Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1561118 times)
Offline stand.geek
Re: [GB] TMK Alps64 - 60% PCB for Alps [10th GB 2017/Aug]
« Reply #1000 on: Wed, 13 September 2017, 04:35:49 »
Beetwaaf,
Leftover sale will start soon after GB is fulfilled, in a few weeks probably.
stand.geek,
Keymap Editor doesn't support defining macros at thiis time at least.
If you build firmware from source code with macro definitions you can edit keymap including the macros in Keymap Editor theoretically. But you won't need Keymap Editor in fact when you can write and compile source code :D
Alps64 default firmware doesn't include any macro definitions you can't use macro(ACTION_MACRO) in keymap.
Ah too bad  :(
So I think this is the right time to start learning about firmware  ;D
Any simple tutorial / documentation as a starting point?
You can refer to this keymap doc and  my keymap as an example. No further documentation for MACRO you may have to look into tmk_core source code.
https://github.com/tmk/tmk_keyboard/blob/master/tmk_core/doc/keymap.md
https://github.com/tmk/tmk_keyboard/blob/master/keyboard/hhkb/keymap_hasu.c#L219-L239
https://github.com/tmk/tmk_keyboard/blob/master/tmk_core/common/action_macro.h
Alright thanks! will look into it right now  :)
Offline kmba
  • Formerly tameone
« Reply #1001 on: Fri, 15 September 2017, 08:35:15 »
I bought the FR-4 plate to try out with my blue alps build, but I've never typed on a board with a plate like this.  What's it going to feel like?  very flexible?
keyboards.
Offline hasu
  • @tmk
« Reply #1002 on: Fri, 15 September 2017, 20:35:38 »
I'm also curious about what people say on FR-4 plate comparing to steel. Try it yourself and share your thought!
I have one with FR-4+blue switches and other with cutout AEK plate+orange and both have plastic Poker X case. I could not find difference in terms of firmness on those two. On Poker style case design plate is completely floating and not fixed on any of PCB and case, unlike some of custom design keyboards. I think, in this case plate plays role primary to align switches laterally and it has enough horizontal hardness for that while it has virtually no or the least effect on reinfocing vertically. Case material and structure may have more effect on overall firmness and feel, I don't have any heavy metal case to compare though.
Offline kmba
  • Formerly tameone
« Reply #1003 on: Wed, 20 September 2017, 07:07:51 »
Got my shipping notification. Thanks
keyboards.
Offline pabile
    • pabile online
« Reply #1004 on: Wed, 20 September 2017, 07:47:06 »
no noticeable flex difference here also. fr-4+blues in plastic case VS SS+salmon in alum pok3r case.
Offline hasu
  • @tmk
« Reply #1005 on: Thu, 21 September 2017, 11:24:19 »
[GB Update]
All paid orders were shipped until yesterday. You will receive tracking number from Japan Post in a few days.
Thank you
Offline pixelpusher
Re: [GB] TMK Alps64 - 60% PCB for Alps [Leftover]
« Reply #1006 on: Thu, 21 September 2017, 12:26:12 »
Sorry if this has been covered before, lots of pages to look through.  I've dealt with SP alps caps now and I understand the stabilizer situation.  I would like to avoid making my own wires again like I did the last time.
Has anyone found an off-the-shelf plate with either plate-mounted cherry or costar stabilizers that works with this PCB?
Offline hasu
  • @tmk
« Reply #1007 on: Fri, 22 September 2017, 18:40:50 »
[Leftover Sale]
Currently leftover pcbs from UK GB(2017/04) are available. It is identical electrically and has no confirmed flaw.
Differences from the latest 10th GB(2017/08) PCB are only two:
1) It has Alps logo instead of TMK logo.
2) It has no breakout pads for unused pins(C4, C6, C7).
This is pcb from UK GB.
This is the latest revision of pcb for reference.
