Author Topic: Alternate Layout Firmware for Poker II  (Read 17665 times)
Offline Hogesyx
« on: Wed, 29 October 2014, 03:01:24 »
While looking for a fix for LED state not behaving as per stated in the manual, I came across this firmware on pcwaishe[Chinese Forum].
Original Thread
WARNING:
ISO USERS HAS REPORTED MIX RESULTS AFTER FLASHING.
DO NOT FLASH UNLESS YOU HAVE AN WORKING ISO FIRMWARE BACKUP
(WHICH I DON'T HAVE)
Remarks:
Poker II comes with 4 dip switch, thus allowing 16 different combination.
1) Toggle mode switches shifted from fn+right shift to fn+left shift
2) Pn mode switches sfhited from fn+right ctrl to fn+left ctrl
3) Keys highlighted in RED are the one modifiable by the dip, do note that Win key is Left Win
4) DIP order are flipped(see picture)
81077-0
Download:
Firmware File (The file you want is Poker II 独立方向键 固件v0.5.bin)
English Firmware Flasher and guide from Vortex
Instructions:
1) Download the firmware file as well as the bundle from Vortext
2) Rename the firmware file a non unicode file name(eg custom_dip_0.5.bin), as the tool does not supports unicode
3) Follow the instructions in the Vortex bundle but use the file you prepared in step 2.
4) On successful flashing, hold fn+r for 12 seconds(or 9 left space bar LED flashes)
5) Do remember your fn and pn are no longer fn and pn anymore, change the DIP settings based on the above chart.
« Last Edit: Thu, 29 January 2015, 18:27:53 by Hogesyx »
Novatouch TKL | Ducky YOTR (Brown) | Ducky Shine (Brown)
Poker II (Red) | GH60 revchn (Clear)
Offline Oobly
Re: Alternate Layout Firmware for Poker II
« Reply #1 on: Wed, 29 October 2014, 14:31:35 »
This is quite awesome. Increases the flexibility of the Poker a whole lot (although it's pretty damn flexible already without this)!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Tiramisuu
« Reply #2 on: Wed, 29 October 2014, 16:12:47 »
Not sure how this is better.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline esoomenona
  • Gnillort?
« Reply #3 on: Wed, 29 October 2014, 16:30:53 »
« Last Edit: Tue, 01 September 2015, 09:36:33 by esoomenona »
Offline spiceBar
    • ChessTiger.com
« Reply #4 on: Wed, 29 October 2014, 20:08:59 »
I do not have any Windows computer.
How do I flash the Poker 2?
Offline Hogesyx
« Reply #5 on: Thu, 30 October 2014, 12:59:13 »
Don't look like Ikbc has flasher for other platform. Maybe try flashing in a vm?
« Reply #6 on: Thu, 30 October 2014, 13:05:51 »
This is why I keep a windows FLP (lightweight build of XP) box around: there's lots of windows on KB tool. If you need help acquiring an old, cheap computer, and a copy of windows, I can help.
You are probably better off installing it to a flash drive.
Offline ideus
  • Björkö.
« Reply #7 on: Thu, 30 October 2014, 13:40:19 »
Does this firmware could be flashed on a Poker X? Thank you in advance for any feedback.
Offline kebby
« Reply #8 on: Thu, 30 October 2014, 13:46:04 »
Any idea whether this works on an ISO layout Poker 2?  Is there any talk of this coming to the Pure Pro or does it have anything similar?
Offline spiceBar
    • ChessTiger.com
« Reply #9 on: Fri, 31 October 2014, 00:27:01 »
I could keep a Windows XP partition on one of my linux boxes, but I would use it less than once a year, so I wanted to avoid it.
I have a Windows XP image I can run in a VM, but I don't trust it would work reliably for flashing a firmware. I think it's a recipe for bricking the keyboard. I'll not be the one to tell you if it really bricks it because I'm not going to try anyway. :)
Offline tehj0shi
« Reply #10 on: Fri, 31 October 2014, 12:00:52 »
I tried it on my poker II de and it acted all strange and would then just stop typing. So I am not even sure it works at all.
Offline kebby
« Reply #11 on: Fri, 31 October 2014, 16:35:07 »
Thanks for subjecting your precious Poker 2 to testing. I believe Caekys stated on reddit that he had tested it so that might be a problem with the ISOs then... or just your Poker 2.
Offline spiceBar
    • ChessTiger.com
« Reply #12 on: Fri, 31 October 2014, 21:15:11 »
Last time an official firmware has been released, people have reported lots of problems. So it could just work on the ISO model, but maybe it's a bug in the firmware or a problem with the flashing process.
I think I'm going to stay away from this because I don't really need to reclaim those two keys anyway.
Offline Coreda
« Reply #13 on: Fri, 31 October 2014, 21:20:22 »
The single most annoying feature of the Poker II? The Fn+Shift layer that turns on without any indication. Perhaps not the right thread for it, but wow, the number of times I've unwittingly enabled that mode while using the Caps-as-Fn+WASD combo and wondered for several seconds why certain keys weren't working...
Offline jackalope
  • Now with 20% more soul.
« Reply #14 on: Sat, 01 November 2014, 03:47:00 »
Nice work
eh o well
Offline spiceBar
    • ChessTiger.com
« Reply #15 on: Sat, 01 November 2014, 05:44:48 »
The LED at the left end of the spacebar lights up, as far as I remember, when you activate this Pn mode.
