Author Topic: What Model M is this?  (Read 2599 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Sat, 31 January 2015, 13:01:54 »
Hiya guys, got this Model M that some old professor discarded a couple of days ago, but it doesn't have a model sticker. Strangely, it has a part sticker behind the speaker grille that looks like a normal sticker, but it reads "1386715" which I can't find anything about on wikipedia or anywhere else.
It's a UK layout, grey label model with two-part keycaps and a detachable SDL cable. It doesn't appear to have the drainage channels. I'd open it up, but I don't have the proper nut driver for it.
Anyone have any idea what part it is? Pictures below.
Offline TheSven
Re: What Model M is this?
« Reply #1 on: Wed, 04 February 2015, 14:24:45 »
I have the same layout, but with a blue label. Mine is a 1391406, but the other number says 1386719 rather than 1386715. I'd assume it's just an older model of the one I've got. Nice find by the way:) !
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Wed, 04 February 2015, 15:34:36 »
Looks identical to mine, however mine doesn't have anything behind the grill on the back.
The model number on mine is 1391406
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Wed, 04 February 2015, 16:03:18 »
Hmmm, mine has the same specs as that otherwise, yeah. I'm not sure there's actually anything special behind the grill, since it appears to be just a sticker on the back plate. Still have no idea what that number represents though.
« Reply #4 on: Wed, 04 February 2015, 20:54:10 »
Could it be the part number for the barrel plate?
« Last Edit: Wed, 04 February 2015, 20:59:48 by Findecanor »
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5 on: Wed, 04 February 2015, 22:29:38 »
It's a nice keyboard.  I think you need a left Alt key. Does it work?  Did you check it?  I hope it works fine for you for years to come.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #6 on: Wed, 04 February 2015, 22:38:38 »
Offline Snowdog993
« Reply #7 on: Wed, 04 February 2015, 22:42:47 »
Orly?
Yeah one of those that have the fancy green lettering!  Woohoo!  Well, after looking again at that picture, maybe not, but I think it was swapped with the left Ctrl key.  So maybe he needs a left Ctrl key instead.  No fancy green lettering.  Awwww.
« Last Edit: Wed, 04 February 2015, 22:46:18 by Snowdog993 »
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Thu, 05 February 2015, 03:10:27 »
Yeah it might be the number for the barrel plate, I'm no sure. There's really no info for that part number available as far as I can tell.
Orly?
The key cap from the ctrl key was missing, but because I use that ctrl key quite a lot, I put that of the left Alt on it. I do actually have the buttom part of the key, even though that's not that picture. It's definitely a nice board, though you wouldn't believe how filthy it was when I got it xD . Works perfectly though, every key registers perfectly and works crisply and cleanly :) .
Offline azhdar
  • Praise the AZERTY god
« Reply #9 on: Thu, 05 February 2015, 04:01:55 »
Pm me if you need a Ctrl key for this board
Azerty Propagandiste
