Author Topic: Keyboard with AT/XT switch not working  (Read 1873 times)
Offline essex
« on: Thu, 08 January 2015, 11:21:19 »
Hey,
My keyboard which I just got (http://deskthority.net/wiki/Commodore_KPQ-E99YC) doesn't work on my computer. It has an AT/XT switch underneath and I have set it to AT, however when i connect it nothing happens. When I switch it to XT the capslock numlock lights are turned on. Could it be some driver issues?
EDIT: To clarify, the  interface is PS2, however the model number is the same. It's a compaq keyboard which is manufactured in 1992 and the model number is KPQ-E99YC
Thanks in advance
« Last Edit: Thu, 08 January 2015, 11:37:52 by essex »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Keyboard with AT/XT switch not working
« Reply #1 on: Thu, 08 January 2015, 11:25:36 »
Are you using an active PS/2 adaptor?
Offline essex
« Reply #2 on: Thu, 08 January 2015, 11:28:45 »
Well the interface is PS2, its a different keyboard but the model name is the same.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #3 on: Thu, 08 January 2015, 11:31:27 »
I'm assuming you're connecting it to your computer through usb, in which case you would need something like this
Offline essex
« Reply #4 on: Thu, 08 January 2015, 11:36:14 »
Hey,
My mobo does have a PS/2 keyboard connector in the rear IO. And the keyboard itself has a PS2 connector. SO why can't I just connect the keyboard to the PS/2 port?
