Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1588936 times)
0 Members and 6 Guests are viewing this topic.
Offline frosty
  • jukebox hero
Re: [GB] TMK Alps64 - 60% PCB for Alps [Revised price]
« Reply #1200 on: Thu, 13 December 2018, 23:43:15 »
flip gave me "AtLibUsbDfu.dll not found". I've selected ATmega32u2 and put the board in bootloader mode. but it gives me that error.
troubleshoot section has solution for the exact problem.
https://github.com/tmk/tmk_keyboard/wiki#flash-firmware
got it, was reading the exact same page. thanks lots hasu.
Offline AllTheWayUp
« Reply #1201 on: Sun, 16 December 2018, 02:20:26 »
So I finally have my board assembled - and I want to repmap some of the keys.
I have the map downloaded from the online editor - but I can't get DFU to compile.  Which is probably just me being stupid.
iIs there a source for DFU or another firmware flash tool that will work on OSX?
I do have access to a Windows machine and i can probably use flip, but I don't want to defile my new keeb by connecting it to PC hardware.
Offline merlin64
    • MechMerlin
« Reply #1202 on: Mon, 17 December 2018, 10:04:03 »
what do you mean get DFU to compile? DFU should already be compiled and ready to go when you downloaded it.
I suspect your keymap is the one that's not compiling
Offline AllTheWayUp
« Reply #1203 on: Thu, 27 December 2018, 14:53:15 »
Ah - sorry - from reading the readme file at source-forge it seems that DFU needs to be compiled for LINIX/MAC OS.
"dfu-programmer-x.x.x.tar.gz contains the source tree for this project.
Download this to build and install on a Linux/Unix/Mac system."
Perhaps you can tell me which file is the executable from the screenshot below?
Offline merlin64
    • MechMerlin
« Reply #1204 on: Thu, 27 December 2018, 16:21:51 »
These instructions are taken from the QMK docs, but you can use homebrew to install all of them
if you're using homebrew, you can use the following commands:
brew tap osx-cross/avr
brew tap PX4/homebrew-px4
brew update
brew install avr-gcc@7
brew link --force avr-gcc@7
brew install dfu-programmer
brew install dfu-util
brew install gcc-arm-none-eabi
brew install avrdude
afterwards on you terminal you can use dfu-programmer to erase the current contents, and then flash the new hex file.
Offline hasu
  • @tmk
« Reply #1205 on: Thu, 27 December 2018, 17:52:43 »
You can download .zip file which includes Windows executable from here. And .tar.gz is source archive and it doesn't include any executable. If you are on Mac or Linux use your favorite package manager like brew, apt, pacman...
https://sourceforge.net/projects/dfu-programmer/files/dfu-programmer/0.7.2/
EDIT: Ah, the readme already explain this as you can see ...
dfu-programmer-win-x.x.x.zip contains the pre-compiled Windows executable
and the USB drivers for use with Atmel chips in DFU bootloader mode.
The Windows executable does not need any installation or setup. Just
extract the executable and run it.
The Windows driver can be installed when prompted by Windows when a DFU
device is attached. Do not let Windows search for a driver; specify
the path to search for a driver and point it to the .inf file.
« Last Edit: Thu, 27 December 2018, 18:02:34 by hasu »
Offline abrahamstechnology
« Reply #1206 on: Sat, 29 December 2018, 19:55:32 »
Do you know if Matias keycap sets work with the AEK plate?
Offline hasu
  • @tmk
« Reply #1207 on: Sun, 30 December 2018, 07:27:16 »
Probably No. You need unusual 6.5u space bar for AEK layout. Matias doesn't seem to have the space bar.
« Reply #1208 on: Sun, 30 December 2018, 11:21:00 »
Do you have any plans in the future to sell a plate that supports Tai-Hao spacebars (Cherry mounts for the stabilizers, 6.25u)?
Offline hasu
  • @tmk
« Reply #1209 on: Sun, 30 December 2018, 13:05:09 »
I have no plan to do so.
