Author Topic: Are the Ducky Mini's / Year of the Horse the thinnest 60% boards you can buy?  (Read 4062 times)
Offline dante
Subjects says all ..
I know Poker/V60 are 1.5"+.   Ducky Mini/YOTH is listed at 1.25"; anything on the market either past or present that is thinner than the Ducky?
Offline dante
No one?
Offline exitfire401
  • The Force is Re/\l
Not sure of any others with shorter dimensions.
dante, you are confusing me, bro. What is this thickness measurement? From the desk to the top of the keycaps, or what?
Offline dante
I'm just reading it off the specs on MechanicalKeyboards.com website.
Pretty sure that is a measurement of the highest point between desk and top of keycaps, not really a measurement of how thin the board really is.
The thinnest would probably be to put your 60% PCB inside a Tex case or similar and don't use feet. Oh yeah, with Cherry/GMK caps.
Offline Latin00032
A 60 percent gon might be pretty thin.
Offline dante
I assume you meant TEX Aluminum; do you know if the Acrylic is also as thin?
True.  Originally I was thinking Sprit because he offers a super low profile option however he has been MIA.  GON appears to be backlogged with work a couple months long - so that's not an immediate option.
Offline regack
Did anything ever come of the base-plate designs that swill was working on?  Those should make for a pretty thin keyboard.
Edit: found the thread
« Last Edit: Tue, 17 March 2015, 15:25:30 by regack »
Offline dante
I'll have to check that out!
I have one of those and they are awesome.
Offline trizkut
The tex acrylic case is 1.25cm tall
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
winkeyless cases are pretty thin and low profile, you could look into the b.face
Offline Oobly
GON NerD60 or any standard 60% in a flat Tex case.
If you really want a thin mechanical it's hard to beat the G84-4100, although it's a 75% and has ML switches. When they're lubed they're surprisingly nice. Unlubed they don't handle off-axis forces well.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline katushkin
  • Too Keycool for School
  • Just the guy
I would say probably a V60 with an aluminium case would be the thickest you could get. I have mine with the Granite set and it's nice and sleek. The Ducky Mini is pretty thick comparatively.
Why are you worried about the tickness anyway?
Offline dante
Because I like thin!
