Author Topic: Post your BS boards here!  (Read 611027 times)
Offline trees
  • I like bagels.
Re: Post your BS boards here!
« Reply #400 on: Wed, 15 July 2015, 00:07:44 »
all the keyboards on this thread are making it very hard to wait for my SSK...
B.Face HHKB - B.mini - Black/Purple Custom
Offline daerid
    • Rossipedia
« Reply #401 on: Wed, 15 July 2015, 00:16:06 »
Yes, it's a Unicomp. It was cheap, I like the caps, COME AT ME BRO
Offline 0100010
  • Not Sure
« Reply #402 on: Thu, 30 July 2015, 14:52:43 »
That looks nice.  If only they made a 7x white spacebar...
Offline Touch_It
« Reply #403 on: Thu, 30 July 2015, 14:54:00 »
If only :(.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #404 on: Thu, 30 July 2015, 15:09:03 »
If only :(.
I did the best I could....
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #405 on: Thu, 30 July 2015, 15:53:56 »
Tad Williams' books have a perfect height for repairing Model Ms (my wooden construction is not here, as always: the tools I need are not were I need them)! Anybody read Tad Williams? And not only Tolkien?
I bought a full sized Model M found at a local craig list, in very good condition, almost no rivets broken (I counted only two, and the rest could not break off easily), German language, for my fathers birthday, I hope he likes it. I know that chances are low he will actually use it, but at work he could type on it just for a day as a show-off for the colleagues - "hey, this guy is bad-ass typing on this clunky old keyboard". He is journalist, and we always had a lot of typewriters at home.
A good backpack is the one were a full sized Model M fits perfect inside:
« Reply #406 on: Thu, 30 July 2015, 19:10:18 »
Although unlikely that I'd be able to find such a backpack over here, which one is it?
I can just fit an SSK in my backpack, but not a full sized Model M.
Offline Mooksie
« Reply #407 on: Thu, 30 July 2015, 20:16:04 »
madhias that's a really cool present I hope he loves it!
I'm about to go put another coat of grey paint on my model M top case. A little lighter than industrial I think. More of a battleship grey I guess.
« Last Edit: Thu, 30 July 2015, 20:21:52 by Mooksie »
we use up all the cupholders during our furious love making sessions
Offline Snowdog993
« Reply #408 on: Thu, 30 July 2015, 20:20:25 »
Interesting color.
I tried that once.
Once.
Offline njbair
    • nickbair.net
« Reply #409 on: Thu, 30 July 2015, 21:02:58 »
Interesting color.
I tried that once.
Once.
That's not gray. Wait, is this one of those pics like that blue & black dress?
My boards:
Offline Snowdog993
« Reply #410 on: Thu, 30 July 2015, 21:11:15 »
Interesting color.
I tried that once.
Once.
It is.  It's actually a metallic gray color.  I think it is called soft iron.  Pretty nice complimentary color.
It looks good with the pearl/pebble.
It's not primer gray.  The shades from black to white can be called from extremely light to extremely dark gray.  The gray in mooksie's picture reminds of the primer I used below the flat iron.
« Last Edit: Thu, 30 July 2015, 21:25:05 by Snowdog993 »
Offline njbair
    • nickbair.net
« Reply #411 on: Thu, 30 July 2015, 21:30:09 »
Has anyone ever tried Plasti-Dip on a Model M case? I've seen some really nice smooth results with that stuff and I love the idea that you can peel it off and start over... just not sure about the finish.
My boards:
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #412 on: Thu, 30 July 2015, 23:40:09 »
It is from the brand 'EXPED', which is from Switzerland. Not too big, the size is OK for a daily usage.
http://www.exped.com/switzerland/de/product-category/rucksaecke/glissade-25-black#prettyPhoto
Offline Mooksie
« Reply #413 on: Fri, 31 July 2015, 17:44:48 »
ABORT MISSION. Really screwed up the paint when gluing on the label. It came out so nice too  :( RIP. The case was already ruined anyways so... to unicomp I go.