But it's true that this key combination is a bad choice.
Keyboard manufacturers, most of the time, have no idea what they are doing. Except Matias.
That's why we need full programmability now.
Offline kebby
« Reply #16 on: Sat, 01 November 2014, 06:05:59 »
Do the ISOs use the same firmware in general?
Offline Coreda
« Reply #17 on: Sat, 01 November 2014, 17:05:05 »
Sorry, my mistake - Fn+Space. The light displays with Fn+Shift, but nothing for Fn+Space, which makes no sense as it's very easy to hit during typing (they're actually both too easy to mistakenly activate).
Absolutely. I saw a screenshot of GON's GUI for reprogramming his boards, looks decent.
« Last Edit: Sat, 01 November 2014, 17:08:02 by Coreda »
Offline dinoxor
« Reply #18 on: Wed, 05 November 2014, 15:15:00 »
Quick question,
if your fn pn no longer becomes fn pn, then what do they become now?
Thanks,
Offline Hogesyx
« Reply #19 on: Mon, 10 November 2014, 03:10:56 »
Doubt so, judging by the fact that simple variation requires a different binary. I am updating my post to warn ISO users, thanks to tehj0shi for testing.
Quick question,
Thanks,
They will become whatever you set your DIP with.
Offline tehj0shi
« Reply #20 on: Mon, 10 November 2014, 11:07:04 »
Just a quick update for any adventure seeking to tickle the last bit out of their poker II, I reflashed it with the firmware Vortex-JC posted and it works great again... But I really wished this firmware would work :-( maybe other Poker II ISO rockin' typist will have better luck...
Offline Hogesyx
« Reply #21 on: Wed, 12 November 2014, 02:36:09 »
Glad you got it working again.
btw: "Meat Brother" posted a new firmware recently as well, which supports breathing LED. I have yet to test it so I am not sure if it is based on the alternate firmware or the original firmware.
http://pan.baidu.com/s/1hq7UpRe
Offline tehj0shi
« Reply #22 on: Wed, 12 November 2014, 11:14:45 »
So I just tested it seems to be working so far even on my ISO. Very cool I just have not figured out the DIP Switches yet they seem not to be exactly like the picture above. Anyways I did get caps to be FN somehow and this was always a dream of mine so to do this via Hardware. Very cool!
Offline Hogesyx
« Reply #23 on: Thu, 13 November 2014, 09:29:28 »
Maybe it follows the original dip configuration? Is your win key the caps lock now?
Offline kebby
« Reply #24 on: Wed, 10 December 2014, 14:25:51 »
I can confirm that this works on my ISO Poker II as well so the first problem must have been a fluke. :) I guess there is no way at all to use Fn and Pn if you set the keys this affects to something else?
This is definitely a nice alternative for me as I disliked the lack of a dedicated Menu key on the Poker II. In terms of being able to just swap around the default keys, the v60 Mini still seems to be more flexible though.
« Last Edit: Wed, 10 December 2014, 14:45:43 by kebby »
Offline zshang
« Reply #25 on: Wed, 10 December 2014, 14:36:14 »
But I still can't swap CapsLock and L_Ctrl ?...
Offline kohi
« Reply #26 on: Fri, 12 December 2014, 16:09:06 »
ooh didnt know about this. breathing mode works too o: v cool
Offline kebby
« Reply #27 on: Wed, 07 January 2015, 08:32:46 »
How is the breathing mode activated?
Offline kohi
« Reply #28 on: Wed, 07 January 2015, 11:50:52 »
just flash the breathing mode firmware using the same program to update firmware, and then fn+v twice. first fn+v should be regular LED mode, and second fn+v should be the breathing mode. :thumb:
Offline ChumtheWaters
« Reply #29 on: Sat, 21 February 2015, 15:40:24 »
I tried the breathing LED as well and couldn't figure out the dip switches. If somebody more intelligent than me could take a stab at it I would greatly appreciate it. I have a funny feeling it won't let me get the combination I'm looking for. If I could get breathing mode to work with the same key swaps I have using the alternate setup I would be so stoked. I use 0101 right now which is the following:
Caps=FN
Win=Win
LAlt=Pn
RAlt=Alt
Edit: Switched to and am currently using the Breathing LED setup now. I'm not sure how the programmable layer works in this (having trouble doing things I would normally do with the default firmware). It seems PN+Commands don't work but they work fine in the Pn Lock layer.
« Last Edit: Sat, 21 February 2015, 17:57:36 by ChumtheWaters »
Offline dinoxor
« Reply #30 on: Tue, 31 March 2015, 16:28:07 »
Finally got this to work and it's great!
used the 0001 layout mapped all of my pn layers as follows:
Didn't realize that the pmode and toggles now uses the left ctrl and shift key.
Thanks again Hogesyx, I no longer need to rely on AutoHotKeys when carrying my poker II around!
Offline dinoxor
« Reply #31 on: Wed, 01 April 2015, 12:08:56 »
sorry for constantly reviving a dead thread but everyone should note that the ESC key no longer is the default
esc = `
fn+esc = esc
shift+esc =  ~
:[ oh well nothing AHK can't fix
