Author Topic: Post your BS boards here!  (Read 611031 times)
Offline Belfong
Re: Post your BS boards here!
« Reply #350 on: Fri, 22 May 2015, 21:55:35 »
That Track Point is just so deliciously nice!
I didn’t even know such a model exists.
Anyway, my humble SSK.
Offline meow a cat
  • Resistance is futile.
« Reply #351 on: Sat, 23 May 2015, 02:17:49 »
My IBM Model F PC-AT. Stock, but about as close to new as it could get. Almost rust-free plate, and very clean. Running it with an Orihalcon Soarers converter.
Boards:
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #352 on: Wed, 27 May 2015, 14:24:11 »
I keep mentioning my nephew's keyboard, but never got the chance to post it.
Blue Label 1391401, beautifully restored by Phosphorglow.
« Last Edit: Wed, 27 May 2015, 21:45:19 by Snowdog993 »
Offline njbair
    • nickbair.net
« Reply #353 on: Thu, 28 May 2015, 08:28:54 »
Blue label + Blue underlay = Blue-tiful
My boards:
« Reply #354 on: Thu, 28 May 2015, 10:07:34 »
Yeah, that looks really nice.   :thumb:
Offline Snowdog993
« Reply #355 on: Thu, 28 May 2015, 10:19:56 »
Yep!  Now that he has his keyboard back, I believe I will finish up on the keyboard he was using and do the LED mod on both the 1394204 and 1395665 keyboards.  I like having the status lights better.  I have ordered the LED panels and overlays for them.
It's not that I can't use some software for the status on the screen.  I find myself checking most of the time on the keyboard itself.  Old habits die hard I suppose.
« Last Edit: Thu, 28 May 2015, 10:28:31 by Snowdog993 »
Offline Snowdog993
« Reply #356 on: Thu, 28 May 2015, 10:35:12 »
Oh yeah!  I almost forgot about this one!
I definitely want to go ANSI here!
Offline Venatorious
  • Gotta Start Somewhere
« Reply #357 on: Thu, 28 May 2015, 13:36:11 »
Yeah I love my ANSI F122.
Offline njbair
    • nickbair.net
« Reply #358 on: Thu, 28 May 2015, 18:55:31 »
In the foreground is a Unicomp PC-122 that I'm tearing apart and turning into an Unsaver. I'm still not sure how I'm going to weld the plastic case back together, but that didn't stop me from sawing it in half. You can see how I've removed all the unnecessary traces from the mylar membranes and separated them with a sheet of paper to prevent false triggers. I removed the extra so it would be easier to bend back behind the board. I can't think of another way to do this... I'm saving all the unused bits in case one day I decide to build a BS numpad with a custom case.
In the background is its brother, an identical PC-122 that's been screw-modded and ANSI-converted. The beige keys are donors from another Model M until I finalize a layout for the monster board and order replacement caps from Unicomp.
101919-0
My boards:
Offline sleepy916
« Reply #359 on: Thu, 28 May 2015, 20:36:20 »
My desk is dusty...don't mind the potatoes.  ^-^
Offline njbair
    • nickbair.net
« Reply #360 on: Thu, 28 May 2015, 20:39:06 »
I've never seen one unpainted before. Looks awesome with that brushed finish.
My boards:
Offline Touch_It
« Reply #361 on: Thu, 28 May 2015, 20:53:16 »
I know blue labels aren't the most desired, but I think they make a strong case for being the best looking.  That is a beautiful restore job and the underlay compliments it quite well.
Offline Snowdog993
« Reply #362 on: Fri, 29 May 2015, 11:06:06 »
His keyboard is on the Phosphorglow website too:
I was going to mention I do have one very similar to his too.
This is the 1370477: (Same as 1391401 except it has single-piece keys.)
They both are amazing looking!
« Last Edit: Fri, 29 May 2015, 11:17:54 by Snowdog993 »
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #363 on: Fri, 29 May 2015, 11:15:49 »
Here is my 1987 SSK that I posted in the Space Saver Club thread, it is in pretty good shape, only thing wrong with it is one of the little plastic studs that holds the top of the plate close to the screw holes is broken off. I will hopefully be sending it to Phosphorglow soon to have the rivets replaced.
It not being there does not hurt it too much, If I push up on the print screen key I can move the plate thing forward a little bit on that side but nothing too bad, still goes together fine :)
« Last Edit: Fri, 29 May 2015, 11:19:03 by nickheller »
Offline Snowdog993
« Reply #364 on: Fri, 29 May 2015, 11:23:27 »
It not being there does not hurt it too much, If I push up on the print screen key I can move the internals forward a little but nothing too bad, still goes together fine :)
I'm sure he will fix that issue easily.  He's very meticulous.  If you haven't seen, there are keyboards he has restored that would make a restoration expert cringe at the thought of attempting to restore it.  Amazing!