Tapatalk を使用して私の WAS-LX2J から送信
« Reply #1210 on: Sun, 30 December 2018, 15:30:14 »
Do you know a company that will make the plate out of the same material from a .svg file? Thanks.
Offline hasu
  • @tmk
« Reply #1211 on: Sun, 30 December 2018, 18:11:06 »
You mean FR-4 material? You need to design gerber files and send to pcb factory.
EDIT: For steel and other metal meterials see 'Plate' section of the first post.
« Last Edit: Sun, 30 December 2018, 18:20:10 by hasu »
Offline jtPox
« Reply #1212 on: Tue, 01 January 2019, 21:25:48 »
May I know if this is still being sold as I am very interested!
Offline hasu
  • @tmk
« Reply #1213 on: Wed, 02 January 2019, 12:58:02 »
Yes the pcb and plate are still available :-)
Offline jtPox
« Reply #1214 on: Wed, 02 January 2019, 13:01:07 »
Awesome! Email sent!
Offline hasu
  • @tmk
Re: [GB] TMK Alps64 - 60% PCB for Alps [OUT OF STOCK]
« Reply #1215 on: Mon, 28 January 2019, 20:58:16 »
Alps64 pcb is currently out of stock.
It will take several weeks before pcb become available again due to Chinese New Year. I'll update first post when it is restocked.
Thank you
Offline KorbenDallas
« Reply #1216 on: Mon, 11 February 2019, 23:35:33 »
Could I add a LED strip on the bottom with those 5v and GND open holes around the space bar location?
Offline hasu
  • @tmk
« Reply #1217 on: Tue, 12 February 2019, 01:42:09 »
I think so but what is your concern actually?
« Reply #1218 on: Tue, 12 February 2019, 04:45:57 »
Just wanted to know if it’s possible. I’ve yet to add my own LED strip to a pcb and wanted to know whether it was possible with this one. Figured all you would need is a ground and 5v supply but again I’ve never done it so I wasn’t certain. Will probably try it with a short single color strip.
Offline aroostercat
« Reply #1219 on: Mon, 25 February 2019, 12:21:58 »
Would an older pcb be compatible with the newest plate file?
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #1220 on: Mon, 25 February 2019, 15:17:05 »
Yes. PCB supports AEK layout, and so does the plate. All he changed with the plate is more configurations for the spacebar. So as long as you're using an ANSI AEK layout, youre good to go.
Offline aroostercat
« Reply #1221 on: Mon, 25 February 2019, 15:45:12 »
Thank you!
Offline oxchamballs
« Reply #1222 on: Tue, 26 February 2019, 00:35:59 »
I followed a guide on reddit and managed to get rgb underglow with qmk working on my Alps64
I have an older rev of the pcb so I had to solder directly to the mcu, but it should be easier since the new revs have breakout pins (I think).
Offline nevin
« Reply #1223 on: Tue, 26 February 2019, 03:51:29 »
oxchamballs, nice. what case do you have planned for it?
Offline oxchamballs
« Reply #1224 on: Tue, 26 February 2019, 08:25:26 »
it was the first custom pcb I owned; sadly due to my inferior soldering skills back then I've lifted so many pads on the board it's basically half handwire at this point ^-^ It's been retired to my cupboard for now but here it is in it's final state:
http://imgur.com/gallery/38fOrOw
Offline nevin
« Reply #1225 on: Tue, 26 February 2019, 08:29:02 »
very nice.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #1226 on: Tue, 26 February 2019, 09:43:36 »
Links to this guide? I'm doing this with mine.
