Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1554392 times)
Offline deductivemonkee
  • Professional Lurker
Re: [GB] TMK Alps64 - 60% PCB for Alps
« Reply #750 on: Fri, 07 October 2016, 23:38:53 »
Nice.
Thanks, Deductivemonkee.
No problem. I got my alps64 to wake my PC on my x58 system. Using actionmap fixed it somehow.
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline Applet
« Reply #751 on: Sun, 09 October 2016, 04:40:06 »
Is round 7 still going? If not I'm in for rount 8 ;D
Offline Jumie
« Reply #752 on: Sun, 09 October 2016, 06:18:53 »
I think so, just email hasu
Offline hasu
  • @tmk
« Reply #753 on: Tue, 11 October 2016, 02:22:59 »
PCBs(from batch.1) paid as of now(Tue Oct 11 07:12:51 UTC 2016) were shipped today. Participants will  get tracking number from Japan Post in 48 hours, if not email me.
Thanks.
Offline Jumie
« Reply #754 on: Tue, 11 October 2016, 09:39:22 »
got my tracking number.. thanks hasu
Offline jorgenslee
« Reply #755 on: Fri, 14 October 2016, 05:30:24 »
Hi Hasu,
Just curious if it is possible to cut/remove the 2 1.5u in bottom to achieve HHKB layout?  I have a case but it requires custom pcb  with that area cutoff.
Offline hasu
  • @tmk
« Reply #756 on: Fri, 14 October 2016, 05:35:52 »
No, you can't. Row 2 and 3 will be killed probably.
You have to patch them at least.
Sent from my Nexus 5X
Offline XMIT
  • formerly jsoltren
« Reply #757 on: Sun, 16 October 2016, 22:30:17 »
Thanks hasu! I finally completed my build, looks and works great! I chopped an AEK II for this one and used its caps and key switches.
150592-0
Offline Reckless5040
« Reply #758 on: Tue, 18 October 2016, 09:01:45 »
Im interested in one for sure. If any batch 2 are still available.
Offline Jumie
« Reply #759 on: Tue, 18 October 2016, 09:19:44 »
what plate did u use? looks great..
Offline Applet
« Reply #760 on: Tue, 18 October 2016, 11:52:52 »
Got my PCB today, looks good, thanks! :) It's going to replace my butchered rev A PCB soon
Offline duynguyenle
  • Personal text? What personal text???
« Reply #761 on: Tue, 18 October 2016, 12:08:05 »
What case is that?
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #762 on: Tue, 18 October 2016, 13:44:29 »
What case is that?
Looks to be this case from AliExpress. I have one and it looks nice with the blue PCB of the older revisions.
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline hasu
  • @tmk
« Reply #763 on: Tue, 18 October 2016, 15:33:25 »
Hi all,
All PCBs from batch.1 were shipped, if you made payment till Oct 12 you should have already tracking number. If not let me know.
PCBs from batch.2 are still available and you can order it.
Offline Hypersphere
« Reply #764 on: Tue, 18 October 2016, 15:50:30 »
@Hasu: Batch 2 is for the PCB only? Do you also supply plates? If you do not supply plates, do you have suggestions for suppliers or suggestions of where to download templates to have plates made? Thank you!
Offline Hybrid
« Reply #765 on: Tue, 18 October 2016, 16:21:28 »
PCB and Diodes only. Use the Open Source Alps 60% plate. (https://geekhack.org/index.php?topic=82916.0)
Seems you can have the plate made for about $55-60, or use the AEKII plate and just cut it down to size.
Offline Scarpia
« Reply #766 on: Tue, 18 October 2016, 16:30:39 »
My plate arrived from Lasergist today, so I finally got to build my Alps64 today. Thanks to hasu for an impeccable product!  :thumb: :thumb: :thumb:
Gallery / build log: http://imgur.com/a/6QdOG
Offline hasu
  • @tmk
« Reply #767 on: Tue, 18 October 2016, 16:33:18 »
Hi Hypersphere,
PCB only.
My AEK FR4(PCB) plates were not so popular and I decided not to resotck them. I'll have canceled plate from last group buy, perhaps.
As people say,
To get stainless steel plate you can use lasergist.com with plate design file published here. You will have to contact them to get 1.2mm thick material option.
(I'll update first post to add this info.)
Offline Scarpia
« Reply #768 on: Tue, 18 October 2016, 16:33:38 »
I had mine cut by Lasergist.com using the AEK file from that thread (and asking for 1.2mm instead of 1.5mm as the thread suggests). I paid $49.50 shipped for it, and you can see the result here
Offline axtran
« Reply #769 on: Wed, 19 October 2016, 00:02:20 »
Do you have pictures of green PCBs made in the latest run? Any changes?
MX Silent > MX Vintage Black > Everything Else
Offline hasu
  • @tmk
« Reply #770 on: Wed, 19 October 2016, 02:39:52 »
First post has pic of the green PCB.