Check the first post. Thanks
Offline pabile
    • pabile online
« Reply #1008 on: Sat, 23 September 2017, 03:39:07 »
wow! those black PCBs looks awesome. i wish i have a budget for a 3rd build....
Offline skidude9678
« Reply #1009 on: Sat, 23 September 2017, 21:03:11 »
Just soldered the diodes and loaded firmware, works great! Fits absolutely perfect in my Pok3r case. Now just crossing my fingers that the plate I ordered from Lasergist works as I hope it does.
« Last Edit: Sat, 23 September 2017, 21:07:51 by skidude9678 »
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
« Reply #1010 on: Sat, 23 September 2017, 21:08:45 »
« Last Edit: Mon, 15 April 2024, 18:44:33 by FearsomeCubedWarrior »
« Reply #1011 on: Mon, 25 September 2017, 03:54:00 »
« Last Edit: Mon, 15 April 2024, 18:44:38 by FearsomeCubedWarrior »
Offline hasu
  • @tmk
« Reply #1012 on: Mon, 25 September 2017, 22:48:52 »
did you check "troubleshooting" section on wiki and try to reinstall driver?
https://github.com/tmk/tmk_keyboard/wiki#flash-firmware
Offline Thebonuslevel
« Reply #1013 on: Tue, 26 September 2017, 00:37:00 »
Any US leftovers available, from the 10th GB? It said they would be avail 9/24.
« Last Edit: Tue, 26 September 2017, 00:45:12 by Thebonuslevel »
Offline hasu
  • @tmk
« Reply #1014 on: Tue, 26 September 2017, 06:20:20 »
Leftovers from 10th GB will be avaiable soon in a few weeks probably, if you don't mind making payment early and wating for the weeks email me I'm happy to send invoice.
« Reply #1015 on: Wed, 27 September 2017, 01:30:10 »
« Last Edit: Mon, 15 April 2024, 18:44:47 by FearsomeCubedWarrior »
Offline hasu
  • @tmk
« Reply #1016 on: Wed, 27 September 2017, 04:01:44 »
Thanks, Hasu.
Actually, it wasn't a driver issue, but incorrect instructions in the forum message:
Make the layout you want and export the hex file with the button at the bottom.  Open up the copy of FLiP you downloaded and plug in your keyboard.  Press the chip button on the left, and select your chip.  This PCB uses the ATmega32u2.  Then click the next button to the right and connect via USB, opening the connection.  While doing this, press the button on the back of your PCB.  It may take a few tries to connect correctly.  When you get it, load your hex file and Start Application.
The part Run operations is ommited here, but in your link it is there and I was able to flash the board.
The flash was successful and I'm typing this on my new board with SKCM whites and DSA LC.
Thanks for feedback!
Updated first post and it refers wiki page on github in 'Program Controller' section now.
« Last Edit: Wed, 27 September 2017, 04:03:26 by hasu »
Offline mseaworthy
« Reply #1017 on: Wed, 27 September 2017, 10:27:58 »
@Hasu
Do you think this new case from KBDFans will work with your current plate and PCB?
https://kbdfans.myshopify.com/products/pre-orderkbdfans-5-60-case
Offline hasu
  • @tmk
« Reply #1018 on: Wed, 27 September 2017, 11:55:38 »
@Hasu
it seems to me it is poker compatible, I think so.
Offline mseaworthy
« Reply #1019 on: Wed, 27 September 2017, 12:26:24 »
@Hasu
Thanks. Going to give it a try. Let you know how it fits.
Offline kmba
  • Formerly tameone
« Reply #1020 on: Wed, 27 September 2017, 16:29:41 »
@Hasu
should fit
keyboards.
« Reply #1021 on: Wed, 27 September 2017, 16:52:13 »
« Last Edit: Mon, 15 April 2024, 18:44:54 by FearsomeCubedWarrior »
Offline hasu
  • @tmk
« Reply #1022 on: Thu, 28 September 2017, 07:15:35 »
[Leftover Sale]
You can order pcbs from leftovers of 10th GB now. Those PCBs need to be assembled and checked this weekend and It will take probably a week or two until shipping.
