Author Topic: Kinda regretting lubing cherry mx reds FML  (Read 9121 times)
Offline Hellcatz
« on: Thu, 25 December 2014, 19:25:01 »
So first time lubing after spending so many hours un-soldering, lubing, and re-soldering my keyboard I find I don't find my keyboard attractive to type on anymore. Its feels sluggish and has a slow reflex Prob goofed and applied to much or might get a heavier spring. Thoughts on a fix? used https://ctrlalt.io/ thin lube
Re: Kinda regretting lubing cherry mx reds FML
« Reply #1 on: Thu, 25 December 2014, 19:47:27 »
You only need a very small amount of lube.
Offline Hellcatz
« Reply #2 on: Thu, 25 December 2014, 19:50:51 »
feels a lot like typing on membrane keys
Offline dante
« Reply #3 on: Thu, 25 December 2014, 19:51:25 »
Can't wait to try some Gateron's - I hear they are very smooth out of the box.
Offline Hellcatz
« Reply #4 on: Thu, 25 December 2014, 19:52:55 »
some wat?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #5 on: Thu, 25 December 2014, 19:54:30 »
some wat?
They're a newer cherry mx clone
Offline Hellcatz
« Reply #6 on: Thu, 25 December 2014, 20:25:55 »
buying them is prob out of the question then
Offline dante
« Reply #7 on: Thu, 25 December 2014, 20:30:37 »
There is a Gateron switch tester up on Mass Drop now.  There was a hint dropped that if enough interest develops that switches may be offered for sale.
Offline Hellcatz
« Reply #8 on: Thu, 25 December 2014, 20:32:46 »
pretty expensive for just testers but then again I did spend 350 for a gon keyboard that Im going to build
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9 on: Thu, 25 December 2014, 20:56:11 »
Give it a week or two before you do anything. I had a similar problem with MX clears and a bit of usage helped a lot. I was lucky enough to have a plate where I could open the switches, so I did switch from 62g to 65g, but the still felt sluggish for a week or so. They got better with some wear though.
Offline Hellcatz
« Reply #10 on: Thu, 25 December 2014, 21:03:31 »
I hate plate mounted keyboards!!! After yesterday I have new found hate for em
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #11 on: Thu, 25 December 2014, 21:23:13 »
Just get a plate you can open the switches on. :) don't hate the plate, hate the boso company that gave you a ****ty one.
Offline honoka
« Reply #12 on: Fri, 26 December 2014, 15:11:59 »
Getting a custom plate isn't that easy though. I wish I hade a bunch. Soldering fumes has made me stupid :)
OP! As suggested, give the lube some time. If it doesn't clear up and still feels sluggish after a while I then consider desoldering and fitting a heavier spring. Or buy new red switches. Worst case.
« Last Edit: Fri, 26 December 2014, 15:14:39 by honoka »
Offline Hellcatz
« Reply #13 on: Fri, 26 December 2014, 18:31:13 »
Whats the purpose if the plate anyway? My guess is that it is used to protect the pcb from rubbish
« Reply #14 on: Fri, 26 December 2014, 18:35:55 »
Mount switches straight. It does a better job of it than the PCB mount holes.
Offline Hellcatz
« Reply #15 on: Fri, 26 December 2014, 18:42:56 »
THATS IT? for that much hassle?
« Reply #16 on: Fri, 26 December 2014, 18:47:15 »
That's not what it's for. Plates don't mount the switches any straighter than PCB mount holes.
It makes the switches more stable, as it holds them rigidly in place. It stops any kind of flex you would have while the switches are just mounted on a PCB. It of course makes the board more heavy and 'solid feeling' too.
« Reply #17 on: Fri, 26 December 2014, 18:48:38 »
You're not exactly supposed to be opening these things. There's a reason it voids your warranty.
Yeah that too I guess
I've never noticed a huge difference.
Offline Hellcatz
« Reply #18 on: Fri, 26 December 2014, 18:51:08 »
warranty was meant to be voided!!!
« Reply #19 on: Fri, 26 December 2014, 18:52:22 »
I'm surprised. I think there's a large difference in feel between plate and PCB mount boards. I could definitely distinguish between the two by feel alone.
It's not 'that too'. It's 'only that'. Really, switches mounted just on a PCB will mount perfectly straight, so long as the switches have the two extra plastic pins and so long as the holes are the correct size on the PCB [I have encountered one PCB where they were too big, and they could potentially be mounted a bit off-center].
