Author Topic: Alps GlidePoint Keypad  (Read 6112 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Sat, 14 February 2015, 20:12:30 »
http://www.ebay.co.uk/itm/Alps-Glidepoint-Keypad-/331471826621?pt=LH_DefaultDomain_0&hash=item4d2d42aebd
Anyone have any idea what kinds of switches these use? Might make a tester unit of some sort if it's SKCM / SKCL compatible :D .
Offline FrostyToast
  • Litshoard
Re: Alps GlidePoint Keypad
« Reply #1 on: Sat, 14 February 2015, 20:17:40 »
Maybe I'll dump my spare Blue ALPS in there.
Quote from: elton5354
Offline chyros
  • a.k.a. Thomas
« Reply #2 on: Sat, 14 February 2015, 20:21:56 »
SPARE blue Alps? Oh wow mate that sounds amazing :D .
Offline FrostyToast
  • Litshoard
« Reply #3 on: Sat, 14 February 2015, 20:22:46 »
There is a 75% board that I want to put these in.
That means I should have enough for a numpad at the least after I complete the board.
Offline chyros
  • a.k.a. Thomas
« Reply #4 on: Sun, 15 February 2015, 09:36:41 »
That is, IF this thing is compatible with this kind of switch xD .
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Mon, 16 February 2015, 10:32:37 »
Well I contacted a guy from Alps but he said the item doesn't appear in any logs for the last 10 years so he can't find any info on it. Anyone have any other idea of who it what might know?
Offline Dihedral
  • Mostly Harmless
« Reply #6 on: Mon, 16 February 2015, 10:33:49 »
Possible Knockoff?
« Reply #7 on: Mon, 16 February 2015, 10:39:06 »
https://geekhack.org/index.php?topic=61519.0
https://geekhack.org/index.php?topic=5079.0
https://geekhack.org/index.php?topic=7332.msg124285#msg124285
Looks like a tossup between White Alps or a rubber dampened Alps? I'd say that would be Cream Alps but for some reason that's not mentioned in the search. Wondering if it's something unique.
« Last Edit: Mon, 16 February 2015, 10:42:44 by CPTBadAss »
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Mon, 16 February 2015, 14:24:42 »
Indeed, there seem to be a few conflicting reports there. It does list that it has a lifetime of 10 million cycles which I think is what the SKCM \ SKCL series are rated for. Cheers mate!
Offline jacobolus
« Reply #9 on: Mon, 16 February 2015, 17:56:21 »
I think these keypads might be those low-profile Alps switches, http://deskthority.net/wiki/Alps_SKFR/SKFS
Offline chyros
  • a.k.a. Thomas
« Reply #10 on: Mon, 16 February 2015, 18:21:29 »
Maybe it's possible that the Mac and PC versions have different switches? Also, are these low-profile Alps switches exchangeable with SKCM/SKCL switches?