Please check first post.
Thank you
Offline kmba
  • Formerly tameone
« Reply #1023 on: Thu, 28 September 2017, 17:47:10 »
Mine arrived two days ago but just got to it today.  The fr-4 plate is pretty nice, definitely going to use it.  Now begins the slow process of disassembling and cleaning blue alps :o
keyboards.
Offline skidude9678
« Reply #1024 on: Sat, 30 September 2017, 18:57:33 »
Received my plate from Lasergist today, fit perfectly. Soldered some SKCM Orange switches on and topped it with DSA Light Cycle. Works fantastic! This PCB has been an excellent base, I will probably buy another in the near future. Now just to wait on a cyan case from KBDfans.
« Last Edit: Sat, 30 September 2017, 19:36:49 by skidude9678 »
Offline smithyithy
  • a l p s
« Reply #1025 on: Sat, 30 September 2017, 19:30:04 »
Gotta start building my boards soon...
I've got SKCM Cream Damped here, and some SKCM Brown and Orange on the way  :p
« Last Edit: Sat, 30 September 2017, 19:44:19 by smithyithy »
KBD75; Alps64 trio; some other stuff
Offline skidude9678
« Reply #1026 on: Sat, 30 September 2017, 19:38:29 »
You going to build 3 of them? Would love to try some cream damped to see how they compare to the orange. Only other tactile alps I've tried is salmon.
Offline smithyithy
  • a l p s
« Reply #1027 on: Sat, 30 September 2017, 19:48:30 »
Yeah, I got some of the UK edition PCBs brought over so figured I'd order a few and make the most of it, plus there's a few switch and cap combinations I want to build up so it'll be a nice little collection I guess.
I tried some lubed and spring-swapped Oranges at the MKUK meetup recently and they were fantastic, so I've got some being built up for me. The Cream Damped I got quite cheap, they're quite rough though, and I imagine the Browns I have coming will be too as they've just been desoldered from an old IBM. I think I'll need to try ans get them ultrasonic cleaned, hopefully that'll restore them
Offline smithyithy
  • a l p s
« Reply #1028 on: Tue, 10 October 2017, 04:28:04 »
Has anyone built a 'proper' HHKB layout with an Alps64 and if so, what keycaps are you using? I have a KBDFans Tina on the way which has the HHKB layout allowing the 6u space, but I'm unsure what keycaps (new or old) would be compatible with this..
Offline RealLaugh
« Reply #1029 on: Tue, 10 October 2017, 04:51:25 »
What stabalizers did you use?
Offline skidude9678
« Reply #1030 on: Tue, 10 October 2017, 05:13:52 »
Costar style from a KBP V80. The biggest thing needed for me to get them to fit was a completely straight wire without the bend in the middle, which is why I took them from my V80 as the ones I bought online had the bend, which impacted the switch housing.
Offline cheddarbek
« Reply #1031 on: Tue, 10 October 2017, 07:33:10 »
Yes, I built mine in HHKB layout. I used Alpine Winter keycaps.
https://geekhack.org/index.php?topic=75515.0
The Alps cover 65% of Switzerland's surface area (41,285 kmē), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 kmē),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline smithyithy
  • a l p s
« Reply #1032 on: Tue, 10 October 2017, 07:48:52 »
Cheers, I have Alpine Winter, but currently using it in a traditional 'Pok3r' 50% layout. I think that's the only 6u space I've been able to find though..
Offline nurbs
« Reply #1033 on: Sun, 15 October 2017, 06:45:36 »
These still available? Sent you an email!
Offline 6FeaT
« Reply #1034 on: Sun, 15 October 2017, 07:34:00 »
I'm pretty sure they were out of stock as of yesterday.