You have a very nice SSK there too!  It looks very clean as it is!
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #365 on: Fri, 29 May 2015, 11:30:09 »
I have seen them on his site, and been emailing him about it I am pretty much just waiting on the right time to send it out. It is pretty clean, I just want to get these rivets swapped out so I can stop worrying about it falling apart on me lol. I love this thing, so I am exited for it to get a little bit of a rejuvenation.
« Reply #366 on: Sat, 30 May 2015, 03:38:00 »
If you were thinking of just getting the broken rivets replaced, I'd suggest getting Phosphorglow to do a full bolt mod.  It might cost slightly more, but the keyboard will be rock solid for another 30 years.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #367 on: Sat, 30 May 2015, 04:02:08 »
I am having him do the whole reconditioning service ( really only needs bolt mod and plastic stud fixed) I am exited to see how solid it is when I get it back. I was thinking about converting to the USB controller but I decided to keep my stock controller and cable since they work fine and my desktop has PS2, and I kind of like the way the old coiled cable looks :)
« Reply #368 on: Sat, 30 May 2015, 06:24:41 »
And you can always get an SDL to USB cable later on anyway, or a PS/2 to USB adaptor if the cable is non-removable.
Offline Snowdog993
« Reply #369 on: Sun, 31 May 2015, 12:08:10 »
Okay, I did do the LED panel on the terminal board that my nephew used.
From This:
To This:
And Finally To This:
This keyboard went through everything!  It's pretty nice now!
http://imgur.com/a/bBFuv
Footnote:  I did the 1395665 too!
« Last Edit: Sun, 31 May 2015, 13:39:05 by Snowdog993 »
Offline fanpeople
« Reply #370 on: Sun, 31 May 2015, 22:04:27 »
Nice work Snowdog  :thumb:
Offline Snowdog993
« Reply #371 on: Mon, 01 June 2015, 11:09:39 »
Yeah, the LED mod is pretty simple to do.  You just need the right controller for it!  I was in a panic with the 4204 at one point.  The keyboard would not respond with the spacebar, right alt, - key on the numpad and the bottom 3 arrows on the inverted T.
I slowed down, took my time, cleaned up the ribbon cable and triple checked the LED connectors.  Everything works fine.  For a little while there, I was worried that I cooked something.
Whew!
« Reply #372 on: Mon, 01 June 2015, 22:07:38 »
What a....
 :cool:   :cool:   :cool:
Offline Snowdog993
« Reply #373 on: Wed, 03 June 2015, 12:10:52 »
What a....
It's a pretty cool keyboard CPT.  I did find a video of someone converting one too.  I believe that influenced the person to modify their Wildcats' keyboard.
Cross Post:
They actually put the regular legends on it.  Took off the blue keys and put the regular keys on it, put a regular Model M overlay for the LED's, and put an IBM logo where the Wildcats logo was.  I believe it was a "Unicomp Special" for a low price and they just did that.  It went back to the Pearl/Pebble.
I guess they didn't like the Wildcats?  I don't know why.
I think they were influenced by this YouTube video, but I think they had a regular M for the keycaps.  They took ALL the blue keycaps off.  Just made it Pearl/Pebble.  Maybe they did it before or around the same time.
I couldn't PM you to give you that link.
Anyway, there is something more in the works going on....
Just a teaser shot:
« Reply #374 on: Wed, 03 June 2015, 12:14:14 »
Oh you said modify so I thought you meant like an actual mod. I don't really consider swapping keycaps a modification. Just a cosmetic change. I don't really like the Kentucky function caps either.
And that's samwisekoi.
Offline Snowdog993
« Reply #375 on: Wed, 03 June 2015, 12:22:31 »
Yeah, they just had a dead keyboard and swapped caps with it.  I guess that wouldn't be a mod.  But I am seriously not too sure if it were before or after that video was made.  I remember it being a few years ago.  Anyway, the next one does have to do with a controller swap.  (Another teaser..)
« Last Edit: Mon, 08 June 2015, 10:28:30 by Snowdog993 »
Offline retrochick
  • goodbye my wallet
« Reply #376 on: Tue, 09 June 2015, 01:57:28 »
Wow Snowdog993 you're quite the BS board modder! Nicely done LED mod  ;D
Here are pics of my Model M that I got in today.
103125-0
103127-1
103129-2
Going to put a set of dyed pbt keycaps on it from Gutz and update with more pics. Just waiting for my washed keys to dry lalalala~~~~
Offline Snowdog993
« Reply #377 on: Tue, 09 June 2015, 08:23:01 »
Looks pretty nice in it's natural habitat.  What color keys did you plan on putting on the keyboard?  It does make me wonder, hmmm.