Offline Hellcatz
« Reply #20 on: Fri, 26 December 2014, 19:04:17 »
I guess I will find out the difference when I finish building my keyboard
« Reply #21 on: Fri, 26 December 2014, 19:06:36 »
I've seen some odd alignment issues with PCB mount boards.
I dunno, I've had a lot of weird experiences with older boards.
Offline berserkfan
« Reply #22 on: Sat, 27 December 2014, 00:08:20 »
You can't claim to be a real gher until you void the warranty on everything electronic you own (except for maybe the hard disk).
I'm certainly not a real gher, since I have not tried repairing my TV or handphone before.
 :p
« Reply #23 on: Sat, 27 December 2014, 00:52:55 »
 :p
Warranty on my mattress is void, can confirm.
Offline berserkfan
« Reply #24 on: Sat, 27 December 2014, 02:05:54 »
 :p
You took apart your mattress? For what?
Don't tell me you decided to put the springs in your Topre?  :p
Offline sorijealut
    • steam
« Reply #25 on: Sat, 27 December 2014, 02:06:42 »
Lube up(?) those mattress springs!
I wonder the what's the force of actuation required on those!
« Reply #26 on: Sat, 27 December 2014, 03:20:12 »
 :p
You have an electronic mattress?
Offline Hellcatz
« Reply #27 on: Sat, 27 December 2014, 12:19:38 »
Mattress keyboard?
« Reply #28 on: Sat, 27 December 2014, 12:43:02 »
If you've never woken up with a keyboard imprint on your face, you have never really slept.
Offline Hellcatz
« Reply #29 on: Sat, 27 December 2014, 13:38:19 »
Does banging my head against one count?
« Reply #30 on: Sat, 27 December 2014, 17:52:11 »
Does banging a keyboard against someone else's head count?
Offline Hellcatz
« Reply #31 on: Sat, 27 December 2014, 18:14:16 »
Sure use my poker! It has some heft to it so it make a better imprint  ;D
Offline sorijealut
    • steam
« Reply #32 on: Sat, 27 December 2014, 18:24:16 »
Model Mattress
Offline Hellcatz
« Reply #33 on: Sat, 27 December 2014, 18:27:58 »
Model Mattress
I get what your getting at but i prefer to have a real model as a mattress
Offline sorijealut
    • steam
« Reply #34 on: Sat, 27 December 2014, 18:33:51 »
Model Mattress
Can't argue with that one.
« Reply #35 on: Sat, 27 December 2014, 18:37:59 »
You're crazy. Lubed reds are God Tier switches, dare I say better than Topre?!?  :eek:
Offline Hellcatz
« Reply #36 on: Sat, 27 December 2014, 18:40:57 »
As I said I might have screwed up
« Reply #37 on: Sat, 27 December 2014, 18:43:51 »
Ohh, too much lube? Well you can clean it off with rubbing alcohol and q-tips, but again, it's extremely tedious. Switch work is usually tedious :(
That's when you hire someone else! :)
Offline sorijealut
    • steam
« Reply #38 on: Sat, 27 December 2014, 18:44:36 »
Dirty deeds ~
done dirt cheap!
Offline Hellcatz
« Reply #39 on: Sat, 27 December 2014, 18:45:44 »
Born Asian Born Cheap
« Reply #40 on: Sat, 27 December 2014, 19:46:24 »
Less of a difference on eg a poker, but g80-8113 is floppy.
Some boards that done have a in switch LED or diode I think are bad PCB mount. Stabilizing the front of the switch with something is very important.
Isopropanol does noting to krytox. All about those q-tips though.
Offline Hellcatz
« Reply #41 on: Sat, 27 December 2014, 19:55:36 »
def not looking forward to unsoldering all those led and switches
Offline Joebroniee
« Reply #42 on: Sat, 27 December 2014, 20:06:34 »
DO IT! lol
Offline Hellcatz
« Reply #43 on: Sat, 27 December 2014, 20:16:53 »
not now
Offline Joebroniee
« Reply #44 on: Sat, 27 December 2014, 20:39:52 »
i know, just trying to motivate you in a way...peer pressure.
Offline honoka
« Reply #45 on: Sun, 28 December 2014, 11:27:03 »
I agree with Joebroniee. DO IT NOW. More pressure, better results!
Hugs