Offline Kafka
  • i like clean things
« Reply #1035 on: Sun, 15 October 2017, 14:08:20 »
Where to get an alps 60 pcb now :thinking:
« Reply #1036 on: Sun, 15 October 2017, 14:11:05 »
Wait for him to run them again, or /r/mm. I don't believe there are other options.
Offline zacheadams
« Reply #1037 on: Sun, 15 October 2017, 14:43:59 »
He can wait for these to come back after revisions too:
https://clueboard.co/parts/clueboard-60-pcb
Offline nurbs
« Reply #1038 on: Sun, 15 October 2017, 16:42:04 »
Just got a reply from Jun.  Said it will run again within the month.
Offline hasu
  • @tmk
Re: [GB] TMK Alps64 - 60% PCB for Alps [PreOrder]
« Reply #1039 on: Sun, 15 October 2017, 19:05:50 »
[PreOrder]
Leftover pcbs from last round have all gone and out of stock now.
Next batch of the pcb will be available within a month. Anyway I will order componetns enough to assembly some tens of pcb soon.
If you don't mind paying earlier and waiting for several weeks you can place order now. Check first post please.
Thank you
Offline neralo
« Reply #1040 on: Mon, 16 October 2017, 20:55:21 »
I accidentally bought an AEK64, so I'm gonna be waiting patiently for the next round of alps64 now. Smh I knew i should have bought one earlier.
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
Offline Marvellion
« Reply #1041 on: Mon, 23 October 2017, 13:04:44 »
Hey Hasu, if this is the wrong place to ask this, sorry. Any chance for the split space support before this year ends?
Offline hasu
  • @tmk
« Reply #1042 on: Mon, 23 October 2017, 22:59:17 »
No plan at this time.
But like to hear about preferable layout of bottom row and source of keycaps from you guys for future refrence.
Offline Marvellion
« Reply #1043 on: Tue, 24 October 2017, 00:34:37 »
Splitting the spacebar as 2.75/1.25/2.25 or the reverse would be nice for the basic split spacebar layout. But  I don't know if finding Alps keycaps would be easy for this layout ( I'm going for either SP keycaps or MX converters).
Offline neralo
« Reply #1044 on: Tue, 24 October 2017, 00:46:29 »
wonder if its possible to do something with the M0116 layout.
https://deskthority.net/wiki/Apple_Standard_Keyboard
Its so wonderfully weird.
Offline mwhy
« Reply #1045 on: Wed, 25 October 2017, 14:55:02 »
Hi I'm quite new to this so please don't crucify me if it is a dumb question. So my question is if this pcb supports the "infinity" layout with a split right shift and 4 keys right from the spacebar, because it is not listed with the supported layouts but looking at the pcb it looks to me like it would work and also there is a xdf file with a plate for that layout.
Offline amatecha
    • Matecha.net
« Reply #1046 on: Wed, 25 October 2017, 16:53:02 »
[PreOrder]
Thank you
Emailed you hasu :)   Thanks.  Just picked up an old Apple Extended Keyboard II so I can build with this PCB + plate!  :)
Offline hasu
  • @tmk
« Reply #1047 on: Wed, 25 October 2017, 20:21:27 »
Yes, it supports Infinity layout.
You can put together from any of Bottom row, Top right(backspace), Left shift, Right shift and Enter configurations listed in 'Supported Layouts',  press 'MORE' to see detail. Images in the section are just examples, that do not display all combinations of the configurations.
you need "Infinity"(1.5+1+1.5 spc 1.5+1+1+1.5) configuration for "Bottom row",  "HHKB like Split Backspace"(1+1) for "Top right" and "HHKB like Shift + Fn"(1.75+1) for "Right shift".
Offline heavyheaded
« Reply #1048 on: Sun, 29 October 2017, 20:43:19 »
Any chance of getting classic ALPS logo on next round for US?
Offline hasu
  • @tmk
« Reply #1049 on: Mon, 30 October 2017, 22:44:19 »
Probably no.
