Author Topic: 75% Keyboards?  (Read 26532 times)
Offline chuckster
75% Keyboards?
« on: Thu, 29 January 2015, 02:22:57 »
I really like the KBT Race, but was looking for something with a larger R Shift key. Are there any 75% boards out there that fit the bill? I con't find many 70/75% models period.
Also, what is this? Is it custom? I think this is just about perfect (or at least as close to perfection that any kind of TKL board can be):
If it isn't custom, I must have it! It would pretty much end all issues I have with Full size vs. 60% boards.
Offline Heliosphere
Re: 75% Keyboards?
« Reply #1 on: Thu, 29 January 2015, 02:30:17 »
Reverse Google image search revealed it as a LZ MX Mini: https://dangwang.wordpress.com/2012/11/16/420-reviews-lz-mx-mini-by-lifezone/
Correction: It's a LZ MX Mini SE https://dangwang.wordpress.com/2013/05/20/order-keyboard-in-january-get-in-may-lz-mx-mini-se-21/.
Edit2: The original owner of the specific keyboard in your photo (#21) actually just sold it on mechmarket for $700 http://www.reddit.com/r/mechmarket/comments/2u0hm1/wts_selling_90_of_my_remaining_collection_kmac_lz/
« Last Edit: Thu, 29 January 2015, 15:16:52 by Heliosphere »
Offline flaming_june
Re: 75% Keyboards?
« Reply #2 on: Thu, 29 January 2015, 02:45:14 »
I think many of us would like one like that but with more spacing.  Atm you either go TKL or 80% with numpad and no arrow keys.
Offline Oobly
Re: 75% Keyboards?
« Reply #3 on: Thu, 29 January 2015, 07:08:43 »
For me, TKL or 60% are best. 75% has a few disadvantages:
1. Non-standard layout - requires retraining your muscle memory for finding keys like the arrows.
2. Non-standard keycap sizes - means most aftermarket sets won't fit, in some cases none at all will fit. The one in the picture you posted is about the most compatible I have yet seen, but even that has mismatched legends on the keys above the right arrow.
The only disadvantage to TKL is the size, and it's very close to 75% in width, which is the dimension that matters most on a desk.
60% you have to use a Fn layer for arrow keys, edits and F keys and sometimes the Fn key is in an awkward place, but it's the most compact and there are some with great Fn layers and key placement options (original KBT Pure) or programmability (Poker II, GH60, GON NerD60, Infinity, etc).
Out of all the "compact" layout boards I've seen, the one I like best is the Leopold FC660M:
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Data
Re: 75% Keyboards?
« Reply #4 on: Thu, 29 January 2015, 08:29:53 »
My Octagon should be shipping soon-ish.  It's 75%.
Key caps shouldn't be a problem depending on which bottom row layout you pick, assuming you've got options.  Most key sets have a Tsangan kit.  That should cover the odd sizes you might need.  And you may have a slight profile mismatch on the far right column depending on which keys you want there, but that isn't really a big deal for me.
All the 75% boards I've ever seen are customs.  I don't know of any commercial versions -- but that doesn't mean they don't exist.  :P
Offline blighty
Re: 75% Keyboards?
« Reply #5 on: Thu, 29 January 2015, 09:28:22 »
75% production boards?  Noppoo choc mini and Keycool 84.
« Last Edit: Thu, 29 January 2015, 09:31:19 by blighty »
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline Jotokun
Re: 75% Keyboards?
« Reply #6 on: Thu, 29 January 2015, 09:58:58 »
Not entirely true. For a long while, 75% was very common on laptops. I've owned three laptops in a row, all of different manufactures (Toshiba, Compaq, Dell), with almost exactly the same 75% layout in the past. It seems to be less common now as everyone tries to copy the macbook's 60% layout on their laptops, but I still wouldn't call it non-standard. There are people with muscle memory built up for it.
Caps are a pain, though. IMO that's the only drawback aside from not enough options existing for the layout.
« Last Edit: Thu, 29 January 2015, 10:00:57 by Jotokun »
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline blighty
Re: 75% Keyboards?
« Reply #7 on: Thu, 29 January 2015, 14:07:50 »
Caps aren't that hard to find for 75%.
