Author Topic: how do I put the coil back into the connector? Filco cable.  (Read 2494 times)
Offline FinancialWar
« on: Tue, 18 November 2014, 05:44:41 »
You know the connector that connects cable to the board, one of the child cables well out, how do I secure it back into place?
« Last Edit: Tue, 18 November 2014, 05:47:27 by FinancialWar »
Offline feizor
Re: how do I put the coil back into the connector? Filco cable.
« Reply #1 on: Tue, 18 November 2014, 06:23:28 »
Stick it back into the pin and use a pair of needle nose pliers to close the pin around it.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #2 on: Tue, 18 November 2014, 07:27:20 »
There should be a point on the pin where you push it down like a button and slide the pin out from the connector, then you'll want to stick the wire back into the pin and clamp the end back down and then slide the pin back into the connector.
*edit* Alternatively you could solder it while it's out.
« Last Edit: Tue, 18 November 2014, 07:32:30 by Evo_Spec »
GON NerD TKL DTA Edition
« Reply #3 on: Tue, 18 November 2014, 07:39:11 »
I can't do it, can yo tell me where can I buy a replacement cable?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Tue, 18 November 2014, 07:42:46 »
You could get one from one of the cable makers here like Zeal or Pexon.  They'll be a little pricier than a stock cable but really high quality and customizable
« Reply #5 on: Tue, 18 November 2014, 07:48:23 »
sure, do you have the link?
« Last Edit: Tue, 18 November 2014, 08:05:23 by SpAmRaY »
« Reply #7 on: Tue, 18 November 2014, 08:05:19 »
I haven't been here for like half year and 95% of my posts are non keyboard related.
« Reply #8 on: Tue, 18 November 2014, 08:12:40 »
@spamray
Thanks.
« Reply #9 on: Tue, 18 November 2014, 08:15:10 »
Zeal doesn't seem to sell Filco cables.
« Reply #10 on: Tue, 18 November 2014, 08:20:33 »
Jesus 32AUD for a cable?? Aren't there like $2 ones from Hong Kong or something?
Offline Oobly
« Reply #11 on: Tue, 18 November 2014, 08:47:04 »
^^ This...
Easiest and cheapest solution, although it requires a bit of fiddly work.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #12 on: Tue, 18 November 2014, 09:03:37 »
what is that thing in your avatar?
Offline Oobly
« Reply #13 on: Tue, 18 November 2014, 09:12:42 »
