Author Topic: LZ plate fits  (Read 6018 times)
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
LZ plate fits
« on: Sat, 01 November 2014, 07:40:23 »
Just assembled my LZ-GH and I noticed that half of my plate was crooked... like the mounting points were way off, have anyone else had this issue with an LZ keyboard?
What do you guys think I should do?
New question does the lz-se plate fit a lz-gh case?
picture of a lz-se plate:
pic from zenuty
« Last Edit: Tue, 04 November 2014, 03:58:47 by Signature »
Offline Signature
  • master of puppers
  • snoozing
Re: LZ-GH quality issues
« Reply #1 on: Sat, 01 November 2014, 08:15:18 »
« Last Edit: Sat, 01 November 2014, 09:04:15 by Signature »
Offline 0100010
  • Not Sure
« Reply #2 on: Sat, 01 November 2014, 10:20:29 »
The plate and the PCB line up under the function row?  Or are the switches just temp mounted in the plate?
Offline Signature
  • master of puppers
  • snoozing
« Reply #3 on: Sat, 01 November 2014, 10:34:35 »
I had to modify some of them to make it work but they still look crooked and some interfere with eachother... Sucks since I payed big$$ to get a working keyboard and the seller didn't inform me of these issues. Should I ask for a partial refund or what do you think I should do?
« Reply #4 on: Sat, 01 November 2014, 10:48:06 »
someone had a KMAC whose plate was crooked like that. It was replaced, IIRC.
0100010: if you look at it, you can see some of the alignment issues: specifically on F, V, etc.
Offline Signature
  • master of puppers
  • snoozing
« Reply #5 on: Sat, 01 November 2014, 10:50:19 »
problem is that I don't think LZ has these plates anymore
Edit: you can also see the allignment issue easily if you look at the 2 and 3
« Last Edit: Sat, 01 November 2014, 10:52:01 by Signature »
Offline jameslr
« Reply #6 on: Sat, 01 November 2014, 11:55:45 »
Wow that's awful looking. I can't believe this plate is so jacked up. Is it bent or is that just a poor cut? How does this even happen on a laser cut? Those things are accurate to 10 micrometers usually. Are you sure you have those switches seated in there good enough? I'd start with the switches then work my way up. I have some alignment issues on my filco TKL that I desolder and resoldered MX clears. It's causing clearance problems with the arrow keys. I'm sure it's my screwup because it wasn't like that before. I need to desolder and resolder them to see if I can fix it. There is some tolerance / play in the switches when they're mounted on the plate.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline Signature
  • master of puppers
  • snoozing
« Reply #7 on: Sat, 01 November 2014, 12:01:35 »
Yeah it's the cutting in the plate unfortunately, I noticed it in the beggining but I thought it was supposed to be that way:/ Looks like I need to contact lz about a new plate but I doubt he Will have a new one :/
Offline Signature
  • master of puppers
  • snoozing
« Reply #8 on: Sun, 02 November 2014, 10:42:15 »
Hmm does it classify as an ergonomical keyboard now?  :rolleyes:
Also trying to get in contact with both LZ and boost (seller)
« Last Edit: Sun, 02 November 2014, 10:44:27 by Signature »
« Reply #9 on: Sun, 02 November 2014, 11:06:28 »
That's really odd.
I think I've seen it happen a few times in Kustoms, not just the LZGH. It's probably something that happens in shipping.
« Reply #10 on: Sun, 02 November 2014, 11:08:14 »
That's really odd.
No, something like this can't happen in shipping (if it's like that KMAC plate) I think it happens if someone bumps the laser halfway through.
Edit: It was halverson's KMAC. Check out the carnage:
http://geekhack.org/index.php?topic=38348.0
« Reply #11 on: Sun, 02 November 2014, 11:15:09 »
Different issue than I thought then.
More tag that pic, it's disgusting.
Offline Signature
  • master of puppers
  • snoozing
« Reply #12 on: Sun, 02 November 2014, 11:24:29 »
Dunno if this captures the issue completely but the market switches are the one with dislocation, exactly the same as dorkvader is talking about, easier to notice if you zoom in!
« Reply #13 on: Sun, 02 November 2014, 11:25:20 »
I was gonna but halvy didn't so I ain't either!
Anyway, if it's a similar issue to that KMAC plate, then it'd cause the same issue and certainly isn't shipping damage.
If the LZGH used aluminium plates, I'd just get a better one made out of steel. I'm thinking about doing that with my skeldon.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #14 on: Sun, 02 November 2014, 11:27:57 »
That's really odd.
Wow  :-X
|||My other keyboards :
x
« Reply #15 on: Sun, 02 November 2014, 11:29:17 »
Speaking of making things, where are the pics of my Dolch!?
ahem.
I think the LZGH is an Alu plate. I'd have to check, but I think that's right.
Offline Signature
  • master of puppers
  • snoozing
« Reply #16 on: Sun, 02 November 2014, 11:30:24 »
ahem.
it is indeed alu
« Reply #17 on: Sun, 02 November 2014, 11:31:50 »
That's really odd.
Wow  :-X
I still have that plate :)
Offline DrHubblePhD
  • I am star stuff
« Reply #18 on: Sun, 02 November 2014, 12:31:36 »
If anything see if LZ has the laser cutting file and you can cut your own. I don't know about you but I have some connections that easily cut it given the file.
Offline Signature
  • master of puppers
  • snoozing
« Reply #19 on: Sun, 02 November 2014, 13:26:11 »
Yeah I still need to get in contact with either boost or LZ. Just have to wait!
Offline OverKill
« Reply #20 on: Mon, 03 November 2014, 16:08:47 »
That's really odd.
Depending on the size of the machine bumping it could cause the issue but if it is a large machine (that can accept 4x8 sheets) you would have to bump it with a forklift. The bottom line is the material was moved while it was being machined.
Offline Muzi
« Reply #21 on: Mon, 03 November 2014, 17:39:58 »
the key caps looks nice
Offline Photoelectric
« Reply #22 on: Mon, 03 November 2014, 18:04:36 »
I've modded 2 LZ-GH keyboards and have not encountered this--everything fit perfectly.
Offline feizor
« Reply #23 on: Mon, 03 November 2014, 18:19:33 »
That's really odd.
Wow  :-X
Time for Gon's KMAC pcb and polycarb plate!
Offline Signature
  • master of puppers
  • snoozing
« Reply #24 on: Tue, 04 November 2014, 03:11:27 »
The lasering is the issue afaik, still got no contact with LZ tho, thinking of modding the plate to a 356.2 style
Offline Signature
  • master of puppers
  • snoozing
Re: LZ plate fits
« Reply #25 on: Tue, 04 November 2014, 03:58:57 »
update
Offline jameslr
Re: LZ plate fits
« Reply #26 on: Tue, 04 November 2014, 07:57:20 »
That's some trick or treat **** right there. Halloween at its finest.   :eek:
Offline DrHubblePhD
  • I am star stuff
Re: LZ plate fits
« Reply #27 on: Tue, 04 November 2014, 07:59:52 »
I'm no expert but it definitely looks like it should line up!