Offline retrochick
  • goodbye my wallet
« Reply #378 on: Wed, 10 June 2015, 20:00:50 »
Here it is, jungle green and blue. Can't decide which one I like more. Opinions?
Offline XMIT
  • formerly jsoltren
« Reply #379 on: Wed, 10 June 2015, 20:17:51 »
Very nice! :-)
Where did you get such a lovely keyboard? ;-)
Offline retrochick
  • goodbye my wallet
« Reply #380 on: Wed, 10 June 2015, 20:24:37 »
Very nice! :-)
Thank you! Some dude in Texas  :p
Offline XMIT
  • formerly jsoltren
« Reply #381 on: Wed, 10 June 2015, 20:40:03 »
Very nice! :-)
You're welcome. :D
There are plenty more where that came from! I'll post something in the Classifieds soon-ish. But I'm a little busy at the moment - see https://geekhack.org/index.php?topic=72707.0.
Offline Snowdog993
« Reply #382 on: Thu, 11 June 2015, 11:28:12 »
They are both very nice.
Offline Snowdog993
« Reply #383 on: Thu, 09 July 2015, 09:32:57 »
Update: Finally finished, posted on DT somewhere or other when GH was down.
« Reply #384 on: Thu, 09 July 2015, 10:03:06 »
The Blue set is really nice!
Offline SixtyLife
« Reply #385 on: Sat, 11 July 2015, 15:38:30 »
found this beauty for $40 at a surplus warehouse. my first BS!
time to clean her up and convert
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #386 on: Sat, 11 July 2015, 15:48:25 »
nice score breh
Offline SixtyLife
« Reply #387 on: Sat, 11 July 2015, 16:26:48 »
nice score breh
thanks man!
Offline Sed8op8
  • Keyboard Padawan
« Reply #388 on: Sat, 11 July 2015, 16:57:53 »
nice score breh
$40 bucks did the have moe BWAHAHAHA very nice score though!!!!
thanks man!
« Reply #389 on: Sat, 11 July 2015, 20:12:32 »
Dang, nice grab!  :)  Post some pics after cleanup.   :thumb:
« Reply #390 on: Sun, 12 July 2015, 02:40:02 »
Excellent!  Especially with the yellow plate :)
Very nice find - and some interesting keycaps too!
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« Reply #391 on: Sun, 12 July 2015, 02:50:22 »
Which M is this? Is this a Kishsaver?
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
  • Formerly temence
« Reply #392 on: Sun, 12 July 2015, 02:51:03 »
Oh my bad, I misread the thread title. For some reason, I interpreted "Post your BS boards" as "Post your Model M's" since... well, yknow.
Offline SixtyLife
« Reply #393 on: Sun, 12 July 2015, 16:55:52 »
they had like 8 other model m's but this was the only ssk I saw, and it was in the unsorted employees only area of Weirdstuff warehouse for anyone in the bay area.
will do, thanks man! tried to disassemble it but realized I didn't have the right tool. need some 5.5mm nut driver. waiting for amazon to deliver
thanks! apparently related to displaywrite according to here: http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/9242/subcatid/0/id/120575
Offline Snowdog993
« Reply #394 on: Mon, 13 July 2015, 21:18:54 »
You could still post some pictures of yours if you like.
Offline Touch_It
« Reply #395 on: Mon, 13 July 2015, 23:42:05 »
Crappy picsof my 86 silver label M with newly added RGB mods.  Still dirty with a few missing caps but beautiful.  What I will say is that it does feel better than my 91 terminal m. And different, maybe better, than my 2 Unicomp boards.
« Reply #396 on: Tue, 14 July 2015, 05:37:38 »
Are your two green Shifts slightly different shades of green?
Offline Touch_It
« Reply #397 on: Tue, 14 July 2015, 12:14:08 »
Not even sure how you were able to see that, but yes, they are.  If I hadn't got them for free I would ask for replacements from Unicomp.  The left shift is darker than the right.  I much prefer the darker color.  Better yet would be some OG IBM caps, lol.  Also I will try to take better pics tomorrow.  Taking them on my iphone and posting through tapatalk = horrible quality :(.
« Reply #398 on: Tue, 14 July 2015, 22:07:18 »
Same here - must be something wrong with the way they make the right Shifts.
Offline njbair
    • nickbair.net
« Reply #399 on: Tue, 14 July 2015, 22:20:51 »
Unicomp's QC leaves something to be desired. My SSK replica keycap set arrived with a cracked F3 key, and the replacement, although free, does not match the rest of the keys 100%. Also, the right shift kept getting stuck because the stabilizer stem was out of alignment. I had to use a heat gun to heat the cap and bend it a little bit. Now it works fine.
My boards:
