Author Topic: League of Keyswitches!  (Read 4895 times)
Offline Ragwolfe
« on: Sun, 11 May 2014, 11:23:26 »
Does anyone have a recommendation of which Cherry MX keyswitches would be best for League of Legends, so far it seems to be either brown or black? Is the feedback on the browns a hinderance to reactions (as this is quite an important factor in league or any other MOBA)?
Offline Sniping
Re: League of Keyswitches!
« Reply #1 on: Sun, 11 May 2014, 11:30:42 »
It really doesn't matter. Get the switch that you think you'll enjoy typing on the most.
Offline CK Briefs
  • formerly calvins1
« Reply #2 on: Sun, 11 May 2014, 11:33:55 »
Honestly, for league, it doesn't matter what switch since the apm isn't very high and I've played league using 'typing' switches like blues and ergo clears.
What matters is that you're comfortable with them, and that they're not too heavy.
If you can get used to linear switches like reds, then you'll find that you can spam buttons faster; yet it really isn't necessary for league.
Edit: Add yourself to the GH LoL thread :P
« Last Edit: Sun, 11 May 2014, 11:37:55 by calvins1 »
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
« Reply #3 on: Sun, 11 May 2014, 11:35:24 »
It's pretty evenly spread among pro players. A lot of them use Blues and browns, but that's mostly because of Razer/Logitech sponsorships. I played LoL on blacks and was gold before I stopped playing. So it really doesn't matter at all.
Offline Ragwolfe
« Reply #4 on: Sun, 11 May 2014, 11:38:18 »
I think then I will probably go for blacks as linear switches supposedly last longer than the ones with feedback and I don't want to spend £150 on a keyboard too frequently :P
« Reply #5 on: Sun, 11 May 2014, 11:40:56 »
All switches should last the same amount of time. I don't know where you heard that.
Offline Rafen
« Reply #6 on: Sun, 11 May 2014, 11:42:39 »
Blacks arent that great to type on since they require more force. You could try reds which are a lighter black .
Offline CK Briefs
  • formerly calvins1
« Reply #7 on: Sun, 11 May 2014, 11:43:12 »
Yeah the commercial crap is contagious
Even razer's supposed '60 million clicks' is more like 'up to 60 million' and as low as 20; just ignore this marketing crap and research stuff through some reputable reviewers or websites.
Offline Ragwolfe
« Reply #8 on: Sun, 11 May 2014, 11:45:04 »
http://www.overclock.net/t/491752/official-mechanical-keyboard-guide#post_6009482
If you click on common switch types it says the advantages of blacks/linear is they last slightly longer!
It does also kind of make sense, especially with less longevity on the blues (more moving parts) and the linear one's will move the metal leaf less than the ones with feedback.
« Last Edit: Sun, 11 May 2014, 11:48:21 by Ragwolfe »
Offline CK Briefs
  • formerly calvins1
« Reply #9 on: Sun, 11 May 2014, 11:50:48 »
In theory, since blacks don't have as many friction points and a heavier spring, there should be less contact with the actuation mechanisms. However in practice, it doesn't really make a difference IMO. Someone can correct me if I'm wrong.
Offline Yslen
« Reply #10 on: Sun, 11 May 2014, 12:32:17 »
I've played league on browns, reds and buckling springs. All fine!
Offline Pacifist
  • on hiatus
« Reply #11 on: Sun, 11 May 2014, 12:37:21 »
by the time you break a key on your board, you will have already bought 10 other boards
so I won't worry about lifetime
« Reply #12 on: Sun, 11 May 2014, 12:55:37 »
can confirm, just bought 11th keyboard
Offline kohi
« Reply #13 on: Sun, 11 May 2014, 13:17:26 »
most of my friends use either blues or browns, I like to use browns/reds - just choose the switch you like :thumb:
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« Reply #14 on: Sun, 11 May 2014, 14:12:38 »
Honestly, I've tried all the Cherry MX switches besides Clears and Greens. For gaming, and I've played a lot of games on these boards (LoL included), Cherry MX Red all day.
Opinion is highly subjective of course, but I love the fact that if I need to act fast, the slightest reach over to the key and it will actuate. So much easier to spam keys on Reds. As a Rogue in WoW, the ease of the linear switch felt very crisp while spamming to make sure the ability executed the second it was off cool down.
« Reply #15 on: Sun, 11 May 2014, 14:55:16 »
Blues used to advertise a lesser number of actuations before failure. Perhaps he read it out of the cherry datasheets.
for gaming, clears can be nice, as they actuate just past the tactile bump, so it is very easy to bounce them at that point.
Offline missalaire
  • Great Finder of Great Finds
« Reply #16 on: Sun, 11 May 2014, 15:03:21 »
Whatever you use isn't going to magically make you a better player. That being said, I like gaming on clears.
Offline thestage
« Reply #17 on: Sun, 11 May 2014, 20:58:06 »
I play a lot of LoL on reds.  I used a brown board for gaming before this one, and I definitely prefer reds for this purpose.  But your mouse is going to have a much great effect than your keyboard on league performance (and for most games).
