Author Topic: a post is brewing...  (Read 2338 times)
Offline wellington1869
« on: Fri, 11 September 2009, 16:53:30 »
apropos nothing, oh, I've got a good post coming this evening... :-D
:-D  Big. Grin.
have to run errands, meeting people for dinner etc, but after all that, it'll take a little time to put it together...  :-D
using: ms 7000/Das 3
Offline rdjack21
« Reply #1 on: Fri, 11 September 2009, 17:00:47 »
:blah: Ok if you say so....
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline huha
« Reply #2 on: Fri, 11 September 2009, 17:00:58 »
Write your post when you're done and don't announce you're going to, that's just annoying and honestly, no one cares about it.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ch_123
« Reply #3 on: Fri, 11 September 2009, 17:03:49 »
Unless you also got yourself an IBM 3278 keyboard, I probably won't get around to reading it for a while :p
« Reply #4 on: Fri, 11 September 2009, 17:04:25 »
Quote from: huha;117119
-huha
hahahahahahahahaha yes i should have posted that in off topic at least ;)
oh well. seemed like a slow friday afternoon.
well since the cats out of the bag: its about boards with bad scan rates. Found another one (just got it in the mail) and whats more its got fukkas. Got me kind of excited, is all.
« Last Edit: Fri, 11 September 2009, 17:09:16 by wellington1869 »
Offline ch_123
« Reply #5 on: Fri, 11 September 2009, 17:15:15 »
Filco Zero: Now with 100% genuine leftover DAS controllers.
« Reply #6 on: Fri, 11 September 2009, 17:18:52 »
another similarity is this board also used to have xm's and recently upgraded to fukkas. how about that? :D
Offline JBert
« Reply #7 on: Fri, 11 September 2009, 17:53:42 »
Bah, this is topic is off-topic!
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ch_123
« Reply #8 on: Fri, 11 September 2009, 17:56:27 »
I think the topic would have had more effect if it was just initially posted with details of when you first noticed the problem and then how you tested it... You might want to do that over in the Elitekeyboards section to let Majestouch know.
Offline o2dazone
« Reply #9 on: Fri, 11 September 2009, 21:48:17 »
a post is brewing
youre gay lol
Offline msiegel
« Reply #10 on: Sat, 12 September 2009, 00:26:57 »
wellington's gone off the deep end...
the keyboard fairy has brought him an imaginary low-scan-rate fukka board ;D
Offline maxlugar
« Reply #11 on: Sat, 12 September 2009, 01:02:14 »
Quote from: msiegel;117192
Wellingtons gone of the deep end because I just verified that the $50 DSI/Solitek 6600 has genuine branded ALPS keyswitches, has a slightly better feel than the Filco Zero, and no NKRO issues!
Although they are similar, there is a noticeable difference between the Solitek's ALPS key switches and the Filco's Fukkas.  The ALPS are slightly more clicky and also have a slight edge in tactile feel.
I concur with Sandy that both the simplified ALPS and so call Fukkas are inferior to the original complicated ALPS key switches.  The Northgate Omnikey is superior in just about every way to the Filco Zero or Solitek 6600.  The Northgates are also one of the ugliest keyboards ever designed.  It's a good thing I'm a touch typist so I don't have to look at the keyboard  :)
Hey, it's possible this is the post Welly as alluding to...
Emperor of the IBM 84-key AT Model F Darkside
Offline maxlugar
« Reply #12 on: Sat, 12 September 2009, 01:34:16 »
Quote from: ripster;117202
Welly just posted his ABS M1 review.  I beat him by 7 mins with a prediction.
"Get REAL Dude" is what I always say.
So that's what you always say huh?
The genuine orginal complicated ALPS are superior.  It don't make no never mind how much you dudes try to rationalize and prove other wise.
Offline msiegel
« Reply #13 on: Sat, 12 September 2009, 01:37:53 »
Quote from: maxlugar;117208
yeah but...
ehh, you're right