« Last Edit: Fri, 31 July 2015, 17:46:29 by Mooksie »
Offline Snowdog993
« Reply #414 on: Sat, 01 August 2015, 11:54:28 »
I had a similar thing happen....  The clear coat I put over the shell was fine until it dried.  Every bit of paint shriveled up and destroyed what it looked like.  That's why there are no other pictures of it.
Kind of a shame.  I liked the color a lot.  It worked well.
Offline njbair
    • nickbair.net
« Reply #415 on: Sat, 01 August 2015, 19:16:28 »
Sounds like you should have scuffed up the plastic and used a good primer or direct-to-plastic paint.
My boards:
Offline Mooksie
« Reply #416 on: Sat, 01 August 2015, 20:23:07 »
The reason I was painting it was because I smudged some black dye on it without realizing.(from dying caps)
Offline Snowdog993
« Reply #417 on: Sat, 01 August 2015, 21:38:55 »
I messed up on the varnish.  Learned enough to know that isn't the way you do it!
It's all good.
« Reply #418 on: Sat, 01 August 2015, 21:43:27 »
Plastidip is the worst.  It starts rubbing off almost immediately and you have to regularly redo it for it to look decent.  Even if you put on a thick coat, it still gets issues.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #419 on: Sun, 09 August 2015, 08:22:41 »
Offline Sed8op8
  • Keyboard Padawan
« Reply #420 on: Sun, 09 August 2015, 11:30:50 »
« Reply #421 on: Mon, 10 August 2015, 00:13:25 »
Very nice - SSK done well :)
Offline Mooksie
« Reply #422 on: Mon, 10 August 2015, 10:39:25 »
Awesome Madhias. That backdrop + the beautiful board makes a gorgeous photo. Nice job.
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« Reply #423 on: Sat, 15 August 2015, 02:04:17 »
My endgame board. That is... until the next expansion pack is released.
108369-0108371-1108373-2108375-3108377-4
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #424 on: Sat, 15 August 2015, 12:59:00 »
« Reply #425 on: Thu, 20 August 2015, 20:14:03 »
Two of my favorite BS boards  :)
IBM 4704 62-Key + Clacks by HoffmanMyster, on Flickr
Night Owl Mk2 by HoffmanMyster, on Flickr
Apologies for the Clack-centric shots.  :-[
« Reply #426 on: Thu, 20 August 2015, 20:28:47 »
do you need to get a tetanus shot every time you use that kish?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #427 on: Thu, 20 August 2015, 20:30:56 »
dirt adds character.
« Reply #428 on: Thu, 20 August 2015, 20:31:54 »
Nope.  It's unlikely that this keyboard spent much time outside.
https://en.wikipedia.org/wiki/Tetanus#Cause
Also that's not how Tetanus shots work.
* HoffmanMyster likes to ruin jokes
« Reply #429 on: Thu, 20 August 2015, 20:34:12 »
well..
« Reply #430 on: Thu, 20 August 2015, 20:36:23 »
That Clack trio on your 6019284 makes me happy <3. Grats on your haul
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #431 on: Fri, 21 August 2015, 01:22:51 »
A trick for plastidip is the first 2 coats need to be very thin.  This actually helps a lot with adhesion.  But coats after that can be thicker.  It does hide scuffs and scratches very well.
Offline XMIT
  • formerly jsoltren
« Reply #432 on: Fri, 21 August 2015, 15:44:27 »
Did somebody say beam springs?
109064-0
Offline njbair
    • nickbair.net
« Reply #433 on: Fri, 21 August 2015, 16:33:48 »
Can you weigh in on others' comments regarding durability? They made it sound like it wears off pretty quickly.
My boards:
Offline Melvang
« Reply #434 on: Fri, 21 August 2015, 18:36:01 »
I have it on the plates of my hacked up AT.  It is delicate in the sharper corners, but since I put it on, I haven't had any issues with it.  It is difficult to do touch up work without peeling it all off and starting over though.