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #18 on: Sun, 11 May 2014, 21:02:45 »
Not true. With my new uber l33t razer switches, I've gone from a total n00b to a professional gamer
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #19 on: Sun, 11 May 2014, 21:08:12 »
it doesnt matter what you use. some of the best sc2 players still use dome keyboards up to this date. just try all the switches and go with whatever you like the best
Offline Yslen
« Reply #20 on: Sun, 11 May 2014, 21:31:37 »
I used to play League with a Razer rubber dome one-hand-keypad thingy, and that was definitely NOT okay. If I missed slightly and pressed a key too far from the centre it would sometimes stick and not actuate. Not all the time, but often enough that I wouldn't want to go back to using one. I've had no issues with any of the mechanical switches I've played with.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #21 on: Sun, 11 May 2014, 21:56:55 »
Topre
Offline Pacifist
  • on hiatus
« Reply #22 on: Sun, 11 May 2014, 22:10:09 »
Topre
has less lifespan than Cherry MX
Offline Defect
« Reply #23 on: Sun, 11 May 2014, 22:13:14 »
Got diamond on a mix of blues, Stock Clear, Buckling Spring (even with 2KRO...this game is so low APM lol), 62g ergo clear, 62g lubed blacks.
Played a few norms with a 55g Topre and did fine.  As long as you know how to use the switch you have, you'll be fine.  That being said, from a switch design perspective, blues are garbage for gaming but any other switch will work (I love blues, but just look at how they're designed...no way was this made with gaming in mind).
I recommend trying panda clears or ghost blacks.
I'm starting to realize that Ghost Blacks (black stem, clear spring) is the best for 90% of gaming.  Recommend everyone to try gaming for 3-5 hours on ghost blacks before judging and dismissing.
Offline JPG
  • Model F is my new passion!
« Reply #24 on: Sun, 11 May 2014, 22:16:57 »
Topre
Do the Maths: At either 20 millions or 50 millions strokes before a key fails, there's more chance something else will have broken by then.
As for the choice of switches, just try to decide the one you would prefer to use. And don't think your keyboard will increase your skill. You won't be better but you should still enjoy more using your keyboard if it's a good one.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #25 on: Sun, 11 May 2014, 22:24:13 »
Precisely.  Besides with thorpies, the silicone will split before the actual spring wears out.  With a Cherry you just de-solder/remove the older worn out switch with a newer model and hey presto, you're back in the game  :thumb: .
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #26 on: Sun, 11 May 2014, 22:25:35 »
yup mustve been the dome keyboard because I was diamond 1 in season 3 and I got there with ****ty microsoft dome keyboard
Offline Novus
  • Mondai nothing~
« Reply #27 on: Sun, 11 May 2014, 22:26:14 »
... guys you're supposed to say TOPRE isn't a cherry mx switch.
Geez.
Plz read the OP.
In all seriousness, reds are the best MX switch for gaming.
« Last Edit: Sun, 11 May 2014, 22:30:07 by the1onewolf »
Offline dook0
« Reply #28 on: Sun, 11 May 2014, 22:33:04 »
For me it's cherry Brown, definitively not green for gaming it's too heavy to be reactive
Offline Novus
  • Mondai nothing~
« Reply #29 on: Sun, 11 May 2014, 22:34:05 »
Well obviously you would have been diamond if you had a real keyboard.
I bet your mouse isn't 100 bucks either, so Bing-Bing-Bing!
Offline OnTheBrink
    • Wired In Store
« Reply #30 on: Sun, 11 May 2014, 22:41:00 »
LMAO
On a serious note: with consumers and gamers becoming more knowledgeable about Cherry MX and mechanical switches, why would they switch (no pun intended) to a knock off? This is why I will only buy Razer mice and nothing else from them.
« Reply #31 on: Sun, 11 May 2014, 22:44:02 »
Hate brown for gaming. Either go linear or go clicky.
I'd actually recommend reds, but what do I know :P
Offline Premonition
  • HHKB Elite
« Reply #32 on: Mon, 12 May 2014, 20:03:40 »
I agree, I've played quite a lot of League at a moderate level (high-silver, gold nearly!) and I've used all sorts of switches. Blues were fine, Reds were nice (maybe a little better for playing, but since I'm used to Blues I like them more), and now I use Topre. Most of my champions are pretty mechanically difficult (lots of Zed mostly), but it's not like you're ever going to be pressing switches at StarCraft speed, just in short combinations, so anything was fine for me. I just recommend you use whatever feels best, sorry that it's so unhelpful!
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #33 on: Mon, 12 May 2014, 21:03:26 »
Buy a switch tester. It includes different type of switches.
Offline Yslen
« Reply #34 on: Tue, 13 May 2014, 06:52:47 »
That's... nice for you. I had issues with one particular device, I was just relating my experience.
Offline histevenhere
  • Student
« Reply #35 on: Thu, 15 May 2014, 08:02:11 »
I am using topre and I was diamond last season.
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
Offline Novus
  • Mondai nothing~
« Reply #36 on: Thu, 15 May 2014, 13:10:05 »
If you buy an HHKB type S and a proper mouse you'll be 95 percentile in no time.
Offline motoyuki
« Reply #37 on: Thu, 15 May 2014, 13:12:55 »
I play league with blue switches, but I'm only gold ranked. I feel like it's a good in-between for everyday typing and gaming.
Offline Novus
  • Mondai nothing~
« Reply #38 on: Thu, 15 May 2014, 13:16:30 »
Clearly blue is for plebes. Get a type s today