Footprint of USB connector was changed a bit and silk prints were fixed from the last revision. Not changed virtually.
Offline gogusrl
« Reply #771 on: Wed, 19 October 2016, 06:29:03 »
My pcb got here and it came by DHL. Now those pieces of #@#$ want almost another 50$ in taxes and customs charges. Pissed does not describe how I'm feeling at the moment.
I'm having trouble understanding how the hell my package ended up in DHL's hands when Hasu sent it by Japan Mail.
Sorry for venting here but I didn't know where else to go.
Offline axtran
« Reply #772 on: Wed, 19 October 2016, 07:39:47 »
Is it how your country handles mail routing? Couldn't tell you. Any way to petition?
Offline tjweir
« Reply #773 on: Wed, 19 October 2016, 09:21:52 »
Do I *need* a plate, or is it recommended?
I ask out of ignorance.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #774 on: Wed, 19 October 2016, 09:23:49 »
You need a plate
Offline tjweir
« Reply #775 on: Wed, 19 October 2016, 09:47:39 »
You need a plate
Thanks, time to get cutting then.
Cheers.
Offline phoible
« Reply #776 on: Fri, 21 October 2016, 21:53:52 »
Is there a good reason to go with 1.2mm rather than 1.0mm? I built my first AEK64 with a 1.0mm plate, and it seems to have turned out fine (it has become my default keyboard at work). Building another one once Batch 2, ships, and need to order a plate.
Offline Quakemz
« Reply #777 on: Sun, 23 October 2016, 04:19:45 »
Paid my invoice for two. Thanks, Hasu! Can't wait to put all these SKCM Browns to use.  :thumb:
Offline Jumie
« Reply #778 on: Sun, 23 October 2016, 06:11:32 »
wanna sell some to me?
Offline graefeln
« Reply #779 on: Sun, 23 October 2016, 07:35:36 »
Not sure what I am going to do with it, but it's about time I tried Alps... though I probably won't put anything together until after Christmas. Still, that gives me plenty of time to decide on (and hopefully find) switches, caps, a case and plate.
Offline hasu
  • @tmk
« Reply #780 on: Sun, 23 October 2016, 19:32:32 »
I think there are no actual difference but hey... apparently some people prefer thick and heavy around here :D
One datasheet says "THE MOUNTING PANEL TO BE 1.0mm TO 1.2mm IN THICKNESS" and another just specifies "t1.2",  btw.
https://deskthority.net/w/images/6/68/Forward_Electronics_--_spec_--_SKBMFA.pdf
https://deskthority.net/w/images/3/32/Alps_Electric_--_spec_--_5454_31.pdf
« Reply #781 on: Sun, 23 October 2016, 20:39:15 »
The plate keeps the switches alighted, but ultimately, 60% keyboards are mounted to the case only by the PCB and standoffs. The only substantial difference I can really think of would be the sound.
Offline Jumie
« Reply #782 on: Tue, 25 October 2016, 04:17:56 »
Flashing the hex file using flip, I always got prompt "cannot write to usb". Do I need to use zadig first?
Offline hasu
  • @tmk
« Reply #783 on: Tue, 25 October 2016, 04:30:27 »
Reinstalling driver doesn't help?
http://imgur.com/a/bnwzy
I for one never used zadig yet but I think it works.
Offline Jumie
« Reply #784 on: Tue, 25 October 2016, 05:11:15 »
Couldn't find atm32u2 under 'other device' in Device Manager.
Offline hasu
  • @tmk
« Reply #785 on: Tue, 25 October 2016, 07:09:19 »
You will find under 'Libusb-Win32 Devices' if driver is installed and working somehow.
Did you try Zadig? I hope it works for you.
Offline Jumie
« Reply #786 on: Tue, 25 October 2016, 08:35:03 »
Tried Zadig, now the original firmware has gone. atmel device appear on device manager but still cannot write to usb in Flip.
Edit: replug the pcb and it works like a charm.. I don't know how it happen tho.  :D
« Last Edit: Tue, 25 October 2016, 08:40:04 by Jumie »
Offline hasu
  • @tmk
« Reply #787 on: Tue, 25 October 2016, 08:42:51 »
No error message? Posting screenshots of device manager and FLIP would be helpful.
And check flash procedure again with 'Program Controller' section in first post.
Offline hasu
  • @tmk
« Reply #788 on: Wed, 26 October 2016, 16:37:09 »
Batch.2 status update:
I missed Fedex delivery of PCBs from China yesterday but I'll have them today then start assembly this week end. Shipping will happen on next week hopefully.
You can sitll get Alps64 PCB from Batch.2 if payment is done till Oct 30th in JST.
Offline hasu
  • @tmk
« Reply #789 on: Tue, 01 November 2016, 15:53:51 »
All PCBs ordered from batch.2 were shipped today. You will receive an email with tracking number from Japan Post in a day,  let me know if not.
Leftovers are still available and can be shipped immedately in a few days. Price is revised for leftovers.
Thanks.
