thumb:
Offline C5Allroad
« Reply #1742 on: Thu, 12 December 2013, 16:05:18 »
Very nice! What kind of monitors are those?
« Reply #1743 on: Thu, 12 December 2013, 17:09:49 »
Don't know what model, they're AOC brand (never really heard of them) but they were like $350 for both of them. Not bad for 23" IPS LED monitors.
Also since everyone asks, the Hello Kitty is my webcam. There's a camera on the nose.
Offline Pacifist
  • on hiatus
« Reply #1744 on: Thu, 12 December 2013, 17:29:36 »
explain the kpop poster
Offline ynrozturk
« Reply #1745 on: Thu, 12 December 2013, 17:45:45 »
I've heard of AOC, we have a few of them in our office. Pretty good monitors, especially for their price.
« Reply #1746 on: Thu, 12 December 2013, 17:46:33 »
Why does it need explanation?
Offline Pacifist
  • on hiatus
« Reply #1747 on: Thu, 12 December 2013, 17:47:45 »
what makes ips better than everything else?
Offline HPE1000
  • Keycap Paparazzo
« Reply #1748 on: Thu, 12 December 2013, 18:11:12 »
Better viewing angles, better color reproduction.
Offline vun
  • Just one more thing
« Reply #1749 on: Thu, 12 December 2013, 18:31:18 »
Also higher resolution. TN usually stops at 1080.
