Author Topic: NOW OPEN SOURCE!!! swill's plate building tool [builder.swillkb.com]  (Read 3999360 times)
Offline hvontres
  • Buckling Spring Enthusiast - Full Size Evangelist
Re: NOW OPEN SOURCE!!! swill's plate building tool [builder.swillkb.com]
« Reply #2250 on: Sat, 29 August 2020, 02:18:59 »
Looking for some help getting the builder to draw my plate.
Here's my KLE:
["Esc",{x:1},"F1","F2","F3","F4",{x:0.5},"F5","F6","F7","F8",{x:0.5},"F9","F10","F11","F12",{x:0.25},"PrtSc","Scroll Lock","Pause\nBreak"],
[{y:0.5},"~\n`","!\n1","@\n2","#\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{w:2},"Backspace",{x:0.25},"Insert","Home","PgUp"],
[{w:1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{\n[","}\n]",{w:1.5},"|\n\\",{x:0.25},"Delete","End","PgDn"],
[{w:1.75},"Caps Lock","A","S","D","F","G","H","J","K","L",":\n;","\"\n'",{w:2.25},"Enter"],
[{w:2.25},"Shift","Z","X","C","V","B","N","M","<\n,",">\n.","?\n/",{w:2.75},"Shift",{x:1.25, _c:"0"},"↑"],
[{w:1.25},"Ctrl",{w:1.25},"Win",{w:1.25},"Alt",{a:7,w:6.25},"",{a:4,w:1.25},"Alt",{w:1.25},"Win",{w:1.25},"Menu",{w:1.25},"Ctrl",{x:0.25},"←","↓","→"]
I'm trying to add a rounded rectangle cut out relative to the up arrow key.
I plug in some settings:
but then I get this output:
I'm not sure what I'm doing wrong. I've read the documentation multiple times but I'm still coming up short.
As far as I understand, I've defined the arrow key as the relative to point, left the first relative to field blank, and filled in the second relative to field whose numbers should be relative to the center of the switch I defined earlier. But no cut is made. I tried switching it to other layers(for a sandwich case) like the bottom to see if its actually making the cut but it still isnt.
Any assistance is greatly appreciated.
I think custom cutouts are broken right now. Adding material seems to work, but cutouts don't. It looks like the bug was introduced back in January : https://github.com/swill/kad/issues/19
Henry von Tresckow
1986 Model M 1390131, 1987 Model M 1391401 , 1993 Model M2 Modded Reddragon k556(Test Mule) Boston Prototype x2 (Daily Drivers :) )
Offline ideus
  • Björkö.
« Reply #2251 on: Fri, 02 October 2020, 21:34:07 »
Is the builder's site not working?
Offline Narf
    • Krado Industries
« Reply #2252 on: Sat, 03 October 2020, 12:09:40 »
It has been down for me since evening of Oct 1.
Offline ideus
  • Björkö.
« Reply #2253 on: Sat, 03 October 2020, 12:44:39 »
I found it yesterday when trying to build a plate for my upcomoing build. I hope it gests back to work soon.
Offline ideus
  • Björkö.
« Reply #2254 on: Sat, 03 October 2020, 12:59:14 »
Does someone have the coordinates for 60% standard holes's centers and the proper size for an standard 60% plate?
I just found this today, in case someone needs a plate asap.
http://www.keyboardcad.com
However, it does not provide the cut for 60% case's holes.
« Last Edit: Sun, 04 October 2020, 00:02:10 by ideus »
Offline SE7EN_ate_NINE
« Reply #2255 on: Sun, 04 October 2020, 13:19:33 »
Sadly that one doesn't work for 7U space, gives an error.  :(
Offline xiaoquana
« Reply #2256 on: Mon, 05 October 2020, 05:41:45 »
Hi,swill, the website "builder.swillkb.com" seems to have laydown ,can you please repair it , thanks!
Offline ideus
  • Björkö.
« Reply #2257 on: Mon, 05 October 2020, 07:18:26 »
Swill was active the last time on July 29. I hope he is OK. At his site the only page working is the frontend. Everything seems not working behind it.
Offline ideus
  • Björkö.
« Reply #2258 on: Mon, 05 October 2020, 07:20:02 »
It lacks corner rounding, holes for bolts for sixty cases and other nicities that Swill's have.
Offline ideus
  • Björkö.
« Reply #2259 on: Wed, 07 October 2020, 21:31:07 »
Swill's builder is back and working.
http://builder.swillkb.com
Offline stotle.caps
« Reply #2260 on: Fri, 16 October 2020, 05:05:15 »
i want to make a gasket mount plate like this shorturl.at/afwRW any info on how to make it
Offline ideus
  • Björkö.
