Author Topic: Seeking advice on clicky boards  (Read 2556 times)
Offline Rainarrow
« on: Sun, 15 June 2014, 04:14:36 »
Before anything, my daily driver is a RF86U Variable force. I've experienced(and historically owned): Model M(BS clicky), FIlco Majestouch TKL(Cherry MX Blue), Choppo Choc Pro(Cherry MX Black). That was back in China and I brought only the 86U to US when I moved to here for school.
A few days ago I typed on a friend's Razer BlackWidow and instantly began to reminsince the clicky and tactile feeling of that board. I removed a keycap to verify it's blue in color so I assume it's Cherry MX Blue. So I began to look for a board with MX blue switch to see if I'll prefer that than my 86U.
So - I'm a touch typist so I dislike any form of fancy backlight on the keyboard. By that principle, I liked the KUL ES-87 by its standard ANSI layout and lack of fancy lights. However I then noticed for some reason it doesn't come with blue switches...only brown, black or clear.
So here am I , seeking advices from you guys:
a) Any standard, low-profile TKL board with MX Blue switch you can recommend?
b) I'm also considering alternatives - namely MX Clear and Topre 55g. Like I said, if I'm craving for more clickyness and tactile feeling than my 86U variable force could offer, any chance I'll like these?
Thanks in advance for any input!
Offline Kayla
  • :3
Re: Seeking advice on clicky boards
« Reply #1 on: Sun, 15 June 2014, 04:17:51 »
Ducky
Filco
Topre are clocky. There is no click like blues. Blues and Greens have a unique click.
Offline Daspartic
  • IBM is love IBM is life
« Reply #2 on: Sun, 15 June 2014, 04:25:58 »
If you are willing to forgo having a TKL board, then I would suggest an IBM Model F.  They are about as clicky and tactile as you can get and I think they feel even better than the 55g topre switches.
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Offline Rainarrow
« Reply #3 on: Sun, 15 June 2014, 04:52:16 »
I really liked the feeling of typing the Model F a lot. However unfortunately the 2KRO and layout is dealbreaker for me.
Offline Daspartic
« Reply #4 on: Sun, 15 June 2014, 05:01:47 »
Yeah I'm not crazy about the layout either, but it has NKRO, which is pretty sweet for a keyboard from 1981 lol.
Offline CaptLock
« Reply #5 on: Sun, 15 June 2014, 09:25:48 »
Filco!
Offline 1391406
« Reply #6 on: Sun, 15 June 2014, 23:13:21 »
Model M's are 2KRO. Model F's are NKRO, and the layout of a 122-key Model F can also be modded to match an IBM Model M.
Offline sakai4eva
« Reply #7 on: Mon, 16 June 2014, 00:26:10 »
Clears are not clicky in any way.
Only blues and greens are clicky.
