Author Topic: Question about QFR top case.  (Read 1487 times)
Offline Mooksie
« on: Mon, 02 February 2015, 19:27:29 »
So, I ordered a QFR and I already know I don't like the rubber coating on the top case. I can buy a replacement gray one from CM for only $10. My question is, is the grey one also rubberized? I hope it isn't. Thanks in advance guys!
This is the one I can get, but it'll be debranded.
http://cdn.overclock.net/3/3f/3fa54fad_image_171.jpeg
we use up all the cupholders during our furious love making sessions
Re: Question about QFR top case.
« Reply #1 on: Mon, 02 February 2015, 19:28:28 »
dont think so, i had a grey one and it wasn't rubberized. not sure if they've changed anything since i had mine like a year ago
Offline Mooksie
« Reply #2 on: Mon, 02 February 2015, 19:30:45 »
Alright sweet, thanks!
« Reply #3 on: Mon, 02 February 2015, 20:38:05 »
That one looks exactly like my QFR - it is rubberised.
Offline MJ45
  • HHKB Pro
« Reply #4 on: Tue, 03 February 2015, 06:41:33 »
The gray I had was rubberized also. To refinish you have to sand it off or I have used EZ-off oven cleaner to remove it.
Offline tigersharkdude
« Reply #5 on: Tue, 03 February 2015, 07:43:09 »
Yes, both the black and grey top cases are rubberized. I've bought both and sanded them down to paint and it took a lot to get the coating off
Offline jabbon
« Reply #6 on: Tue, 03 February 2015, 08:39:08 »
I hate that shipping cost is too high to Europe...
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #7 on: Tue, 03 February 2015, 10:32:35 »
Yep, that's also rubberized. You can sand the top and just paint over it though
Offline Dihedral
  • Mostly Harmless
« Reply #8 on: Tue, 03 February 2015, 10:43:55 »
The rubberised finish is really nice. At least try it first.
