Author Topic: Ducky Shine Zero or Ducky Shine 4?  (Read 4446 times)
Offline HoboInAShack
« on: Fri, 15 May 2015, 05:12:19 »
Not exactly sure which one to choose, but should I go and save myself or few dollars with the Ducky Shine Zero ($149 AUD), or go with the more expensive Ducky Shine 4($199)?
P.S. Currently, about $1.29 AUD is equal to about $1 USD.
Re: Ducky Shine Zero or Ducky Shine 4?
« Reply #1 on: Fri, 15 May 2015, 06:15:08 »
Welcome to Geekhack!
Depends on what features you want.  Either should be a good keyboard, but Shine Zero has less lighting effects, only single colour LEDs, and non-detachable cable.
Shine 4 has many more lighting modes, multi-coloured LEDs and detachable cable (it has detachable cable, right?  Shine 1, 2 and 3 did).
« Reply #2 on: Fri, 15 May 2015, 06:32:39 »
It does have a detactable cable :).
Lighting doesn't matter the most to me, but it'll be nice to have. I'll see how much I can afford, then decide. At most, I want the Ducky Cities Space Bar Set, as flaunting my nationality on my keyboard sounds like fun.
Offline Giorgio
« Reply #3 on: Fri, 15 May 2015, 08:32:34 »
I have a ducky zero with blacks (not sure if it is different from ducky shine zero).
I didn't know what was a ping before buying (and soon returning) that keyboard.
It drives you crazy.  :eek: :mad:
« Reply #4 on: Fri, 15 May 2015, 09:47:59 »
...whats a ping?....
I'm pretty sure the main difference between the ducky zero and the ducky shine zero is the backlighting.
Offline Giorgio
« Reply #5 on: Fri, 15 May 2015, 09:55:17 »
The ping is the vibration of the switch, that gets amplified by the plate, resunting in a ping, it really seems to make a... ping!
Ducky zero with blacks= very pingy
Cherry mx 3.0 with reds= no ping
« Reply #6 on: Sat, 16 May 2015, 01:29:03 »
So mainly the sound made by the keyboard itself, right?
It doesn't seem that bad to me though.
Offline Giorgio
« Reply #7 on: Sat, 16 May 2015, 01:40:56 »
It is unbearable in reality.
« Reply #8 on: Sat, 16 May 2015, 21:01:50 »
Sydney skyline though, not Melbourne :blank:
Offline Giorgio
« Reply #9 on: Sun, 17 May 2015, 03:28:16 »
It's like a diapason
« Reply #10 on: Sun, 17 May 2015, 04:02:31 »
Regardless, there are very few things more Australian than the Sydeny Harbour Bridge and the Sydeny Opera House!
Offline miroslav
« Reply #11 on: Sun, 17 May 2015, 11:17:44 »
I would say go with the Shine Zero unless you plan swap out your boards and care a lot about the dual leds. I have the Ducky Shine 4 69 Fire Edition myself and I don't use it all that often. I would prefer to save the 50 dollars because dual lighting + detachable cable just isn't worth it. With the Shine Zero you also have TKL whereas the Ducky Shine 4 will not have a TKL released (Heard from a head staff at Ducky). The Shine 4 has different case colors too if you decide to go for that option.