« Reply #2261 on: Fri, 16 October 2020, 07:51:22 »
Your link does not work. At least for me.
Offline stotle.caps
« Reply #2262 on: Sat, 24 October 2020, 05:57:24 »
like this,my bad the url is broken for some reason
« Last Edit: Sat, 24 October 2020, 06:06:46 by stotle.caps »
« Reply #2263 on: Sat, 24 October 2020, 08:30:45 »
That's going to need custom polygons, the 'cut polygon' option is broken but 'add polygon' works.  Looks like you want 'plate corners' on, then add six rounded rectangles above/below but without seeing the whole plate I can't be sure.
Offline stotle.caps
« Reply #2264 on: Fri, 30 October 2020, 05:02:44 »
roughly like this,sorry for the late reply,been doing some raw sketch for the alst couple days,but i want to make the plate looking like this,i already try to add custom polygons,but its so complicated for me to understand,and i dont want any mounting holes on the plate cause it will be sandwiched between acrlylic case
« Last Edit: Fri, 30 October 2020, 05:09:32 by stotle.caps »
Offline jrel
« Reply #2265 on: Mon, 02 November 2020, 07:18:07 »
Hey,
I am in the planning process of building a 40% keyboard with OLED, rotary encoder and underglow.
That is my current draft:
http://www.keyboard-layout-editor.com/##@_name=jr-planck&plate:true&pcb:true%3B&@=Magic1&_x:1%3B&=Magic2&=Magic3&=Magic4%3B&@_a:7%3B&=Tab&=Q&=W&=E&=R&=T&=Y&=U&=I&=O&=P&=Back%20Space%3B&@=Esc&=A&=S&=D&=F&=G&=H&=J&=K&=L&=%2F%3B&='%3B&@=Shift&=Z&=X&=C&=V&=B&=N&=M&=,&=.&=%2F%2F&=Return%3B&@=&=Ctrl&=Alt&=Super&=%2F&dArr%2F%3B&_w:2%3B&=&=%2F&uArr%2F%3B&=%2F&larr%2F%3B&=%2F&darr%2F%3B&=%2F&uarr%2F%3B&=%2F&rarr%2F%3B%3B&@_rx:9.25&ry:1&y:-1&x:-0.25&c=%23000000&t=%23ffffff&f:7&w:2%3B&=OLED
  • How could I add a placeholder for the OLED cutout? How can I set the right dimensions for it? Can I place it at the edge and have no border for it?
  • Is there a way to add some wings for a gasket mounted  plate?
  • Is there a way to handle flex cutouts?
« Reply #2266 on: Mon, 16 November 2020, 12:31:27 »
Sorry for the even slower reply!
If you add some measurements and the KLE for your switches I'll have a go, without them I can't.
Hey,
You would really like 'subtract polygons' to work for 1 and 3, but it doesn't.  The only way to make it would be to build it out of lots of polygons and I'm not sure how that would work as you want switch holes in twobof them.
2 is the same as stotle's?  If sobyou jyst 'add polygons' round the edge.
Offline TalkingTree
    • My projects
« Reply #2267 on: Mon, 16 November 2020, 13:14:24 »
@stotle.caps, @jrel:
This code:
Code: [Select]
Top and bottom supports:
Add polygon - Custom polygon.
shape: [-x/2-10,-y]; [-10,-y]; [x/2-10,-y]; [-x/2-10,y]; [-10,y]; [x/2-10,y]
path: [0,0]; [5,-5]; [15,-5]; [20,0]; [15,5]; [5,5]
Top and bottom supports holes:
Cut polygon - Circle.
diameter: 3
shape: [-x/2,-y-5]; [0,-y-5]; [x/2,-y-5]; [-x/2,y+5]; [0,y+5]; [x/2,y+5]
circle centers: [0,0]
Lateral supports:
shape: [-x,-y/2-10]; [-x,y/2-10]; [x,-y/2-10]; [x,y/2-10]
path: [5,5]; [5,15]; [0,20]; [-5,15]; [-5,5]; [0,0]
Lateral supports holes:
diameter: 3
shape: [-x-5,-y/2]; [-x-5,y/2]; [x+5,-y/2]; [x+5,y/2]
Will give you something like this:
* toad v2.1.svg (19.78 kB - downloaded 405 times.)
Offline debo
« Reply #2268 on: Sat, 03 April 2021, 18:38:26 »
It would appear the online tool is still busted when it comes to the cutout. I really hope the author is well and that he is just overwhelmed by life and work.
I also tried to build from source but without luck. Is there a working version of this tool somewhere else? Thanks in advance for your help.
