Author Topic: What mounting style is used for most SP keycaps  (Read 2675 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« on: Mon, 05 January 2015, 04:40:31 »
There's a ton of SA/DSA/DCS keycaps, but I never paid attention to the type of mounting that was in use. According to SP's site there are 4 options available for MX compatible stems.
Anyone aware of the mount style generally used?
86430-0
Re: What mounting style is used for most SP keycaps
« Reply #1 on: Mon, 05 January 2015, 13:03:04 »
i think it depends on the profile.
Offline Lu_e
« Reply #2 on: Mon, 05 January 2015, 13:59:07 »
So the recess is the only difference? DCS is definitely quite a bit recessed. I don't own any others :p
Just say NO to ABS keycaps
Offline Oobly
« Reply #3 on: Mon, 05 January 2015, 16:46:11 »
SA profile uses PU. It's even printed on the inside of the caps.
I'd say DCS could also be PU also since the ones I have seem flush, but .005" is a tiny amount, so they could also be 4U.
I don't own any DSA caps right now, so I can't check those, but I think I remember seeing what could have been 6U printed on the inside of one of them at some point... Best if someone who as some chips in with more detail I guess.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline MOZ
  • Busy making stuff
« Reply #4 on: Tue, 06 January 2015, 06:54:12 »
I wasn't aware it was stamped on the inside. I shall go home and check.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #5 on: Tue, 06 January 2015, 07:04:06 »
I'm a total noob.  I didn't even know this **** existed.
Offline MOZ
  • Busy making stuff
« Reply #6 on: Tue, 06 January 2015, 07:05:43 »
We're all noobs here (And I'm the king), else we'd have had a definitive answer by now :P