Offline XMIT
  • formerly jsoltren
« Reply #790 on: Sun, 06 November 2016, 19:36:11 »
So sorry for the delayed response! I built my board using a generic GH60 case that I purchased here:
http://www.ebay.com/itm/182211470719
With the AEK II plate it was tricky to get the screw locations right. I use three screws: left of Tab, right of \|, and toward the right edge of the Space bar. I drilled holes in the plate, and bolt the PCB to the case.
I've got this thread open now as I'm in the process of converting Cream Damped Alps to Creamsicle Alps - that means swapping in the springs and tactile leaves from donor Orange Alps switches. Tedious, but, so worth it. This completely changes the character of the switch! The only better setup I can imagine, would be a hybrid of Cream and Brown. I really, really like Orange, and this mod keeps the same character but makes them quieter. The loud Clack becomes a refined Thock. Fantastic setup.
Four switches down, 56 to go. I'll be here for a little while...
Offline XMIT
  • formerly jsoltren
« Reply #791 on: Sun, 06 November 2016, 22:00:09 »
Alright well, switching out the springs and leaves is done.
I modify what I said a little earlier. As a board I think it does feel better but only by a little bit.
The real magic of Orange Alps (and Blue Alps) is in the tall switch plate. This is part of what helps the switch to feel so solid: a rigid, no-flex, reinforced connection between the switch contacts and the shell of the switch.
As a proof of concept, I made one more complex hybrid switch. The spring, leaf, and switch plate are from an Orange switch. The top shell, bottom shell, and slider are from a Cream Damped switch. In order to get the tall Orange switch plate to fit in the bottom shell from the Cream Damped switch I had to snip two plastic pegs which are designed to support a short switch plate. The Cream Damped lower shell has landing pads for downstroke damping; it is easier to remove material than to add it.
The proof of concept switch is everything I could hope for from an Orange and Cream Damped hybrid. But, making it is really labor intensive since it involves swapping a switch plate. So I'll probably leave my board as is for now, unless I have some reason to de-solder all the switches *again*.
Thanks again to hasu for bringing this little PCB to production. The board I've made from it is one of my favorites, and my default (non-Hall effect, non-backlit) travel keyboard. :thumb:
Offline Laser
« Reply #792 on: Mon, 07 November 2016, 03:47:14 »
@XMIT (since you seem to know your Alps) - I have a sufficient number of Blue Alps for a 60% custom build, but I'd rather do "something" and end up with tactile switches instead of clicky (while keeping the quality, of course). What would you recommend?
I also have enough White and Black Alps (from a Dell 102). Would it be ok to take the non-clicky switch plates (is that the term) from the Blacks, and move it into the  Blues?
« Last Edit: Mon, 07 November 2016, 03:53:02 by Laser »
Offline Applet
« Reply #793 on: Mon, 07 November 2016, 04:05:41 »
Great insight XMIT, thanks for sharing, I have been planning to do something similar for a while (I WAS thinking damped sliders in orange housings). I think I'll go all in and translplant the orange switch plates as well into the cream housings. I'm also considering taking the rubber dampers from a Matias Quiet Click keyboard I have, do you think it is worth it? I'm a bit worried that the dampers from the creams will dry up.
Offline Hypersphere
« Reply #794 on: Mon, 07 November 2016, 07:01:05 »
Here is my latest hybrid, the "MatiaBlue" switch:
152252-0
This is a KBP V60MTS-C (V60 with Matias Click switches) with sliders, return springs, and click leaves transplanted from SKCM blue Alps switches.
These sound and feel more like blue Alps than Matias. The hybrid switches are lighter and quieter than Matias Click switches.
For the spacebar, I used a slider from a Matias Quiet switch. This dramatically quietens the spacebar.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #795 on: Mon, 07 November 2016, 07:31:40 »
Interesting.  They look pretty cool
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Hypersphere
« Reply #796 on: Mon, 07 November 2016, 15:43:00 »
For more information on the "MatiaBlue" hybrid Matias/Blue Alps switch, see the pics and video at either of the following links:
https://geekhack.org/index.php?topic=85664.msg2298435#msg2298435
https://deskthority.net/keyboards-f2/matias-switches-t14985.html#p336623
Offline gnmar2723
« Reply #797 on: Mon, 07 November 2016, 17:18:00 »
Just got mine in the mail today! Can't wait to finally finish my AEK 60% board that has been in the works for almost half a year  :D Kinda sad that I didn't get one of the iconic blue pcb's but hey, no one will see it anyways.
Offline tinyprawn
« Reply #798 on: Mon, 21 November 2016, 21:26:08 »
Got my PCB today! I am going to test it and then get soldering. I can do the Diodes now but my plate isn't in so I have to wait on the switches. 153454-0
Offline tinyprawn
« Reply #799 on: Wed, 23 November 2016, 11:38:28 »
Success! Gonna build it when the Lasergist board arrives or get sick of waiting and slice up my disassembled AEK2 keyboard's plate.