Offline oxchamballs
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #1228 on: Tue, 26 February 2019, 12:40:44 »
Offline merlin64
    • MechMerlin
« Reply #1229 on: Tue, 26 February 2019, 13:13:30 »
QMK is a fork off of TMK, so the process of installing is rather similar
1. Make your keymap, but use QMK
2. Flash .hex file.
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #1230 on: Tue, 26 February 2019, 14:48:09 »
Oh. I am the dumb. Thanks
Offline mxgian99
« Reply #1231 on: Tue, 26 February 2019, 15:31:39 »
i think i am dumb too.  when a board is in the TMK repo but not the QMK repo, what do you need to do to bring it to the QMK side?
what exactly does merlin mean when he says 1. Make your keymap, but use QMK
copy the alps64 directory to the qmk keyboards directory and build it from there?
Offline ShadeDream
« Reply #1232 on: Tue, 26 February 2019, 19:30:27 »
The Alps64 is in the QMK repo as well, so you don't need to port anything. If you'd like to use anything but the default keymap, you need to make a keymap (in TMK or QMK) and compile a new firmware file (hex) and flash it to the board. The instructions for doing this should be available in either of the project's repositories on github.
« Last Edit: Wed, 27 February 2019, 07:25:45 by ShadeDream »
Offline mxgian99
« Reply #1233 on: Tue, 26 February 2019, 22:28:13 »
ok, yeah im really dumb then, i thought i looked in QMK repo but i overlooked it nevermind!
Offline merlin64
    • MechMerlin
« Reply #1234 on: Wed, 27 February 2019, 10:19:06 »
@mxgian @ @redsnotdead
You guys can use the online tool if you'd rather not deal with setting up an environment and all that
We support all the layouts that TMK provides as well: https://config.qmk.fm/#/alps64/LAYOUT_60_ansi
Offline hasu
  • @tmk
Re: [GB] TMK Alps64 - 60% PCB for Alps [RESTOCK Mar-01]
« Reply #1235 on: Thu, 28 February 2019, 20:00:55 »
[RESTOCK]
The pcb is back in stock now and backorders will be shipped in a few day.
Thank you
Offline vafan
« Reply #1236 on: Thu, 28 February 2019, 20:23:43 »
You can cut it yourself
Offline Wojciech
« Reply #1237 on: Sun, 03 March 2019, 10:41:31 »
Hi Hasu. Thank you for the PCB - everything works beautifully. I am still waiting for the case and I will upload photos. I tried to make a version with external bluetooth - unfortunately the battery life is very short - about 12 hours with 2600 mAh. So I have a question about whether you plan to make a PCB with bluetooth onboard? Greetings
Offline nevin
« Reply #1238 on: Sun, 03 March 2019, 11:35:55 »
What BT module are you using? What is it's current draw? Are you using lots of leds? Please post your build/setup.
Hasu, do you know what the current draw of your pcb is (in minimal configuration)?
Offline Wojciech
« Reply #1239 on: Sun, 03 March 2019, 15:16:25 »
Hi. I'm using Handheld Handheld Scientific BT-500 Bluetooth Adapter, no leds - only Adapter got two LED's. According to producent the adapter consumes about 50mA of current when Bluetooth is enabled.
Offline nevin
« Reply #1240 on: Sun, 03 March 2019, 16:16:06 »
Wojciech, yeah, that definitely doesn't add up. even looking at another thread where soarer references some current draw of a couple keyboard models... https://geekhack.org/index.php?topic=44092.msg909328#msg909328
possible that the battery/bank you are using isn't really 2600mah or is old & not holding a charge very well anymore?
a much more in depth build of a custom BT keyboard (bunch of info/measurements throughout thread) https://geekhack.org/index.php?topic=93890
Offline Wojciech
« Reply #1241 on: Sun, 03 March 2019, 16:41:09 »
Thanks - but it's to complicated to me - I'm not an electronics technician - just musician :) I held the soldering iron in my hand for the first time :) I am looking for a ready-made project. If you've heard about some ready bluetooth PCB for ALPS, please let me know.
All the best
Wojtek
Offline nevin
« Reply #1242 on: Sun, 03 March 2019, 16:56:37 »
no, wasn't suggesting that as a build, just as a reference of some of his measurements.... was starting at 12-13ma, and getting it down to under 2ma.