Offline njbair
    • nickbair.net
« Reply #435 on: Fri, 21 August 2015, 21:31:06 »
Suppose I shouldn't be shocked and awed that a product marketed as easy to remove isn't the most durable thing in the world. Thanks for sharing!
My boards:
Offline Touch_It
« Reply #436 on: Fri, 21 August 2015, 21:35:43 »
Oooh that layout looks surprisingly usable.  If I were to ever get a beam spring, that would be my choice.
Offline Melvang
« Reply #437 on: Fri, 21 August 2015, 21:44:07 »
As much as I would love to try that layout, I didn't care for the beamspring switches I tried at the last con in Chicago.  The feel very light and smooth, I just lime the longer keystroke and heavier tactile bump in F style buckling springs.
Offline XMIT
  • formerly jsoltren
« Reply #438 on: Sat, 22 August 2015, 15:16:45 »
Thanks! This is an approximation to the layout that I used. The latching Lock key limits my options at the moment.
109144-0
« Last Edit: Sat, 22 August 2015, 15:20:04 by XMIT »
« Reply #439 on: Sat, 22 August 2015, 17:31:48 »
Offline Greystash
« Reply #440 on: Wed, 26 August 2015, 06:18:33 »
My first new/old board. (Love it ;D)
1391401 - Model M made by IBM 27th April 1993 with detachable PS2 and drainage holes.
« Reply #441 on: Wed, 26 August 2015, 22:03:09 »
it's amazing that such a classic design still looks great and is perfectly functional :)
Offline invariance
  • ...here with all the other boson's
« Reply #442 on: Mon, 31 August 2015, 18:48:16 »
Cleaned this old girl up and she is now as good as new  :)
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline cgbuen
    • cgbuen.io
« Reply #443 on: Sat, 26 September 2015, 16:29:17 »
Salute on my dirty Kish https://instagram.com/p/7yIa3PnGYK/
Offline Sed8op8
  • Keyboard Padawan
« Reply #444 on: Sat, 26 September 2015, 16:37:01 »
« Reply #445 on: Sat, 26 September 2015, 19:16:04 »
Mmmmm, I love me a dirty 4704...  ^-^
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #446 on: Sat, 26 September 2015, 19:16:57 »
A little bit of dirty is always good ;) . But man do I need me a kishy now...
Offline pr0ximity
« Reply #447 on: Sat, 26 September 2015, 20:12:17 »
Dirty is right. Dirty-dirty.
« Reply #448 on: Sun, 27 September 2015, 21:46:20 »
Sweet :)
But that's cable's far too white for the keyboard!
Offline BlueNalgene
« Reply #449 on: Sun, 27 September 2015, 22:02:59 »
Time to finally show off my 'finished' model M.
In early March this year, I bought a Model M from Jixr on the cheap.
The keyboard was bolt modded, had a wonky membrane, and no cable.  I did a few mods to it.
I dyed the caps aqua colored.  I oriented the caps in the same direction in the bath, and that gave them a nice gradient.
I removed the old connector and added a Teensy for USB capabilities.  I actually went through a few Teensys in the process.  I had a Teensy 2.0, but while soldering it I damaged one of the resistors/capacitors and the socket.  I did some work on it with the Teensy 2.0+, but I am going to use that for another project.  I bought a Teensy LC, but the ARM processor was giving me ****.  So I finally went with another 2.0.
I also desoldered all of the old crappy green LEDS and resistors on the breakout board.  I put in their place some bright blue LEDs and appropriate resistors for them.
So here we go:
I have a BS Brobot from the 4/20 sale on the esc
and a pair of glorious multi-shot Krap bonus caps on the pause and scroll lock buttons.
I'm pretty proud of the usb connector.  I took the old DIN socket and ripped it all to hell with my Dremel.  I made little slots so the teensy board would slide in and super glued it to that spot.  I filled in the open area with epoxy clay so it looks fairly clean.
So that is my sexy modded Model M.
