Author Topic: Topre lube problem  (Read 3831 times)
Offline dungfrs
Topre lube problem
« on: Wed, 18 March 2015, 12:26:42 »
So recently i came up with an idea, lubing my hhkb... but i stuck with buying the gpl103. Question is can i use a mixture of gpl 205 and gpl 105? I mean is this method affect the typing experience to much ? I also use the dental bands.  ;D
Offline exitfire401
  • The Force is Re/\l
Re: Topre lube problem
« Reply #1 on: Wed, 18 March 2015, 12:29:42 »
I actually use a mixture of 105 and 205. It works wonderfully, just make sure you're applying the thinnest coat possible. As for dental bands, I suggest tossing them out and doing the o2dazone mod. It completely fixes the issue of impeding travel that's caused by dental bands.
Offline dungfrs
« Reply #2 on: Wed, 18 March 2015, 12:35:47 »
thanks for the reply, then should i keep 50-50 mixture or should i change? Sorry for my bad english ;D
Offline exitfire401
« Reply #3 on: Wed, 18 March 2015, 12:41:44 »
50-50 is fine. Try it on one, and if you don't like the feel of it, you can add more oil to get a more fluid mixture.
Offline dungfrs
« Reply #4 on: Thu, 19 March 2015, 00:02:17 »
i will try... any one use this mixture before?
Offline dungfrs
« Reply #5 on: Thu, 19 March 2015, 00:07:25 »
one more problem is my rubberdome come out of the pcb right after i remove the pcb from the case? is that affect the feeling?
Offline Synjin
« Reply #6 on: Thu, 19 March 2015, 00:09:18 »
Not if you replace it back on correctly.
Offline dungfrs
« Reply #7 on: Thu, 19 March 2015, 07:08:26 »
when i unassemble it, the domes fall off right away, is this normal? One more thing i feel it a little bit hard to type sometimes, feels like the domes are being hardened..
Offline Bucake
« Reply #8 on: Thu, 19 March 2015, 07:31:37 »
would it be a big mistake to use only grease (205 for example) for topre sliders?
Offline derb2k2
  • Something of a Topre ****..
« Reply #9 on: Thu, 19 March 2015, 11:12:08 »
does anyone know of someone selling the silicone bands that o2dazone made or something similar? I checked out some old threads but nothing there.
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
« Reply #10 on: Thu, 19 March 2015, 11:17:37 »
You buy silicone sheets and punches and punch them out.
There have been a few people who have made them and mentioned they might sell them but I've sent many PM's and never got replies from any of them.
Offline derb2k2
« Reply #11 on: Thu, 19 March 2015, 11:20:18 »
I've sent out a couple of PMs myself after checking the threads but also no reply.
I'm afraid I'll order the wrong stuff and silicone sheet but I like the idea of purchasing from another geek hacker.
Offline trizkut
« Reply #12 on: Thu, 19 March 2015, 11:28:08 »
o2dazone's thread has direct amazon links to what he used:
http://www.amazon.com/gp/product/B000KE17JO/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1
http://www.amazon.com/gp/product/B005584QJI/ref=oh_details_o00_s01_i00?ie=UTF8&psc=1
Some have said the 0.020" reduced the travel a bit too much, so you could try 0.010" thickness for a similar price:
http://www.amazon.com/dp/B005584R1U/ref=biss_dp_t_asn
The 12x12 sheet is more than enough, I screwed up a bunch and still only used 4 rows of punches
Offline spiceBar
    • ChessTiger.com
« Reply #13 on: Fri, 20 March 2015, 22:54:22 »
You can achieve less reduction in travel (so probably a better, unchanged, feel), by using my method here:
  https://geekhack.org/index.php?topic=49046.0
The landing pads I use are sold by EliteKeyboards:
  http://www.elitekeyboards.com/products.php?sub=access,slpads&pid=sl120_cs
The landing pads method is probably faster than punching silicone rubber, and after using a clothing iron on them they end up being thinner => no reduction of the Topre tactility.
