Author Topic: Does Metal case interfere with the Bluetooth communication?  (Read 10631 times)
Offline bickle
« on: Mon, 06 October 2014, 11:43:00 »
I want to change my Bluetooth keyboard case into metal.(Like aluminum)
But I'm concerned that it will interfere with the Bluetooth communication.
What do you think about this?
Re: Does Metal case interfere with the Bluetooth communication?
« Reply #1 on: Mon, 06 October 2014, 14:18:06 »
If the metal case is properly grounded than it can, but the bluetooth signal can go out the "front" side where the keycaps are. I would expect it to be usable but with decreased range but your mileage may vary.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Mon, 06 October 2014, 17:32:57 »
Yeah I've heard of it interfering with some of the insides (like two times) but nothing about the Bluetooth
Offline Tiramisuu
« Reply #3 on: Mon, 06 October 2014, 17:42:04 »
I've got the old dinovo edge that has plenty of aluminum on it and the bluetooth has never been an issue in the 10 foot range.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline bickle
« Reply #4 on: Tue, 07 October 2014, 00:49:18 »
Two times??
That's worse than Bluetooth interference!!  :eek:
Offline keynoob
« Reply #5 on: Mon, 31 July 2017, 14:23:27 »
Any update on this thread? I want to build a metal case for my BT Keyboard.
Offline Leslieann
« Reply #6 on: Mon, 31 July 2017, 20:21:43 »
Depends entirely on where inside the case that the antenna is located and it will not block it entirely, it will simply degrade the signal strength.
If it's in the bottom tray the signal will be terrible, not only do you have the case around it, but you have what amounts to a Faraday Cage above it. If you mount it up above the PCB and the plate (if you have one), then the signal will be fine. Laptops and cell phones have the same problem, antenna position is critical.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