Offline hasu
  • @tmk
« Reply #1243 on: Tue, 05 March 2019, 10:48:56 »
No plan for bleutooth.
Alps64 pcb draws 15mA at 5V with current firmware configuration.
Offline nevin
« Reply #1244 on: Tue, 05 March 2019, 10:52:15 »
"Alps64 pcb draws 15mA at 5V with current firmware configuration."
thanks hasu
Offline filabrazilia
« Reply #1245 on: Sat, 09 March 2019, 02:24:39 »
Does anyone have experience connecting a piezo speaker to an Alps64? I have one wired to C6 and a 100 Ohm resistor between the piezo and GND. I was able to get a two tone startup sound when using the QMK AUDIO_ENABLE = yes feature turned on. It should be a three tone sound though but the board continually either reboots or crashes (it is non-responsive) so the two tones continually repeat until the switch on the bottom is pressed to put it DFU mode. The light on the bottom of the board that lights up for half a second on start is also continually flashing so it is clear it keeps rebooting constantly and never gets to a point where it is usable as a keyboard. Maybe too much memory is being used by the audio feature?
I can get some very small chirps on startup without crashing if I put something like this in my alps.c (and set AUDIO_ENABLE = no) :
Code: [Select]
void matrix_init_kb(void) {
    setPinOutput(C6);
    writePinHigh(C6);
    _delay_ms(250);
    writePinLow(C6);
    _delay_ms(250);
    writePinHigh(C6);
    _delay_ms(250);
Those aren't proper sounds though like the two tones using the QMK audio feature. That is using a timer to generate real sounds, this is just some very quiet muffled clicks. It seems like I am close but don't know enough about microcontroller programming to get over this last hump. Thanks for any input.
« Last Edit: Sat, 09 March 2019, 02:33:00 by filabrazilia »
« Reply #1246 on: Sat, 09 March 2019, 08:33:13 »
I was able to make my own audio without using QMK's audio features, if it helps anyone here is some sample code that works, it would be nice if QMK audio could work though if anyone has thoughts on that issue:
Code: [Select]
#include <avr/io.h>
#include <util/delay.h>
#define SPEAKER_PORT PORTC
#define SPEAKER_DDR  DDRC
#define SPEAKER_PIN  6
void delay_10_us(uint16_t count) {
  while(count--) {
    _delay_us(10);
void PLAYNOTE(float duration, float frequency)
long int i,cycles;
float half_period;
float wavelength;
wavelength=(1/frequency)*1000;
cycles=duration/wavelength;
half_period = (wavelength/2)*34;
SPEAKER_DDR |= (1 << SPEAKER_PIN);
for (i=0;i<cycles;i++)
delay_10_us(half_period);
SPEAKER_PORT |= (1 << SPEAKER_PIN);
SPEAKER_PORT &= ~(1 << SPEAKER_PIN);
return;
PLAYNOTE(400,880);
PLAYNOTE(400,932);
PLAYNOTE(400,988);
PLAYNOTE(400,1047);
PLAYNOTE(400,1109);
« Reply #1247 on: Sat, 09 March 2019, 22:31:52 »
I guess this classifies as more of a QMK bug now, I've opened a bug there which is open and acknowledged as an issue with all ATMega32u2 boards.
Offline temp0321
« Reply #1248 on: Wed, 27 March 2019, 02:42:03 »
Will the stabilizer set from matias.store fit all stabs for this pcb?
Also, do you happen to know what keycaps(especially the bot row) will fit?
I was thinking of getting this:  https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1362
Offline hasu
  • @tmk
« Reply #1249 on: Wed, 27 March 2019, 04:22:37 »
Whether stabilizer fits or not depends on your plate design, not PCB.
This Alps64 PCB supports layout of the keycaps. So, you need a plate that supports Matias stabiliers and the layout.
