Author Topic: diodes for PCB?  (Read 3497 times)
Offline Jixr
diodes for PCB?
« on: Wed, 10 December 2014, 09:42:06 »
Hi everyone.
I recently bought a nerd60 pcb and I misunderstood and thought that it came pre-soldered with diodes.
I don't know anything about diodes, and are there different kinds? and is this something I can pick up at a local radio shack?
I was getting ready to make the build today and kinda bummed out now.
Offline 0100010
  • Not Sure
Re: diodes for PCB?
« Reply #1 on: Wed, 10 December 2014, 09:46:17 »
1N4148 diode is what you want most likely.  Through hole or SMD depends on the PCB.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: diodes for PCB?
« Reply #2 on: Wed, 10 December 2014, 09:51:04 »
I'm yet to see any MX based boards use other diodes that 1N4148.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: diodes for PCB?
« Reply #3 on: Wed, 10 December 2014, 09:51:46 »
Please note that diodes have polarity:
Happy Soldering!
Offline Jixr
Re: diodes for PCB?
« Reply #4 on: Wed, 10 December 2014, 09:56:34 »
okay, well now that I got that info thats helpful.
while we are on topic of this kinda stuff, why is it recomended that you solder in resistors for LED's? I've never had any issues soldering in leds without adding resistors.
And my pcb can use either the stick kind or the smd kind, and i'll check out some radioshacks and see if I can find some Diodes.
Thanks guys.
EDIT: Looks like I can buy these at local radioshacks, pfew, I was worried I was going to have to order online and end up waiting a few weeks. Was hoping to get this one built and then give one of my other 60%'ers to a friend for christmas.
« Last Edit: Wed, 10 December 2014, 10:02:56 by Jixr »
Offline FrostyToast
  • Litshoard
Re: diodes for PCB?
« Reply #5 on: Wed, 10 December 2014, 10:08:21 »
Use the through hole diodes if at all possible.
The SMD ones are ****ing tiny as hell.
If you want something for scale, it's maybe smaller than a grain of rice.
Quote from: elton5354
Offline heedpantsnow
  • Old enough to know better
diodes for PCB?
« Reply #6 on: Wed, 10 December 2014, 10:09:53 »
If you're new to soldering then thru hole might be better than SMD starting out. I have the same pcb on the way and might not do the SMD stuff myself at all.
Edit: Frosty Ninja beat me.
I'm back.
Offline DrHubblePhD
  • I am star stuff
Re: diodes for PCB?
« Reply #7 on: Wed, 10 December 2014, 10:12:47 »
I believe that all he nerd PCBs are designed for through hole diodes, GON sells the correct type diode, I'm sure you can find the same specs on mouser. It shouldn't be too hard to solder, however the pads might be a bit small.
Offline evolveS
  • ಠ_ಠ
Re: diodes for PCB?
« Reply #8 on: Wed, 10 December 2014, 10:17:23 »
For the NERD60, all the backlighting & housing LEDs use SMD resistors but the switches require through-hole diodes (which has been said). You can check out the customizing service options for verification.
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline Jixr
Re: diodes for PCB?
« Reply #9 on: Wed, 10 December 2014, 10:20:59 »
I actually already have some SMD resistors for the LEDs, but are they needed?
Offline evolveS
  • ಠ_ಠ
Re: diodes for PCB?
« Reply #10 on: Wed, 10 December 2014, 10:24:24 »
You need resistors with LEDs because they will burn out otherwise.
-a petty thief
Offline Jixr
Re: diodes for PCB?
« Reply #11 on: Wed, 10 December 2014, 10:27:09 »
Hm... I've never had any issues in my other keyboards adding LED's without resistors.
Offline DrHubblePhD
  • I am star stuff
Re: diodes for PCB?
« Reply #12 on: Wed, 10 December 2014, 12:45:31 »
I'm guessing that you are talking about the poker II or similar boards that, as far as I know, ship with resistors already soldered.
Offline Jixr
Re: diodes for PCB?
« Reply #13 on: Wed, 10 December 2014, 13:29:27 »
cool, radioshack had the diodes, $6 for 100 of them. Sweet.
Offline DrHubblePhD
  • I am star stuff
Re: diodes for PCB?
« Reply #14 on: Wed, 10 December 2014, 15:32:50 »
be carefull and make sure they are the same spec and size!
Offline Jixr
Re: diodes for PCB?
« Reply #15 on: Wed, 10 December 2014, 16:54:35 »
box says 1n914 type diodes, 1n914/1n1948
I'll wire one up and test it first to make sure its working right before I do them all.
Offline 0100010
  • Not Sure
Offline Jixr
Re: diodes for PCB?
« Reply #17 on: Wed, 10 December 2014, 18:13:58 »
cool, wired one up and it seems to work, adn the diodes themself do have the 8 on the end, so I should be fine.
Thanks for the help guys.