89108-0
MX mini has an old Cherry 1800 set on it, while the Keycool 84 has the Skull Squadron DSA on it.
Offline Evrycard
Re: 75% Keyboards?
« Reply #8 on: Thu, 29 January 2015, 17:31:39 »
I soooo want one.  :thumb:
Re: 75% Keyboards?
« Reply #9 on: Thu, 29 January 2015, 20:01:49 »
Unfortunately it just doesn't work as for gamers as well.
Offline Oobly
Re: 75% Keyboards?
« Reply #10 on: Fri, 30 January 2015, 01:34:24 »
For the more common 75% boards, yes, they are. You have the 2 easiest and still both need a 1.75x right shift and still the keycap profile or legend won't match on the keys above the right arrow.
The more common ones like Noppoo Choc Mini and KBT Race 2 have some impossible cap sizes (5.5x spacebar, 1.5x ESC and Backspace).
Admittedly, for the FC660M you need a second left shift to fit onto the right hand side, but at least it's a standard size and is just a duplicate of a key already found in normal sets.
@Data, I'm surprised you don't know of the Noppoo Choc Mini, Keycool 84 or KBT Race 1 & 2.
I change keycaps quite often and am VERY used to the standard placement of arrow and edit keys (20+ years of daily use will do that), so for me, a TKL is much more usable than a 75%. Even so, the largest board I tend to use nowadays is a 60%.
Re: 75% Keyboards?
« Reply #11 on: Fri, 30 January 2015, 09:33:46 »
KBT Race keyboards are always out of stock.
Offline pr0ximity
Offline Data
Re: 75% Keyboards?
« Reply #13 on: Fri, 30 January 2015, 14:07:27 »
I've probably seen the Noppoo a time or two, but wasn't familiar enough with it to remember the name.  I've heard of the KBT Race but wouldn't be able to pick it out of a line-up.  :D
I love the arrow keys and use them constantly, which is probably my biggest hurdle to using a 60% (or smaller) layout.  But where they live on the board or even which side they're on hasn't been a problem so far.
Offline supersoul
Re: 75% Keyboards?
« Reply #14 on: Fri, 13 February 2015, 01:05:21 »
love my choc mini but the mentioned lack of compatible keysets really sucks
Offline Fragil1ty
  • Abre los ojos.
Re: 75% Keyboards?
« Reply #15 on: Fri, 13 February 2015, 01:40:05 »
Noppoo Choc Mini is the only 75% board you should ever buy.
/Thread
你搞砸了
Offline punkpc
Re: 75% Keyboards?
« Reply #16 on: Sat, 11 July 2015, 11:47:49 »
What case is that with the MX Mini?
« Last Edit: Sun, 12 July 2015, 01:14:10 by punkpc »
Offline EscapeVelocity
  • Antiquarian
Re: 75% Keyboards?
« Reply #17 on: Sat, 11 July 2015, 16:22:03 »
The KBT Race II was the closest to me finding a good key layout on 75%.
I use a 75% layout that is very similar on my Asus Netbook. So Im familiar with it. 60% just too small. I dont need to travel with it either. I like the Home/End Page Up/Page Down keys along the Right edge that is how my Asus netbook is set up...and I use them.
Ultimately I decided to ditch it and go with TKL.
You might look into the Leupold F660 as well.
PPS - The Noppoo Choc Mini looks like a real good layout too. Maybe even better than the Race II.
« Last Edit: Sat, 11 July 2015, 16:26:57 by EscapeVelocity »
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: 75% Keyboards?
« Reply #18 on: Sat, 11 July 2015, 16:32:07 »
/Thread
LOL, if you're a noob, yes.
Offline Leslieann
Re: 75% Keyboards?
« Reply #19 on: Sat, 11 July 2015, 18:12:38 »
There is no 75% with common keys,, there's no way to make it a perfect little rectangle without chopping out something somewhere and most keysets leave you with odd profiles at best.
It's the main reason I set out on my little adventure.
https://geekhack.org/index.php?topic=73282.0
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: 75% Keyboards?
« Reply #20 on: Sat, 11 July 2015, 18:49:24 »
Well, short right shift is somewhat common, but yeah, yours is a good  improvement as far as standard goes. Reminds me a little of the alienware keyboard layouts.
