Author Topic: Open/Re-assemble an Alps switch  (Read 10625 times)
Offline wellington1869
« on: Fri, 11 September 2009, 21:32:02 »
How to Open/Re-assemble an alps switch.
(If you're looking for how to take the keycap off, see here)
Opening an alps switch: This method uses 2 precision screwdrivers. See the link below the video for the "splinter forceps" method which is faster but requires more specialized tools.
See here for high resolution photographs of the exact same procedure: http://geekhack.org/showwiki.php?title=Island:4901
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">[/youtube]
[color="deepskyblue]
See here for faster "splinter forceps" method (but requires more specialized tools): http://geekhack.org/showwiki.php?title=Island:5452[/color]
Reassemble an alps switch: This video is for people who have trouble putting an alps switch back together. Picture is slightly blurry at times but it should give folks a good idea of whats involved.
Alternately: Use a magnet above the casing, as noted in the alps wiki:
« Last Edit: Fri, 30 April 2010, 13:36:04 by wellington1869 »
using: ms 7000/Das 3
Offline glossywhite
« Reply #1 on: Wed, 14 March 2012, 22:53:04 »
Awesome!
Offline Roguemaster8
« Reply #2 on: Wed, 14 March 2012, 23:06:23 »
Purple boxers.
Was this why Ripster hated him so much?
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
Offline hasu
  • @tmk
« Reply #3 on: Thu, 15 March 2012, 23:41:30 »
When reassemble I lean a board upside down to avoid spring from falling.
